Page 2 of 5 < 1 2 3 4 5 >
#1173303 - 04/20/07 09:41 AM Re: Burnout help [Re: 01FIVE-OH]
98VicP71 Offline
13.97@99MPH
Loc: ATL
Mine wont always break loose from a dead stop. Sometimes it does and sometimes it wont. there are factors to take into consideration as some have been said earlier.
1.) Tires: Are they new, sticky or good compound? Are they old hard compound and slick?
2.) conditions: Is it dry out? Is it rainy and wet?
3.) Road: What type of pavement is it? Mine wont break loose on asphault but on the older concrete it will some.
4.) Ambient Temp: Is it a cold or cool humid day? Is it a hot dry day?
all of the above factors would play a role in your ability to break traction from a dead stop without doing a brake torque first. There are other factors as well that would have to be considered but that pretty much sums up the major ones IIRC.
#1173310 - 04/20/07 09:59 AM Re: Burnout help [Re: 98VicP71]
Moses Offline
Loc: Long Island NY
I have a 2000 P71 and there is no TC.
As for burn out, I have never tried....
White 2000 P71 ~ 79000 miles,Purchased April 2006
Former White Plains Postal Inspector's Vehicle.
#1173354 - 04/20/07 11:41 AM Re: Burnout help [Re: 01FIVE-OH]
luv-my-2002-p71 Offline
Loc: New York
Don't stop trying. Just get a tune up. Bet it will then.
Even before I added my Circle D TC, I could remove my foot from the brake and then violently stab the gas and I'd get wheelspin from both tires.
#1173355 - 04/20/07 11:43 AM Re: Burnout help [Re: luv-my-2002-p71]
Loc: New York
Another thought: AED 6psi Kit + 4L11's = good burnout ability.
#1173410 - 04/20/07 01:01 PM Re: Burnout help [Re: luv-my-2002-p71]
Crown Nick Offline
Loc: Houston, TX
Even my LX with brand new tires and 2.73 rear end will break them loose. Granted, not rip them loose, but nontheless, still spin momentarily. My CVPI with 3.55s will spin for anywhere between 1-3 seconds before it catches from a dead stop. You guys who can't get your wheels to spin need tune-ups.
#1173422 - 04/20/07 01:21 PM Re: Burnout help [Re: Crown Nick]
whdahel Offline
Loc: North Bloomfield, Ohio
make a right turn when mashing on the slim pedal, you'll get it to go then! especialy if you hav an open diff.
02 GMQ HPP 88k miles
4th panther I have owned
no mods yet.....
My Garage: www.supermotors.net/8297
Loud pipes save lives!
#1173446 - 04/20/07 02:06 PM Re: Burnout help [Re: 01FIVE-OH]
TheMarquisPlaya Offline
Loc: Cornwall, NY
So, if I'm reading this right, pulling the TC fuse also eliminates the ABS? I have a '95 AFAIK I don't have a TC disable switch and I have to yank the fuse.
Darn.
Former Panthers:
1995 Grand Marquis LS (12/06 to 8/07)
1997 Grand Marquis GS HPP (11/08 to 12/09)
Current Panther:
2004 Grand Marquis LS Ultimate (11/19-present)
123k and climbing
It's good to be back.
#1173460 - 04/20/07 02:35 PM Re: Burnout help [Re: TheMarquisPlaya]
01FIVE-OH Offline
What does a tune-up consist of? I got new plugs, cops are working great, oil change, air filter, even got rid of that cracked intake. Today after a car wash i almost lost it when i was tearing down the street. almost a complete 360 but i didnt keep it going because it was broad daylight and tickets arent cheap. LOL
But since tires came up, I want some white letter tires for my 16 inch wheels. For some reason i just love the look of them. the only pair ive seen were the goodyear nascar ones. they are s-rated, but the rs-a's are h. should i break down to the s-rated?
2001 Ford Crown Vic P71
#1173486 - 04/20/07 03:11 PM Re: Burnout help [Re: 01FIVE-OH]
Corbin Offline
Loc: St. Louis, MO
There are a lot of raised white letter tires out there. Firestone Firehawk, BFG Radial T/A...if you can only find Goodyears then you aren't looking hard. I have to agree with you though, I do like the look of the raised whites (especially on a black rim).
Edited by Corbin (04/20/07 03:25 PM)
Edit Reason: picture
1997 P71 (RIP), 1996 P71 (daily driver, mostly stock), 1995 P71 ('97 engine...mods below)
Engine - PI h/c/i, Steeda UD pulleys & TA, short belt to bypass PS & AC, deleted mech fan, Meziere EWP, etc...
Driveline - J mod, MMC driveshaft, 3.27 RAR
Suspension - 21mm HPP rear swaybar, deleted front swaybar, 15x7 Cragars, 255/60R15 street tires
1/4 mile - '97 14.919 @ 92.48 / '96 16.051 @ 85.78 (stock, the day I bought it) / '95 14.632 @ 93.00
#1173535 - 04/20/07 04:14 PM Re: Burnout help [Re: 01FIVE-OH]
Loc: New York
Clean your MAF
Seafoam the upper intake - clean out EGR, TB and plenum.
Tranny flush.
Fuel Filter (was changed when??? $10-$12 part)
Auto-RX in the oil
New Gear oil for your rear end.
You also asked about gears, there is a little metal tag on your differential case. Mine says 3L27 - The L means track-lok.
If you change your rear gears you can go for 3.55 or 3.73 for more acceleration and the ability to do burnouts easily.
#1173555 - 04/20/07 04:41 PM Re: Burnout help [Re: luv-my-2002-p71]
98VicP71 Offline
13.97@99MPH
Loc: ATL
Did a tune-up
New fuel filter, New air filter, New plugs, New COP boots, New PCV, cleaned MAF,IAC,EGR,IAT.
Seafoamed
Flushed Trans
Rebuild and re-filled Rear-end
Checked Air pressure in tires (35 PSI)
Installed P&P plenum
Installed Underdrives
Did all of this and still can only peal from dead stop rarely on dry pavement.
You know it could be the 100#'s+ in my trunk from the speaker box and stuff.
I will have to take them out wait until I am down to about 1/8th tank and try again
#1173557 - 04/20/07 04:43 PM Re: Burnout help [Re: 98VicP71]
Crown Nick Offline
Loc: Houston, TX
Well, you have a locker as well. My peg leg has no problem spinning one tire, lol.
#1173559 - 04/20/07 04:48 PM Re: Burnout help [Re: Crown Nick]
dcninja Offline
Regional Cop Chipz Dealer (lawls!)
mine had a tune up when I tried....hell my plugs and wires are less than 3 months old, fresh oil and tranny fluid change...new coil packs, cleaned the plenum and all that too...
#1173581 - 04/20/07 05:11 PM Re: Burnout help [Re: dcninja]
96bluvic Offline
Loc: southeastern WI
My car spins them way to easy and i have wider tires. if do a brakestand I sure as hell dont mash the brake before the gas, and it doesnt take much.
I can still cherp them in second to.
Back in with an 07 CVPI
#1173583 - 04/20/07 05:15 PM Re: Burnout help [Re: dcninja]
pjames Offline
Loc: Quebec
try on a different road... the corner just after i leave work is prime wheelspin road, at half throttle you can get both wheels going, full throttle and you've got wheels spinning up to the highway (it's a right hand corner on to the service road, just before a highway on ramp, so much traffic booting it to merge then accelerate up to highways speed, lots of rubber on the road)
check your tire pressure too, air 'em up a little bit first.
'94 cv lx, dual dynaflow exhaust (no H or X Pipe), 189k kms (117k miles),nothin' special
