#1178787 - 04/28/07 11:46 PM
Re: Spark plug gap
[Re: jmlock]
No, that's electrode erosion. IOW they are "worn out"
Check yours in another 50-60K miles...
Age and Treachery Overcomes Youth and Cunning Any Day. '06 MGM LS UE HPP '96 Linc Mark VIII LSC '90 Bronco EB - The Urban Assault Vehicle
#1178801 - 04/29/07 12:33 AM
Re: Spark plug gap
[Re: UDL]
less is more�
Loc: Moses Lake, Wa
If you put on coppers, check them in like 10k. This is why they use platinums, they wear much slower.
-Colton  2004 Ford Crown Vic LX, 89k "Tank" (Totaled 12/06/15 22:30 PST) 2002 Ford Crown Vic PI, 201k "Highwayman" (Ex-Kootenai County, ID Unit #42) - Down for bad engine 2003 Ford Crown Vic PI, 98k "Name TBD"
#1178859 - 04/29/07 03:03 AM
Re: Spark plug gap
[Re: texasvic]
.054"
-Current: 2001 Crown Victoria P74  -Gone, but not forgotten: 1988 Mercury Grand Marquis 1994 Ford Crown Victoria 2000 Ford Crown Victoria HPP 2004 Ford Crown Victoria LX Sport 2004 Mercury Grand Marquis
#1178887 - 04/29/07 06:05 AM
Re: Spark plug gap
[Re: Ciffer]
Loc: Ontario, Canada
and remember, no anti-seize, use a torque wrench, start plugs by hand No anti-seize? Why the hell not?
Nothing's as bad as it seems... sometimes it's worse.
#1178888 - 04/29/07 06:07 AM
Re: Spark plug gap
[Re: lprocter]
Loc: North Carolina
I had always heard in the past that you should not reset the gap on a platinum plug from the factory. Is there a safe way to gap a plat plug without damaging the thin layer of platinum?
#1178889 - 04/29/07 06:08 AM
Re: Spark plug gap
[Re: lprocter]
Loc: Witchataw KS
and remember, no anti-seize, use a torque wrench, start plugs by hand No anti-seize? Why the hell not? you'll throw off the torque reading on your torque wrench, over tighten and possibly launch the plug
#1178893 - 04/29/07 07:03 AM
Re: Spark plug gap
[Re: Ciffer]
Torque wrench? What's that? Seriously, though, I've never used a torque wrench for spark plugs. I just tighten them until snug, enough that they stick a bit when I try to take them out. So far, no problems.
#1178931 - 04/29/07 11:13 AM
Re: Spark plug gap
[Re: BigNSlow]
still should be .054. unless you use nitrous.
#1178943 - 04/29/07 11:38 AM
Re: Spark plug gap
[Re: BigJon]
Loc: Chicago
OH MY F*CKING . . . I can not believe that we would really need to repeat this, there has to have been a BILLION damn threads on the topic over the years: 1) Do NOT use anti-seize despite what Haynes and Chilton's says. Dry or a light coating of oil. 2) Do NOT start the plug with a wrench, use your fingers on an extension or the classic length of tubing. 3) Use a properly calibrated torque wrench or you will be risking overtighening, wrecking the threads, and launching your plug (read the blown plug threads - you will NOT find anyone who doesn't appear to have messed up changing their plugs before it happened) The setting is pretty damn light; cause there ain't many threads in the aluminum. {note: the debate over whether it's crossthreading or overtorqueing (or both) is resolved by threading cautiously and using a torque wrench  } Oh yeah, do it with the motor cold AND make sure you thoroughly clean out the plug holes with compressed air or a serious shop vac BEFORE you pull the plug. Haul your head over the motor and look down into the well (use a flashlight if you need to) to make sure it's clean. Colder heat range does not require less gap. Higher compression or forced induction (blown or nitrous) sometimes requires running in the 30 - 40 range due to spark blowout problems. I run .40-.42 with the flattops/heads; I know a couple guys with similar motors who run nitrous on top of the cr bump, they run around .32 Better to have as much gap as you can as long as you're producing a healthy spark.
Edited by JCG1 (04/29/07 11:55 AM)
Former Ford Projects: 1967 Mustang w/transplant 351W : 1984 302 T-Bird : 1987 5.0 T-Bird : 1989 5.0 Mustang : 1992 5.0 T-Bird : Current: 2000 CVPIRenegade Racing 4.6 SOHC: Cobra Crank, Manley Rods, Coated Diamond Pistons 10.5:1 comp w/valve reliefs, PnP npi heads, PI intake, Comp Cams, 70mm TB, MM Airbox/80mmMAF/04 Zip, 190lph walbro, FRPP shortys, custom 2.25 duals, Xcal2, Jmod RoadmasterTranz, Dirtyd0g TC. 14.46 @ 95.59 / 14.50 @ 95.91 tuned by Darrin at BC Automotive Watch a 14.58 @ 94.13 Vid by DJChicago HERE
#1178947 - 04/29/07 11:54 AM
Re: Spark plug gap
[Re: JCG1]
I run .40-.42; I know a couple high-compression guys with nitrous on top who run .32 .32, wow, that's a lot of gap
2 registered (bluejay_32, Traffic22),
61
269
