#1220984 - 06/27/07 06:56 PM HELP!!! My intake manifold is leaking
d104rltw Offline
I just started smelling some coolant burning off and noticed that the intake manifold is leaking where the thermostat housing is...the car stating running rough and the check engine light came on..well it was a cylinder 6 misfire..so i replaced the coil and it runs fine now, but when i replaced it i noticed coolant on the spark plug when i pulled it...I want to replace the intake manifold...where and which one would be the best to buy? I have a 2002 P71..thanks a lot
2002 P71
#1220987 - 06/27/07 07:00 PM Re: HELP!!! My intake manifold is leaking [Re: d104rltw]
Crown Nick Offline
Loc: Houston, TX
http://adtr.net/shop.php?page=intake
Current PI intake manifold.
#1220989 - 06/27/07 07:02 PM Re: HELP!!! My intake manifold is leaking [Re: Crown Nick]
d104rltw Offline
that will fit right? whats up with the Additional modifications and parts are required
2002 P71
#1220994 - 06/27/07 07:04 PM Re: HELP!!! My intake manifold is leaking [Re: d104rltw]
Crown Nick Offline
Loc: Houston, TX
That's for someone doing a PI intake swap who has a pre '01 motor. You have a PI motor so it will be a direct swap. You probably have a model that was one of the last few to use the intake with the plastic crossover.
#1220999 - 06/27/07 07:10 PM Re: HELP!!! My intake manifold is leaking [Re: Crown Nick]
d104rltw Offline
2002 P71
#1221000 - 06/27/07 07:11 PM Re: HELP!!! My intake manifold is leaking [Re: d104rltw]
d104rltw Offline
2002 P71
#1221005 - 06/27/07 07:15 PM Re: HELP!!! My intake manifold is leaking [Re: d104rltw]
Crown Nick Offline
Loc: Houston, TX
Both are compatible.
#1221028 - 06/27/07 07:44 PM Re: HELP!!! My intake manifold is leaking [Re: Crown Nick]
jmlock Offline
Loc: Harris County, TX
If you have an 02 model like you stated, then you should already have the upgraded manifold that's half plastic / half metal. Odd that it's leaking. I haven't heard of any of them coming with the all plastic version.
2020 Lincoln Corsair 2.0 Ecoboost
2018 Ford F-150 2.7 Ecoboost
2015 Chevrolet Tahoe PPV
#1221035 - 06/27/07 07:56 PM Re: HELP!!! My intake manifold is leaking [Re: jmlock]
96bluvic Offline
Loc: southeastern WI
Since he has an 02 he just has the PI intake stock, it doesnt have the aluminum crossover.
The sputtering and CEL is the coolant fowling out the #5 spark plug
Back in with an 07 CVPI
#1221040 - 06/27/07 08:00 PM Re: HELP!!! My intake manifold is leaking [Re: jmlock]
Crown Nick Offline
Loc: Houston, TX
Some 2001 & 2002 models have all plastic PI Intake Manifolds.
#1221194 - 06/27/07 11:02 PM Re: HELP!!! My intake manifold is leaking [Re: Crown Nick]
d104rltw Offline
it has the aluminum cross over...its not all plastice
2002 P71
#1221195 - 06/27/07 11:03 PM Re: HELP!!! My intake manifold is leaking [Re: 96bluvic]
d104rltw Offline
What do you mean by the #5 leaking?
2002 P71
#1221202 - 06/27/07 11:13 PM Re: HELP!!! My intake manifold is leaking [Re: d104rltw]
96bluvic Offline
Usually when the thermostat cracks, the coolant flows into the #5 clyinder's spark plug causing it fowel out the plug, causing a sputter.
if you do have the intake with the aluminum crossover, check the thermostat housing piece, in fact i had replaced mine cause it was pitted real bad, check yours to see if the O-ring seal is in good shape, or if its pitted real bad.
#1221204 - 06/27/07 11:17 PM Re: HELP!!! My intake manifold is leaking [Re: 96bluvic]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
The o-ring for the t-stat housing is probably broke, are you SURE you have an aluminium crossover, I could've swore that started in 03.
#1221273 - 06/28/07 12:24 AM Re: HELP!!! My intake manifold is leaking [Re: Quickvic30]
Dan The Vic Man Offline
Loc: Coon Rapids MN
ADTR.net talk to chris, his pi intakes are sweet, i have one on my car.
2012 Ford F150 Ecoboost
RIP 99 CVPI
0 registered (), 24 Guests and 281 Spiders online.
bluejay_32 113
Old_Guy_Stu 79
a_d_a_m 62
Ponyguy 59
Moby_Vic 57
Dmblanch 45
DudeAbides 41
Armada Master 36
JeffBoudah 34
Lance01 34
