Page 12 of 23 < 1 2 10 11 12 13 14 22 23 >
#2104853 - 07/29/10 09:39 PM Re: The "MZT" and some popular bolt-ons [Re: Flippy328]
bigjeezy04 Offline
Loc: concord,ohio
 Originally Posted By: Flippy328
Unless your car came stock with a 80mm maf i.e marauder or 04+ cvpi you will need a tune to be able to use it or else your car wont run right because the computer is setup for a 70mm maf.
the 96 didnt have a 80 but it has 19lb injectors like the newer vics so u dont need a tune for a 04 80maf and his car runs fines with it cause its calibrated with the injectors... now if i put a 80 maf off a marauder i will need a tune for my 04 or any crown vic, cause the marauders have bigger fuel injectors and its calibrated for that
2004 p71 96000 rearcat delete,bumper tuck,z5 open now trac-loc with f-150 S spring,j-mod
1994 p71 115000, no cats(passed e-check)haha,beefed up tranny for free!!
1986 ford f-250hd 4x4 81000, ho351w meyers set up 8.6ft plow,custom exhaust,
2000 p71 ex ranger car 129000 brought 6/11/10 sold 6/18/10 to my dad
#2105409 - 07/30/10 12:53 PM Re: The "MZT" and some popular bolt-ons [Re: BigNSlow]
bigjeezy04 Offline
Loc: concord,ohio
Totally incorrect! All 2v Panthers have 19lb injectors except 01' which got 24lb. If you put ANY 80mm MAF on there, it will need a tune because the MAF transfer function will be different.
oh my bad i forgot about the 01s.. and why does everyone say u need a tune for everything? when u come up here for POTP ur going to see that a 96 cvpi runs fine with the 04 airbox and everything esle he has dont to it! cause if it didnt run right he would have put the stock one back on1?!?!?! and its his dd
#2105575 - 07/30/10 03:57 PM Re: The "MZT" and some popular bolt-ons [Re: BigNSlow]
bigjeezy04 Offline
Loc: concord,ohio
Do some data logging and see how "fine" it's running.
maybe ur right but intil than its runs fine but he is getting dyno tune on it one of these days
#2105646 - 07/30/10 05:12 PM Re: The "MZT" and some popular bolt-ons [Re: BigNSlow]
bigjeezy04 Offline
Loc: concord,ohio
Try unplugging the battery for about half hour then see how good it runs after.
the battery was unpluged when he did it
#2115293 - 08/13/10 12:49 PM Re: The "MZT" and some popular bolt-ons [Re: bigjeezy04]
99_03PantherS Offline
Loc: NW side Chicago
So why did the 01 get 24lb injectors? Better performance?
Jason G.
'06 Towncar Designer
'07 P71 SAP
'78 Continental
'98 Mark VIII
#2115452 - 08/13/10 07:46 PM Re: The "MZT" and some popular bolt-ons [Re: 99_03PantherS]
bigjeezy04 Offline
Loc: concord,ohio
i have HEARD, that ford ran out of the 19lb injectors so they threw the 24lb injectors in.. THATS WHAT I HEARD!!!
another thing i HEARD, was that they thought the performance upgrade to the heads and intake and cams where to much for the 19lb injectors. thats what I HEARD!!!
not sure tho correct me if im wrong, which i think i am wrong
#2115461 - 08/13/10 08:15 PM Re: The "MZT" and some popular bolt-ons [Re: bigjeezy04]
prodigalson Offline
Loc: Cleveland, OH USA
Well I heard, here in another thread, I think from Lonnie, that the 01 still had 19lbs, with the 24lb color connector. Not sure. Maybe he could chime in...
Permanently banned.
#2124260 - 08/25/10 12:17 AM Re: The "MZT" and some popular bolt-ons [Re: prodigalson]
Indeed, over the past year Lonnie has repeatedly stated on the forums that the '01s were also infact 19#hr and merely a different color than 'usual'. This is from referencing stock vehicle tables, so simply put - that should be that.
Besides the color difference - the belief of a different size injector was only further reinforced by the fact that for YEARS Ford listed a unique part number for the fuel injectors of 2001 model year ONLY.
Naturally, knowing the injector size/type and the connector itself is the same as all 1999-2002 models, and that Ford specified a unique injector for this model year only - lead to the simple conclusion of a different size injector as this could be the only variable that would not make them interchangeable (and infact the same part).
However, sometime within the past few months Ford's application guides were revised. The injector specified for 2001 is now also specified for 2002, which should finally put this issue to bed.
Curiously, 2000 is now listed as not interchangeable with 1999, or 2002 (or 01), but is the same as 2003-2004. And 1999 is spec'ed to use the same injector back to 1996.
This is wrong, as the connectors were changed 98<>99, but whatever Clearly, the Ford and Motorcraft application guides have their share of mistakes!
#2124307 - 08/25/10 01:50 AM Re: The "MZT" and some popular bolt-ons [Re: dRock96Marquis]
LTC_Dave Offline
Loc: Kansas
***06 LTC Signature Limited, Silver Birch, 18 Year Old GPS Maps, Movie Theater Audio, Hole-N-Roof, Seat Toaster, TheSunIsMyEnemy Windows,***POTM 06/18 - 10/18***, Garage Queen
P.I. zip tube and airbox, Mo's tune, Mach 1 chin spoiler, 4 tone horns, 18" Mustang Premium wheels, UltraGauge, 20% Tint, J-mod, 03 Fogs, Bluetooth FM transmitter, Wired back up camera. Dynomax UltraFlows
***00 Ford Explorer Eddie Bauer, Spruce Green, 5.0 HO, AWD, Highly Optioned, J-mod, GlassPacks and "high flow" cats, Kenwood radio, UltraGauge, 200k.
***94 Ford Ranger XLT, 3L, 5 Speed. 82k. 01 Mustang wheels. Easy mods and repairs. Daily
***02 Honda Accord, 213k. VTEC YO
#2126105 - 08/27/10 01:20 PM Re: The "MZT" and some popular bolt-ons [Re: LTC_Dave]
Spaceman_Spiff Offline
Loc: Festus, Mo
sorry, but to get back to the original thread topic...
 Originally Posted By: dRock96Marquis
-2004 models can use the 2004+ CVPI airbox/MAF instead of the Marauder airbox/MAF provided the correct connector is soldered in. Again, tuning still required.
am I reading it correctly that I can use a 2004+ CVPI airbox and MAF on my 2002 LX for the MZT rather than the MM airbox, with the only difference being the peak airflow rates of the MM vs CVPI MAF? (and the different harness for the MAF)
The way that quote is worded, I am not sure if that only applies to the -2004 CVPI's or ALL -2004 CV's...
2002 CV LX: 18" Glass Packs, Mustang 70mm TB, SuperChips MicroTuner, $1.50 Airbox Mod, UDP, 16" MB Razor wheels, JMOD
1992 Base Model CV (Bastard Car)
#2126472 - 08/27/10 11:35 PM Re: The "MZT" and some popular bolt-ons [Re: Spaceman_Spiff]
Squad_297 Offline
Loc: St. Clair Shores, MI
It applies to all -2004 Crown Vics. The only real difference between the MM box and the 04 CVPI box, other than the connector, is the 2004 CVPI MAF is a part of the air box lid, where the MM MAF is separate. Also just a mention.... When I used the 2004 CVPI box in my 2001, I had some small fitment issues. The connector for the MAF was almost up against the brake lines coming out of the ABS controller making it fun to get the air cleaner lid on. Also couldn't fully secure the rear lid latch because a hump in the inner fender was in the way. It coulda just been my car, it could be all pre 2003 models. I don't know for sure.
2001 Crown Victoria P71, 04 CVPI Intake & Zip Tube, 93 Octane Tune from Lonnie. SOLD
2009 Dodge Caliber
1984 Honda VF700C Magna
"Some people spend an entire lifetime wondering if they made a difference in the world. But the U.S. ARMED FORCES don't have that problem." ....Ronald Reagan
#2133824 - 09/06/10 08:24 PM Re: The "MZT" and some popular bolt-ons [Re: Spaceman_Spiff]
This applies to many using the MM box as well - myself included. Using washers on the rear mounts to raise the back of the airbox slightly can help, otherwise, just 'force' it - the inner fender is pretty flexible plastic, you should be able to get the latch to engaged relatively easily.
As Squad said, ALL 2004 and earlier - excluding only the 2004 MY CVPI of course, as it already has it ;\)
#2134905 - 09/08/10 07:43 AM Re: The "MZT" and some popular bolt-ons [Re: dRock96Marquis]
Loc: Festus, Mo
can anyone give me a part number for the 04+ p71 80mm MAF? the ebay sellers seem to think that their MAF will replace the 04 p71 MAF as well as all of the 05+ crown vics, but according to this thread, that just isnt true...
#2135642 - 09/08/10 11:17 PM Re: The "MZT" and some popular bolt-ons [Re: Spaceman_Spiff]
You are mis-reading the information in this thread
The MAF sensor itself IS the same between 04- CVPI and 05+ retail. In fact, virtually any (if not all) Ford application that use this new style MAF uses the same exact sensor.
The housing (which is integral to the upper airbox lid on newer models) is different (larger) for the CVPI with 80mm i/d versus 70mm for retail models (with tapered outlet to 80mm). This change in housing size effectively results in a different air transfer or voltage per given airflow, thus requiring a different 'tune' despite using the same sensor.
You need to order a complete 2004- cvpi airbox assembly w/ MAF to do this conversion (or get it used/salvage), plus the pigtail to wire it into a -04retail/-03cvpi
If you have an 04- CVPI airbox sans-MAF, you need to order the replacement MAF sensor (AFLS131)
Note, besides the tuning the MM MAF is plug and play for 95-04 (exc 04 PI) which makes it a more attractive/easier option.
You just need to drill the hole in the airbox lid for the IAT on 95-02 cars.
#2136027 - 09/09/10 01:08 PM Re: The "MZT" and some popular bolt-ons [Re: dRock96Marquis]
Loc: Festus, Mo
ah, got it. so the size is only referring to the diameter of the tube the MAF plugs into, so the same MAF will bolt into the different sized tubes. that makes sense, thanks for clearing it all up!
