Page 1 of 4 1 2 3 4 >
#1321704 - 11/13/07 02:07 AM functional oil pressure gauge mod
Ciffer Offline
Loc: Witchataw KS
i remember seeing something written up a while back about making the oil pressure gauge functional. i searched and didn't find anything, does anyone have a link to the info?
#1321711 - 11/13/07 02:16 AM Re: functional oil pressure gauge mod [Re: Ciffer]
http://www.supermotors.net/vehicles/registry/media/281470
http://www.supermotors.net/vehicles/registry/media/192127
Solder a jumper across the oil pressure gauge 20 ohm resistor on the printed circuit film and install the new sending unit.
#1322209 - 11/13/07 05:42 PM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
JohnG Offline
Tech Admin
Loc: Socialist state of MN
#1322218 - 11/13/07 05:53 PM Re: functional oil pressure gauge mod [Re: JohnG]
Ciffer Offline
Loc: Witchataw KS
is there a ford part number for the older style sending unit?
#1322230 - 11/13/07 06:02 PM Re: functional oil pressure gauge mod [Re: Ciffer]
Clayton Offline
Loc: South Carolina
Active duty 2007 CVPI
#1322285 - 11/13/07 06:58 PM Re: functional oil pressure gauge mod [Re: Clayton]
JohnG Offline
Tech Admin
#1322311 - 11/13/07 07:39 PM Re: functional oil pressure gauge mod [Re: JohnG]
Ciffer Offline
Loc: Witchataw KS
i have to pull the cluster to replace my o/d off bulb anyways, i replaced all the bulbs in the spring, must not have got that one in all the way.
i saw that, i'd rather use a motorcraft sending unit if one is available
#1322353 - 11/13/07 08:41 PM Re: functional oil pressure gauge mod [Re: JohnG]
Are you kidding, John? lol
Removing the cluster is a BREEZE. Trust me ;\)
Follow the directions in the BOK forum under 92-05 cluster bulb replacement to get it out ;\)
#1322465 - 11/13/07 10:53 PM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
Timmn1 Offline
Loc: Near I-80 & I-57
Edited by Timmn1 (11/13/07 11:01 PM)
Edit Reason: Spelling
1997 Grand Marquis GS - Died
#1322496 - 11/13/07 11:20 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
#1324550 - 11/16/07 12:41 PM Re: functional oil pressure gauge mod [Re: JohnG]
Robert Acorcey Offline
Loc: Cherry Hill, NJ
John, as you know, I have a Marauder, with the external guage cluster, and it's still a royal PITA!
- Randy
2004 Mercury Marauder w/Blue Oval Chips Programming
1996 Impala SS (12.45 @ 108.8 NA350)
#1324671 - 11/16/07 03:17 PM Re: functional oil pressure gauge mod [Re: Robert Acorcey]
Randy, not sure if you know this already, but the AutoMeter gauge in the Marauder is also a fake. You can buy a real working kit from AutoMeter, P/N 4327 that almost exactly matches the OEM gauge. Both the sender and the gauge itself must be replaced.
#1332001 - 11/26/07 04:21 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
#1332013 - 11/26/07 04:26 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Ciffer Offline
Loc: Witchataw KS
#1332021 - 11/26/07 04:36 PM Re: functional oil pressure gauge mod [Re: Ciffer]
Timmn1 Offline
#1332080 - 11/26/07 06:12 PM Re: functional oil pressure gauge mod [Re: Timmn1]
'97 was the first year for this, then.
My '96 cluster had the resistor:
My 98+ clusters do not have the resistor.
#1332125 - 11/26/07 07:12 PM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
Timmn1 Offline
My '97 cluster is almost exactly the same as your '96, right down to the round pads the resistor is mounted to, except that there is a trace running between the pads.
#1333570 - 11/28/07 02:26 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
I thought I'd update my progress so far on this thread.
The Motorcraft SW873B sending unit won't fit. There is a steel line running to the bottom of the power steering pump, and the sending unit hits it, and I can't get the threads to line up well enough to start them.
I found another sending unit, Motorcraft SW2433 and have ordered it. It is smaller than a SW873B, the only problem is that nobody stocks it, I should have it tomorrow.
#1333690 - 11/28/07 04:19 PM Re: functional oil pressure gauge mod [Re: Timmn1]
o0_C_0o Offline
wait... so on this pic where would you place the jumper? cuz this pic looks like mine but doesnt look anything like the pic on the install thread... (i think its the resistor on the far left, correct?)
Edited by o0_C_0o (11/28/07 04:23 PM)
-96 P73-
-Flex-a-lite Black Magic Fan (brand new in box)..........$20 (Crackhead @ work) laugh
-Headlight Relay Upgrade
#1333714 - 11/28/07 04:41 PM Re: functional oil pressure gauge mod [Re: o0_C_0o]
Timmn1 Offline
Yes, it's the resistor on the left directly above where the wiring harness connector plugs in.
#1333721 - 11/28/07 04:45 PM Re: functional oil pressure gauge mod [Re: Timmn1]
o0_C_0o Offline
ok, thanks....
Timmaaaayyy!!!(sorry)
-96 P73-
#1333824 - 11/28/07 06:38 PM Re: functional oil pressure gauge mod [Re: o0_C_0o]
Yep. It actually says OIL and 20 OHM right next to it. Would be hard to mistake it ;\)
#1333894 - 11/28/07 08:10 PM Re: functional oil pressure gauge mod [Re: Timmn1]
mattelderca Offline
Loc: Whitby, Ontario, Canada
Use the bottom plugged port and Get a 90 degree elbow in brass so the sending unit points back. Should fit then. Just leave the original in place or replace it with the plug removed from the bottom.
Edited by mattelderca (11/28/07 08:12 PM)
Edit Reason: shorted my response
93' Mercury Grand Marquis LS
Gone to the crusher now!
RIP
#1334034 - 11/28/07 10:38 PM Re: functional oil pressure gauge mod [Re: mattelderca]
Timmn1 Offline
Great idea! I wish I would have thought of that before I ordered the other sending unit.
Oh well.
#1334635 - 11/29/07 04:42 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
Well, I got the Motorcraft SW2433 sending unit this morning, and put it in. It replaces the stock sending unit perfectly, it looks as if it could have rolled off the assembly line that way.
It's harder to get, there are only two Ford models that use it, but well worth the wait.
One of them is a 1993 Mustang GT 5.0L 302CID w/gauge
My first mod, a fully functional oil pressure gauge!
#1334798 - 11/29/07 09:19 PM Re: functional oil pressure gauge mod [Re: Timmn1]
jmlock Offline
Loc: Harris County, TX
Congrats. Now where you able to do it with your '97 cluster, or did you have to modify the other one you had?
#1334893 - 11/30/07 12:17 AM Re: functional oil pressure gauge mod [Re: jmlock]
I think he is using a 92-96 oil pressure GAUGE, inside his 97 cluster shell, with the new sending unit (and no jumpers used)
The 97+ clusters do not have the external 20ohm resistor, it is integral to the gauge. So, by using a -96 gauge inside his 97 cluster there is no resistor being used, which means it will read like a functional pressure gauge provided you use the correct sender.
#1334904 - 11/30/07 12:40 AM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
kustomizingkid Offline
Loc: Minnesota
I don't understand why they made all the gauges give dummy readings in the first place.
2000 CVPI 121,000 miles
#1334906 - 11/30/07 12:46 AM Re: functional oil pressure gauge mod [Re: kustomizingkid]
TechnoWeenie Offline
Loc: The perimeter
Customers who don't know jack about cars don't like seeing gauges jump all over the place, even if it's perfectly normal..
#1334907 - 11/30/07 12:49 AM Re: functional oil pressure gauge mod [Re: jmlock]
Timmn1 Offline
Both of mine were '97 clusters, the only way to make this mod work with a '97 cluster, is to use a temp/oil guage assembly from a '96 cluster. The oil gauge in the '97 (and probably newer) can't be used for this mod.
The '96 and the '97 clusters are identical with the exceptions of the oil guage and the resistor. To remove the assembly, you have to remove the 4 gold screws at the top of the cluster, and the other 4 at the very bottom. This will allow you to remove the "glass" and the black plastic frame surrounding the gauges. This will expose the gauge assemblies. Just grab the temp/oil guage assembly, and gently pull, it will unplug from the cluster.
The '96 gauge assembly will plug right into the '97 cluster, and since there is no resistor, you don't have to jump anything. I changed the gauge assembly without removing the cluster from the car.
Once you have done that, the only thing that remains is to change the sending unit. I recommend the Motorcraft SW2433, harder to get, but easier to install. The Standard part number is PS243, GP Sorensen is OPS134.
#1335022 - 11/30/07 06:31 AM Re: functional oil pressure gauge mod [Re: Timmn1]
Ciffer Offline
Loc: Witchataw KS
great info timmn1, i'll have to go out and find a 96 cluster at a salvage yard next year.
#1335035 - 11/30/07 08:29 AM Re: functional oil pressure gauge mod [Re: Ciffer]
Timmn1 Offline
After doing the mod, and driving around with it, I found that the "reaction time" for the gauge is a bit slow, but it's a heck of a lot better than the fake gauge I had.
#1335036 - 11/30/07 08:37 AM Re: functional oil pressure gauge mod [Re: Ciffer]
Timmn1 Offline
Next year? We're from the Midwest, when do we let a little cold and snow stop us from doing anything?
#1335469 - 11/30/07 07:40 PM Re: functional oil pressure gauge mod [Re: Timmn1]
jmlock Offline
Thank you, drock and Timm.
#1335588 - 11/30/07 10:35 PM Re: functional oil pressure gauge mod [Re: jmlock]
Timmn1 Offline
You are Welcome, hopefully, the next person who tries this will find all of this helpful.
#1335612 - 11/30/07 10:54 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Ciffer Offline
Loc: Witchataw KS
i broke my foot and don't feel like hobbling around salvage yards checking VINs, it isn't a cold issue. besides my car is parked in someone else's garage for the winter.
#1335882 - 12/01/07 12:37 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Embassy Offline
Excellent information. Looks like I'll be pulling two '96 instrument clusters the next time I'm at the salvage yard.
This information should be added to the BOK section.
2003 Procharged Marauder, F.I.T. #003
2004 SAP P71
The EmbassyVic:SOLD!
'01 P71: SOLD!
Keeping a black car clean is not a hobby. It's a part time job.
Support the troops.
#1335957 - 12/01/07 02:00 PM Re: functional oil pressure gauge mod [Re: Embassy]
Bobert2647 Offline
Former Vic Owner
Loc: West TN
I'm sure dRock will have a write up done soon.
#1336098 - 12/01/07 05:44 PM Re: functional oil pressure gauge mod [Re: Bobert2647]
Ciffer Offline
Loc: Witchataw KS
TCCoA has an article on the oil pressure gauge, but does not mention anything about the 97+ gauges, might have never changed from the from the -96 style for the MN12/FN10s.
last article on the page
http://www.tccoa.com/articles/engine/index.html#
Edited by Ciffer (12/01/07 05:45 PM)
#1356391 - 12/29/07 12:01 AM Re: functional oil pressure gauge mod [Re: Ciffer]
Timmn1 Offline
Just thought I'd update this, I've put about 3000 miles on since I did the mod, and it's working like a charm. The only real complaint is that the "response time" for the gauge is a bit slow, but other than that minor complaint, I'm happy!
#1363766 - 01/07/08 05:41 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Ciffer Offline
Loc: Witchataw KS
cool, i am planning to do this mod next spring
#1381416 - 01/28/08 05:14 AM Re: functional oil pressure gauge mod [Re: Ciffer]
K-9Vic Offline
Loc: Fort Worth, TX
Great information, I need to install this for my oil pressure gauge I just installed. The factory sending unit just pegs the gauge as it is the dummy sender, I will go ahead and order the Motorcraft SW2433. Then I will have a real oil pressure gauge on my A-Pillar.
2011 Caprice PPV V8 6.0L L77 <-- Yes I really own a Caprice PPV
1998 Chevy Suburban K1500 4x4, 6.5L Turbo Diesel.
1984 Chevy K20 4X4 6.2L Suburban (CUCV clone)
1986 M1031 - CUCV Military Vehicle, also a 2003 Honda ST1100P (serial #000001)
#1381687 - 01/28/08 02:18 PM Re: functional oil pressure gauge mod [Re: K-9Vic]
jmlock Offline
^^^ Are there any pics of the new ride yet?
#1383523 - 01/30/08 01:35 PM Re: functional oil pressure gauge mod [Re: jmlock]
K-9Vic Offline
Loc: Fort Worth, TX
Yes, posted this in the lounge
https://www.crownvic.net/ubbthreads/ubbth...266#Post1381266
#1410242 - 02/28/08 07:24 PM Re: functional oil pressure gauge mod [Re: K-9Vic]
peteinsf Offline
Loc: San Francisco
Guys,
I am assuming that this will work on my 2001. To confirm I just need to find a 1996 movment? (and the sender of course)
Pete
2001-P73 CNG 21K (now 30K)
hlbly Offline
Loc: Knoxville TN
For the record:
(Motorcraft SW-1311)
BA
hlbly Offline
Loc: Knoxville TN
peteinsf Offline
Loc: San Francisco
Hmm,
1995 returns one.
troyco Offline
Loc: Ontario, Canada
1996 Mercury Grand Marquis GS
UPCOMING MODS:
Snow tires and an oil change.
Here's mine:
troyco Offline
here's what i can make out
GRAND MARQUIS EM114 200 KPH
F6MF-10849-BB
22 MAY 199-
UPCOMING MODS:
troyco Offline
UPCOMING MODS:
peteinsf Offline
Loc: San Francisco
1995-2002
2003-2007? (my guess)
1995-2002
1995-1997 cv/gmq
1998-2002 cv/gmq
2003-2005 cv/gmq
F6MF-10849-BB
22 MAY 199-
Timmn1 Offline
Timmn1 Offline
2 registered (magic, 1 invisible), 39 Guests and 128 Spiders online.
bluejay_32 204
a_d_a_m 126
Old_Guy_Stu 123
DudeAbides 95
Ponyguy 69
Davidzq 47
CrystalPistol 46
Moby_Vic 43
ClayBelt 37
LTC_Dave 35
