Page 1 of 4 1 2 3 4 >
#1321704 - 11/13/07 02:07 AM functional oil pressure gauge mod
Ciffer Offline
Loc: Witchataw KS
i remember seeing something written up a while back about making the oil pressure gauge functional. i searched and didn't find anything, does anyone have a link to the info?
#1321711 - 11/13/07 02:16 AM Re: functional oil pressure gauge mod [Re: Ciffer]
http://www.supermotors.net/vehicles/registry/media/281470
http://www.supermotors.net/vehicles/registry/media/192127
Solder a jumper across the oil pressure gauge 20 ohm resistor on the printed circuit film and install the new sending unit.
#1322209 - 11/13/07 05:42 PM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
JohnG Offline
Tech Admin
Loc: Socialist state of MN
#1322218 - 11/13/07 05:53 PM Re: functional oil pressure gauge mod [Re: JohnG]
Ciffer Offline
Loc: Witchataw KS
is there a ford part number for the older style sending unit?
#1322230 - 11/13/07 06:02 PM Re: functional oil pressure gauge mod [Re: Ciffer]
Clayton Offline
Loc: South Carolina
Active duty 2007 CVPI
#1322285 - 11/13/07 06:58 PM Re: functional oil pressure gauge mod [Re: Clayton]
JohnG Offline
Tech Admin
#1322311 - 11/13/07 07:39 PM Re: functional oil pressure gauge mod [Re: JohnG]
Ciffer Offline
Loc: Witchataw KS
i have to pull the cluster to replace my o/d off bulb anyways, i replaced all the bulbs in the spring, must not have got that one in all the way.
i saw that, i'd rather use a motorcraft sending unit if one is available
#1322353 - 11/13/07 08:41 PM Re: functional oil pressure gauge mod [Re: JohnG]
Are you kidding, John? lol
Removing the cluster is a BREEZE. Trust me ;\)
Follow the directions in the BOK forum under 92-05 cluster bulb replacement to get it out ;\)
#1322465 - 11/13/07 10:53 PM Re: functional oil pressure gauge mod [Re: dRock96Marquis]
Timmn1 Offline
Loc: Near I-80 & I-57
Edited by Timmn1 (11/13/07 11:01 PM)
Edit Reason: Spelling
1997 Grand Marquis GS - Died
#1322496 - 11/13/07 11:20 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
#1324550 - 11/16/07 12:41 PM Re: functional oil pressure gauge mod [Re: JohnG]
Robert Acorcey Offline
Loc: Cherry Hill, NJ
John, as you know, I have a Marauder, with the external guage cluster, and it's still a royal PITA!
- Randy
2004 Mercury Marauder w/Blue Oval Chips Programming
1996 Impala SS (12.45 @ 108.8 NA350)
#1324671 - 11/16/07 03:17 PM Re: functional oil pressure gauge mod [Re: Robert Acorcey]
Randy, not sure if you know this already, but the AutoMeter gauge in the Marauder is also a fake. You can buy a real working kit from AutoMeter, P/N 4327 that almost exactly matches the OEM gauge. Both the sender and the gauge itself must be replaced.
#1332001 - 11/26/07 04:21 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Timmn1 Offline
#1332013 - 11/26/07 04:26 PM Re: functional oil pressure gauge mod [Re: Timmn1]
Ciffer Offline
Loc: Witchataw KS
#1332021 - 11/26/07 04:36 PM Re: functional oil pressure gauge mod [Re: Ciffer]
Timmn1 Offline
4 registered (theBeast1984, vin48, 1291897caexempt, Warped9), 60 Guests and 241 Spiders online.
bluejay_32 208
a_d_a_m 129
DudeAbides 123
CrystalPistol 118
Old_Guy_Stu 115
Moby_Vic 80
ford05 60
Ponyguy 56
Warped9 56
RF_Overlord 49
