#1322209 - 11/13/07 05:42 PM
[Re: dRock96Marquis]
Tech Admin
Loc: Socialist state of MN
#1322230 - 11/13/07 06:02 PM
[Re: Ciffer]
Loc: South Carolina
Active duty 2007 CVPI
#1322285 - 11/13/07 06:58 PM
[Re: Clayton]
Tech Admin
#1322311 - 11/13/07 07:39 PM
[Re: JohnG]
Loc: Witchataw KS
i have to pull the cluster to replace my o/d off bulb anyways, i replaced all the bulbs in the spring, must not have got that one in all the way. According to DRock's linked pictures, the NAPA part# is OP6091. i saw that, i'd rather use a motorcraft sending unit if one is available
#1322353 - 11/13/07 08:41 PM
[Re: JohnG]
If it weren't such a PITA to remove the cluster, I might try and work this mod into the '04. Are you kidding, John? lol Removing the cluster is a BREEZE. Trust me Follow the directions in the BOK forum under 92-05 cluster bulb replacement to get it out
#1322465 - 11/13/07 10:53 PM
Loc: Near I-80 & I-57
Edited by Timmn1 (11/13/07 11:01 PM) Edit Reason: Spelling
#1322496 - 11/13/07 11:20 PM
[Re: Timmn1]
#1324550 - 11/16/07 12:41 PM
[Re: JohnG]
Loc: Cherry Hill, NJ
If it weren't such a PITA to remove the cluster, I might try and work this mod into the '04. John, as you know, I have a Marauder, with the external guage cluster, and it's still a royal PITA! - Randy
2004 Mercury Marauder w/Blue Oval Chips Programming 1996 Impala SS (12.45 @ 108.8 NA350)
#1324671 - 11/16/07 03:17 PM
[Re: Robert Acorcey]
John, as you know, I have a Marauder, with the external guage cluster, and it's still a royal PITA! Randy, not sure if you know this already, but the AutoMeter gauge in the Marauder is also a fake. You can buy a real working kit from AutoMeter, P/N 4327 that almost exactly matches the OEM gauge. Both the sender and the gauge itself must be replaced.
#1332001 - 11/26/07 04:21 PM
[Re: Timmn1]
#1332013 - 11/26/07 04:26 PM
[Re: Timmn1]
Loc: Witchataw KS
#1332021 - 11/26/07 04:36 PM
[Re: Ciffer]
2 registered (ClayBelt, 1 invisible),
71
262
