#1376996 - 01/23/08 01:46 PM Power Steering pump leaking fluid
2008MGM Offline
Loc: Richmond, VA
Hi all,
I have noticed recently that the power steering pump reservoir is losing fluid, and the main hose underneath is all wet/dirty looking. I also notice that the fluid will leave spots on the ground underneath. I have searched power steering pump in the 5.0/5.8L archives, but could not find much info.
Does anyone have much experience with the power steering pump kits at places like Autozone? Are they worth spending the $15.00 on? It appears that the pump is working correctly (aka I can see the fluid physically moving in the reservoir when the car is started and there are no noises coming from the pump area). I am thinking that maybe one of the o-ring seals or something has failed causing the fluid loss. Also, is this a pretty easy task to remove the power steering pump hose/seals and replace? Thanks guys.
-Jason
5.0L 1989 Colony Park 302.
2008 Mercury Grand Marquis LS - Silver Birch Metallic - 143,XXX miles - Dual exhaust system, Jensen double-din stereo unit with Bluetooth, GPS, Infinity Basslink subwoofer/amplifier, back-up camera
#1377437 - 01/23/08 08:11 PM Re: Power Steering pump leaking fluid [Re: 2008MGM]
mikeri Offline
I am All Pro in the leaking 1989 power steering position. Mine leaked just like yours for ....6 years maybe. Just kept filling it up. I would try some Barr's leak transmission fix first. It may seal up the resevoir. There are many brands of course, but I had good luck with the above. I finally swapped out the p/s pump when the steer gear box leak got unwieldy. So I did both at the same time. Keep the fluid up and you should have no running problems, other than spots on the driveway. I went through many a card board box. I never did buy the kit and try to reseal.
#1377555 - 01/23/08 09:59 PM Re: Power Steering pump leaking fluid [Re: 2008MGM]
1991MGM Offline
A noisy and/or leaking Ford power steering pump or box...
... absolutely unheard of!!! Besides a 1991 Grand Marquis I have a 1987 F150 so I am familiar with the Ford power steering woes. I did use Lucas power steering leak stop with success on the truck (it eventually took 2 bottles but the leak at the steering box has almost entirely stopped). As long as you keep the fluid level at the correct level no real problems should occur. My Grand Marquis only has 36,000 miles on it so there are no steering issues yet (but I'm sure it's only a matter of time). At least the Fords give you plenty of forewarning as to power steering issues unlike other makes that die entirely out of the blue.
#1378418 - 01/24/08 08:53 PM Re: Power Steering pump leaking fluid [Re: 1991MGM]
mikeri Offline
LMAO. Really. I recently posted that my other 89 just started a very small leak at the P/S pump, just as it rolled over 100k, almost like the odo was linked to the p/s pump.......BTW, I replaced the original stear box at 160, IIRC, and the rebuilt at 240k on the other, which means the original P/S pump lasted to 240k also.
#1378425 - 01/24/08 09:03 PM Re: Power Steering pump leaking fluid [Re: mikeri]
mikeri Offline
BTW, for those 6 years of just refilling, I used Walmart brand type F, which for years was dirt cheap, and the pump lasted until 240k, and it would still be on the car if the stear gear didn't let go.
#1378989 - 01/25/08 01:04 PM Re: Power Steering pump leaking fluid [Re: mikeri]
AOD Offline
My car leaks at the resevoir too...but only if I keep it filled. ;\) I usually run it a little low until the pump starts groaning loudly, then I add a bit.
I need to replace it...just haven't gotten to it yet.
#1379018 - 01/25/08 01:49 PM Re: Power Steering pump leaking fluid [Re: AOD]
hobbie2k Offline
Mine does that too...which reminds me...I really need to refill it...
'08 Ford Fusion SEL 2.3 manual "Zap"
'89 Ford LTD Crown Victoria wagon "Howard" (For Sale - $1000)
#1379391 - 01/25/08 09:02 PM Re: Power Steering pump leaking fluid [Re: hobbie2k]
TheBlunderbuss Offline
Loc: CHAMPAIGN, IL
Mine never consumes fluid.
02/88 LTD Crown Victoria - 860 miles (hehe)
Don't forget that Throttle valve cable clip update!
#1379589 - 01/26/08 12:55 AM Re: Power Steering pump leaking fluid [Re: TheBlunderbuss]
JDT Offline
Loc: milwaukee, wisconsin
mine used to leak . untill i started using trans fluid in it ( recomended by ford i guess). then all groaning and leaking stoped.
88 CV LX (RIP) and forever in the sig
04 CV p71 67k (tasteful power mods coming soon!)
00 CV p71 127k (sitting. waiting to be sold)
Plus a few General motors cars
#1380328 - 01/26/08 07:06 PM Re: Power Steering pump leaking fluid [Re: JDT]
hobbie2k Offline
Is that true? If it is I might have to try it...
#1380361 - 01/26/08 07:50 PM Re: Power Steering pump leaking fluid [Re: hobbie2k]
btsom Offline
Loc: Oklahoma,America
On both an 89 and a 91, the leaks I had were the return hose. Tightening the hose clamps did no good, finally replaced the hose and everything was dry after that. As windy as it is in there, drops of fluid could be blown anywhere after they separate from the low point.
Now that I've defragged my brain, I've got 89% free space! Entropy manager.
#1380382 - 01/26/08 08:28 PM Re: Power Steering pump leaking fluid [Re: btsom]
SteveS Offline
Administrator
Loc: Groveland, MA
I recently replaced both hoses on the red box. They are available from NAPA.
Steve
1991 P72, 2006 P71, 2016 Explorer XLT, 2019 F250 XLT CCSB
#1380420 - 01/26/08 09:24 PM Re: Power Steering pump leaking fluid [Re: SteveS]
Loc: CHAMPAIGN, IL
Oh shoot. Forgot to mention mine seemed to be leaking at some point, but it was a slow leak.
The hoses were saturated with fluid.
The replacement hoses still showed thread when I tightened them down. Not to worry -- the o-ring at the tip of the fitting ensures a seal. Seeing thread is ok.
#1380736 - 01/27/08 10:49 AM Re: Power Steering pump leaking fluid [Re: TheBlunderbuss]
kyle91LTDcv Offline
Loc: Allentown, PA
mine doesnt leak, but it is loud sometimes. has a kind of whining sound to it if u turn the wheel with the car not moving. ive never really looked closely at the powerstearing system, is there a way to change the fluid?
**CURRENT PANTHER** 2003 CVLX HPP -Chestnut Metallic. 16" Y-Spoke alloys (winter) 17" LX Sport wheels (summer), factory dual exhaust, 3.27 rear end, leather interior, long overhead console, and RAS. All stock. Engine failed at 184K due to broken valve spring and replaced with an '05 town car engine. Currently around 220K miles / 75K on the engine.
**CURRENT NON-PANTHER** 2014 VW Jetta 1.8 TSI: Currently has 210K
**PREVIOUS PANTHERS** 1991 LTD CVLX (RIP): Oxford White: Mileage unknown - Odometer stopped working at 48,685miles - Succumbed to frame rust | 2003 Grand Marquis GS Convenience (RIP): Spruce Green Metallic. 90K miles (SOLD 2013), later found on a salvage website. Apparently made close friends with a pole/tree
#1380996 - 01/27/08 06:09 PM Re: Power Steering pump leaking fluid [Re: kyle91LTDcv]
Loc: CHAMPAIGN, IL
Detach the return hose from the reservoir, place in bucket, turn on engine, pour new fluid until old fluid is gone, moving steering wheel to each stop 5 times.
0 registered (), 38 Guests and 244 Spiders online.
CrystalPistol 362
bluejay_32 324
a_d_a_m 231
Rainbowpizza 167
DudeAbides 149
JeffBoudah 124
Old_Guy_Stu 77
BigNSlow 69
Bangster 62
