Page 1 of 13 1 2 3 12 13 >
#1397017 - 02/14/08 12:20 PM The Marauder Cluster Swap...
Ezbok58a Offline
Loc: Who wants to know...
Buddy at the dealer was unable to swap the marauder cluster into my car. (Something to do with lacking volt and oil gauge outputs, which I can see is not true, and something about PATS being in the cluster which has some validity to it, I'm not savy on the cluster so I don't know if what he said holds water or not.)
So I bit the bullet and am doing the swap myself, however I need those of you on here (P71_CrownVic I mean you and anyone else that did the swap...K9 I mean you too...) To tell me what you had to change and how you changed it.
And as a service to those of you thinking about said swap, here's some progress pics...
Rear of Marauder Cluster
Some sort of chip from the cluster, I have no idea what it does or if its important or not (I also sneezed when taking that pic, no spit hit the chip)
Where the chip goes in relation to the console
The cluster stripped down of all protective stuff.
The set up behind each gauge pod (fuel and temp)
Tach
Speedo removed. This is where I need help, I need that electronic piece off of the speedo face, once thats off then the rest of this should be a cake walk.
Anyone know how that part of the odometer can be removed let me know...
Also I'll need to know how I remove my existing cluster from my dashboard :look:
I'll do what I can today, and finish on the weekend.
#1397061 - 02/14/08 01:33 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Blue95 Offline
Loc: Past the Horizon
Derek gave me great help when I needed to replace the odometer gear on my 95 PI.
Following his instructions, I used a fork to carefully pry up the speedo needle off of the shaft. I put a very thin piece of metal under the fork to avoid marking the speedo face. The needle will pop off. Then the circuit board can be removed from the face panel by removing the attachment screws.
You also need to be careful when re-installing the needle in order to get it calibrated right. Ignition has to be on so that you can carefully push the needle back on where it is just barely above the stop tab. You will see that with ignition off, the needle will rest on the tab, with ignition off, the needle jumps up a bit off of the tab as the circuit is energized.
Best way is to install and then drive using a scantool that will read out the mph as you drive along. You can then compare the needle position to the scantool read-out. I just set mine by the first method and it seems to be fine.
The odometer motor and gearset can be removed by prying them out of the housing. The motor needs to twist a bit as it's removed if I remember right. The gearset end shafts are held in place by tabs.
1995 P71-SOLD
2002 HPP-SOLD
#1397080 - 02/14/08 01:58 PM Re: The Marauder Cluster Swap... [Re: BigNSlow]
Ezbok58a Offline
Someone should do a write up on this subject as it seems to be getting more popular.
Considering I'm taking pics and asking questions as I go this, it should be a tremendous help to those who are interested.
Also, I'm also the first to do this on a Civi Vic, so swapping that odometer computer is a must, otherwise the car won't start and you'd have to get new keys for the car. Courtesy of the PATS system Ford has \:\)
#1397083 - 02/14/08 01:59 PM Re: The Marauder Cluster Swap... [Re: BigNSlow]
Vin, there is info on cluster removal in the BOK forum (92+ cluster bulb replacement)
Like Nick said, getting the speedo head apart is easy. Once the needle is removed unscrew the bolts and it slides right apart. The odo wheel assembly pops right out with a small screwdriver prying on the metal shaft.
That small module is the anti-slosh module. It is used inline of the fuel level sender to gauge circuit to prevent erroneous readings from fuel sloshing around. It also triggers the low fuel lamp on equipped models.
The anti-slosh module is used on MANY Ford vehicles and most are swappable. I'm using an anti-slosh from a '02 CV/GMQ cluster in my '95 Mustang cluster.
#1397085 - 02/14/08 02:01 PM Re: The Marauder Cluster Swap... [Re: dRock96Marquis]
Ezbok58a Offline
Guess I should put that back then...
I do plan on using the Marauder cluster in its entirety in the car, I just need to get that odometer thing taken care of, which I will do at 2:30.
Now, how do I pull my existing cluster out of the car?
#1397086 - 02/14/08 02:01 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
There are no volt gauge or oil pressure gauge inputs to the MM cluster, that's probably what he meant.
There is no PATS function in the -05 clusters with exception to Town Cars (98+)
#1397087 - 02/14/08 02:06 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1206416#Post1206416
BTW - reading over your posts it sounds like you want to try and swap the entire speedo head module from the stock cluster and use the MM face. DON'T do that or it won't read correctly, as the retail unit is for 120mph upper limit.
All you need to do is pop out and swap the wheel assembly. Don't mess with the circuit board or motor, they are geared the same.
Shot showing the metal shaft on the odo wheel where to pry out:
#1397101 - 02/14/08 02:14 PM Re: The Marauder Cluster Swap... [Re: dRock96Marquis]
Ezbok58a Offline
Sweet, thank you drock!
You vast panther knowledge is a truely a gift.
I don't know why he said the cluster had PATs in it then...
Maybe he didn't want to have me get charged a arm and a leg for having the car sit in the shop for hours while he figured out how to get it to work...
Edited by Ezbok58a (02/14/08 02:16 PM)
#1397109 - 02/14/08 02:22 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Uncle_Jesse Offline
Loc: Mifflinburg PA
wow those gauges are neat!
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
#1397123 - 02/14/08 02:30 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
89LTDBoy Offline
PATS is Passive AntiTheft System and the instrument cluster shouldn't have anything to do with it, the only thing that could possibly be related is on some, there is a little flashing "THEFT" light, but that's all I'm aware of. The only parts PATS needs is the PATS module and the PCM. You'll still want to swap the odometers though so you have your correct mileage.
And if the oil pressure gauge is like the one in the Explorers, it's an idiot gauge, and isn't worth bothering with anyway.
Current Vehicle-1999 Ford Explorer
#1397138 - 02/14/08 02:38 PM Re: The Marauder Cluster Swap... [Re: Uncle_Jesse]
Ezbok58a Offline
Ok, the Marauder cluster 'brain' is in my hands (away from the speedo face)
How exactly do I get the odometer part of this out of the rest of the assembly? Do I grab a set of plyers and pull the metal rod holding the odometer in place out and swap in the one from my car? Or is there a different way?
#1397269 - 02/14/08 04:46 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Ezbok58a Offline
Alright, dashboard is in dissaray, cluster is out, mileage is correct.
Prepped for needle removal
Removal of odo gear
Weee!
Try and stop me goverment! \:D I think I hear knocking...
To the car
I call shennanigans on this dashboard now...
Cluster removed
Marauder above, Sport below
Sport
Marauder
Sport (left side)
Marauder (left side)
Sport (right side)
Marauder (right side)
Now what?
I have no idea what the next step is. I hope it doesn't involve me going back to the car and working with whats left of the dashboard...
drock? P71_CrownVic? K-9Vic?
#1397275 - 02/14/08 05:01 PM Re: The Marauder Cluster Swap... [Re: Ezbok58a]
Jony Offline
wow this is going to be a good write up. off topic for one minute. why dont he just get the speedo motor to read 140 mph. seeing as i hard its in the cluster for those wanting to swap out for the mustang gt cluster. why cant you just use the MM speedo stuff and just swap it out.???
and if i have a p71 that reads 140. then i could do a direct swap seeing as speedo reads the same?
2002 P71 pursuit interceptor.
gt air box/meter,high flow exhuast,j mod,hpp rear bar,trickflow plenum/tb, msd coil packs,intake tube,gaterback belt,kyb shocks,3.73 gears t lok,
#1397306 - 02/14/08 05:28 PM Re: The Marauder Cluster Swap... [Re: Jony]
vicfan_00 Offline
Loc: Quad Cities,IL
I just did this swap 2 days ago on my car... Now you need to get back in the car with whats left of the dash and re-pin the connnectors cause some of the wires go to different places for the marauder, you will need a very small flat head screwdriver to get the wires out of the connectors and move them around.
I dont have my diagrams handy with me, but I know Derek has them on his supermotors page, basically all you have to do is look at what color goes where and If it indicaters that the marauder uses a certain color, you just move the wire to that location.
on my car it was a little harder cause its a 00. but 03 and newers are fairly simple to re wire.
You will also need a tach adapter and wire to add into the speedo cluster connector, I clipped a wire from one at the junkyard and just used that for the tach output
Jony- Yours will be a direct swap with just a re-wire and the addition of a tach adapter. It took me less than 2 hours to finish and thats including the small problem I had.... I got confused on 1 wire.
http://www.supermotors.net/17311
2000 CVPI 118K miles (6/2013). Steeda UDs,EMP Water Pump,Ported Plenum,FRPP 70MM TB,PI Intake,
PI cams,180 stat,NGK TR6IX Iridiums,3500 stall converter from Darrin,Dual Trans Coolers,
J-Mod,MMX Driveshaft,3.55 with T-lok,Full Magnaflow Exhaust,Marauder Cluster,
Console with floor shift. 14.9 with no tune.SOLD 11/14
Living vicariously through brothers 93 and 03
Currently in the garage- 2011 edge, 62 t-bird.
#1397327 - 02/14/08 05:49 PM Re: The Marauder Cluster Swap... [Re: vicfan_00]
What the hell are you doing to the dashboard? lol
Something is going to get broken or scratched like that.
Disconnect the trac (if equipped), rear defrost, and adjustable pedal (if equipped) switches from those trims and lay them down on the passenger seat, the longer one will go on the floor and just lean against the seat.
Disconnect that headlamp switch. Pull the radio out of the dash trim. It's heavy enough that if the trim falls it could twist it enough to break, so pull it out and put it on the passenger side floor mat.
Pull the dash bezel off, leave the headlamp switch in, and lay it down in the back seat.
NOW move on to re-pinning the connectors.
Here are the factory pinouts:
K9vic made a pin swap chart which will make this go a lot easier:
http://s95316603.onlinehome.us/cvpi/Speedo/Speedo-All.pdf
I use a small screwdriver to unhook the retaining clips on the connectors and an awl to unhook the terminals. Keep the awl press against the plastic clip for each terminal as you slide it out
4 registered (derekghs, lmrogp, Becker34, 1 invisible), 61 Guests and 110 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 48
a_d_a_m 47
SocalSam 43
Ponyguy 40
