#1410293 - 02/28/08 08:11 PM
[Re: Timmn1]
Loc: Knoxville TN
For the record:
1996 CV oil pressure gauge, engine unit (sender): D4AZ-9278-A (Motorcraft SW-1311) 1996 CV Oil pressure gauge, instrument panel unit: F6AZ-10883- BA
2008 Crown Vic P71 (former Sault St. Marie, Ontario PD). 2010 Crown Victoria P7B SAP (former Federal).
#1410720 - 02/29/08 07:29 AM
[Re: hlbly]
Loc: Knoxville TN
#1414396 - 03/04/08 04:37 PM
[Re: hlbly]
Loc: San Francisco
Hmm,
1995 returns one.
Collision Catalog - 1996 - Ford - Crown victoria Instrument panel, Cluster and switches, Temp gauge, W/o police package, To 2/96 - 1995-97 Mechanical - 1995-97 Mechanical $72.78 $48.04 $0.00 $48.04 Collision Catalog - 1996 - Ford - Crown victoria Instrument panel, Cluster and switches, Temp gauge, W/o police package, From 2/96 - 1995-97 Mechanical - 1995-97 Mechanical $72.78 $48.04 $0.00 $48.04 Collision Catalog - 1995 - Ford - Crown victoria Instrument panel, Cluster and switches, Temp gauge, W/o police package - 1995-97 Mechanical - 1995-97 Mechanical $61.03 $40.28 $0.00 $40.28
2001-P73 CNG 21K (now 30K)
#1414624 - 03/04/08 08:36 PM
[Re: peteinsf]
Loc: Ontario, Canada
1996 Mercury Grand Marquis GS 70mm Aviator throttle body, Professional Products ported upper plenum, STEEDA underdrive pulleys, Auto Meter tach, MSD 8mm wires, MSD coils, 180 thermostat, 17" BULLITT wheels with 245/45/ZR17 Good Year rubber, Blue Oval Industries ceramic coated headers, custom 2.25" cat-back exhaust with x-pipe, Edelbrock SDT mufflers, stainless exhaust tips, Magnaflow Hi-Flow Cats, 21mm HPP rear sway bar UPCOMING MODS:Snow tires and an oil change.
#1415406 - 03/05/08 07:44 PM
[Re: dRock96Marquis]
it's pretty illegible.....  what i can pick up is 22 may and it's either 1995 or 1996..... here's what i can make out GRAND MARQUIS EM114 200 KPH F6MF-10849-BB 22 MAY 199- that's the best i can make out. just barely.
#1418691 - 03/09/08 07:27 PM
[Re: troyco]
#1427655 - 03/19/08 11:17 AM
Loc: San Francisco
1995-2002 2003-2007? (my guess)
#1429081 - 03/21/08 12:15 AM
[Re: peteinsf]
1995-2002 2003-2007? (my guess) LX clusters also interchange so long as they are analog and not optional digital. 1992.5-1994 (1992 as well but incorrect shift patter is printed on speedo) cv for cv and gmq for gmq (different dashes) 1995-1997 cv/gmq 1998-2002 cv/gmq 2003-2005 cv/gmq The speedo head itself (not entire cluster) will swap 95-02 and it appears 03-05 as well. CVPI use 140mph head
#1429083 - 03/21/08 12:16 AM
[Re: troyco]
it's pretty illegible.....  what i can pick up is 22 may and it's either 1995 or 1996..... here's what i can make out GRAND MARQUIS EM114 200 KPH F6MF-10849-BB 22 MAY 199- that's the best i can make out. just barely. I would assume 1996, which means the external resistor delete was a mid-year change
#1429175 - 03/21/08 06:49 AM
[Re: hlbly]
Loc: Near I-80 & I-57
Strike that first item. The correct engine unit is E9SZ-9278-A or Motorcraft SW-2220. The SW-1311 is for vehicles with the electronic cluster. The Motorcraft SW-2220 is just a normally open pressure switch, whenever the oil pressure gets to a certain level, it closes. That is used with the "fake" gauge and the "real" gauge with the resistor.
#1429182 - 03/21/08 07:02 AM
[Re: troyco]
ok. i think i'm just going to find another oil pres. gauge at the wreckers with those p/n's.....my only question is what kind of wiring is required to hook up that sending unit after i install it on the engine?? If your original sending unit looks like a Motorcraft SW-2220, it has a threaded stud coming out of the top that the wire connects to, you shouldn't have to make any modifications to the wiring at all. On the newer cars, Ford changed the sending unit connector, in that case, you have to either change the connector or build an adapter.
