Page 2 of 5 < 1 2 3 4 5 >
#1433625 - 03/26/08 01:23 PM Re: Gear Swap: Did I bite off too much, went with [Re: Allen Maty]
whdahel Offline
Loc: North Bloomfield, Ohio
Now here is a guy that isn't afraid of the price of gas and the power of a V8. Thats awsome!
Sounds like all you really need is a tune a Drive shaft and your in business.
how low of gears would the aluminum D/S be good to?
02 GMQ HPP 88k miles
4th panther I have owned
no mods yet.....
My Garage: www.supermotors.net/8297
Loud pipes save lives!
#1433635 - 03/26/08 01:38 PM Re: Gear Swap: Did I bite off too much, went with [Re: whdahel]
I'd only go to 3.73, or 4.10 if you keep speeds highway or lower.
#1433772 - 03/26/08 04:50 PM Re: Gear Swap: Did I bite off too much, went with [Re: dRock96Marquis]
Mileaway Offline
Loc: Sacto. Calif.
Whiplash disclaimer come with 4.30s?
#1433796 - 03/26/08 05:21 PM Re: Gear Swap: Did I bite off too much, went with [Re: Mileaway]
natedog Offline
Loc: Bowie, MD
Wow.
2.73's to 4.30's, that's quite an impressive leap.
Absurd signature chopped.
Read the rules.
#1433846 - 03/26/08 06:13 PM Re: Gear Swap: Did I bite off too much, went with [Re: natedog]
REAL4WD Offline
Loc: Glendale, CA
I would sure say. I have 3.55s and im worried bout gas prices. haha. tell me how the 4.30 gears work. eventually i might swap my gears.
04 Crown Victoria LX Sport
95 AM General Hummer
#1433852 - 03/26/08 06:23 PM Re: Gear Swap: Did I bite off too much, went with [Re: natedog]
P71CVMAN Offline
Loc: wIScONSiN
WOW \:D I went from 3.27s to 3.73s and I needed a tune as the tranny just didn't feel the same. My 3.73s are at 2200ish @ 60MPH. I thought I had no regard for the cost of gas when I went with my 3.73s and a 93 octane tune!
Exhaust/dragstrip videos
#1433871 - 03/26/08 06:47 PM Re: Gear Swap: Did I bite off too much, went with [Re: whdahel]
JWhittaker Offline
Loc: Seekonk, Ma
Excellent, seconded! By the way does he have the lowest gear on CVN, I can't recall a lower gear in someone's car?
2002 CV LX Sport
Speed Bleeders installed with the new brakes!10/07-brakes 85K at the time
http://www.flickr.com/photos/[email protected]/2382004080/
#1433916 - 03/26/08 07:44 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: Al]
observer Offline
very interesting ratio
what rpms are you hitting at various mphs
you are geared lower than many 1 ton trucks
1997 P71 145K miles
#1433932 - 03/26/08 07:57 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: observer]
95merckid Offline
Loc: wichita
he's got lower gears than a OTR Truck they only come with 4.11 altho id like to see a vic with 4.56 gears
#1434068 - 03/26/08 10:46 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: 95merckid]
autotech57103 Offline
Loc: Sioux Falls, SD
4.30 is a CV is insane. They would be good for running 1/4 miles and if you wanted to pull something the size of a mobile home. 4.10 in a pickup are more reasonable because they have a taller tire thus more mph per rpm of the axleshaft. I useto drive a 89 F250 without overdrive and it would turn 3000 rpms at 60mph so the 4.30 ratio in the CV would be even worse. So ballpark rpm of the driveshaft at 85 would be in the neighborhood of 4500. With a .70 OD ratio that would put the engine rpm a little over 3100. Hope you add some protection for yourself from the driveshaft. It will be a murder weapon when it flys apart and goes thru the floor and out the roof.
#1434110 - 03/26/08 11:20 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: autotech57103]
MountainDewSVT Offline
Seriously people, is the driveshaft that big of a problem on crown vics? I don't understand why it would be. I've pushed my Cobra to 160mph several times and it holds up fine, even at 5500rpm in 4th (which is about 120 if I remember correctly). Seriously, is there something I'm missing??
#1434113 - 03/26/08 11:21 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: MountainDewSVT]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
YES it's about 2 feet longer than a stang shaft.
#1434123 - 03/26/08 11:27 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: Quickvic30]
Which is what I assume causes flexing at higher RPMs?
#1434134 - 03/26/08 11:35 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: MountainDewSVT]
Quickvic30 Offline
Just watchin
Yes sir \:\)
#1434173 - 03/27/08 12:10 AM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: MountainDewSVT]
Big_Bad_Joe Offline
Loc: Rochester NY
yup this aint no mustang.. so get those thoughts out of your head...
as far as pulling the quarter mile.. no way he will pull those gears on a stock motor...
he hasnt got enough motor
Underdrives from ADTR.net
Given to DG in Ohio
0 registered (), 32 Guests and 269 Spiders online.
bluejay_32 129
Old_Guy_Stu 91
Ponyguy 69
Moby_Vic 63
a_d_a_m 55
DudeAbides 47
Dmblanch 47
JeffBoudah 45
GM_Guy 33
Davidzq 33
