Page 1 of 5 1 2 3 4 5 >
#1432941 - 03/25/08 06:35 PM Gear Swap: Did I bite off too much, went with 4.30
Al Offline
Loc: So Cal
My 01 P71 was a slug, I think it had some kind of Highway option or something. 2.73's were in it. I had the 4.30's installed by a proffesional so I am not worried about them wearing out prematurely. What I am worried about is my transmission, however, after about 250 miles my O/D Off light started to blink. I like the acceleration the 4.30's provide, but is it going to tear apart my car? I get a noise around 85mph, but attribute that to brand new gears, hopefully after a week or two that will go away, or else I will be taking it back for service under warranty. Anyhow, I would like to ask for some opinions from the old timers about tall gears in these CV's.
Thanks,
Al...
If you don't know where your going, how do you know when you get there...
03 P71 CNG VIC
05 Mustang GT Convertible (Told the wife it was for her)
95 Bronco
96 Winnebago Adventurer
1373 Cubic Inches of FORD at my command
#1432946 - 03/25/08 06:40 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: Al]
kustomizingkid Offline
Loc: Minnesota
Did you get a tune when you got the new gears? It is recomended to get a tune if you go more than 2 steps, 2.73, 3.08, 3.27, 3.55, 3.73, 4.10, 4.30.... you went a couple more than two so I would have to say a tune could really help, your car is a bit confused right now.
Edited by kustomizingkid (03/25/08 06:40 PM)
2000 CVPI 121,000 miles
#1432964 - 03/25/08 06:53 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: kustomizingkid]
Dan The Vic Man Offline
Loc: Coon Rapids MN
Ah the noise you are hearing is driveshaft noise,you could try and get a MMC driveshaft from a 99 cvpi to try and make it not so noisey, i would have gone with 4:10s the highest gear. Usually when the o/d light is flashing it means you have a tranny code, could be a smoked od band, a faulty electrical part, many things.
2012 Ford F150 Ecoboost
RIP 99 CVPI
#1432982 - 03/25/08 07:09 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: Dan The Vic Man]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
4.30's holy cows \:D
You might want to think about the forced lube tailshaft mod also. i can't imagine what that would be like with 4.30's \:\)
#1432992 - 03/25/08 07:25 PM Re: Gear Swap: Did I bite off too much, went with 4.30 [Re: Quickvic30]
tackleberry Offline
Loc: Las Vegas
say goodbye to gas mileage lol
#1432999 - 03/25/08 07:32 PM Re: Gear Swap: Did I bite off too much, went with [Re: tackleberry]
P71_CrownVic Offline
4.30???
You can probably do a brake stand just by dropping it in drive and stepping on the brake.
I can't help my low intelligence.
-Moby Vic
"I rather be hated for telling the truth, than loved for telling a lie".
#1433014 - 03/25/08 07:54 PM Re: Gear Swap: Did I bite off too much, went with [Re: P71_CrownVic]
Go to autozone and have it scanned (free) and post up the code.
You will need a relfash with that much change in axle ratio.
3.27 is standard for CVPI. Your real axle may have been swapped in favor of a normal retail 2.73 axle because of a problem of better mileage.
The noise you hear at 85mph is probably your drive shaft. The rotational speed traveling that fast with 4.30s must be VERY high. Try to keep speeds below 90mph, and cruising speed below 75. Look into forced lube modification and an AMMC driveshaft IS A MUST.
#1433022 - 03/25/08 08:02 PM Re: Gear Swap: Did I bite off too much, went with [Re: dRock96Marquis]
TechnoWeenie Offline
Loc: The perimeter
I ditched 3.27's for 2.73's, even with only one 'jump' the shifting is noticeably off, I can't even imagine what yours are...
#1433115 - 03/25/08 09:09 PM Re: Gear Swap: Did I bite off too much, went with [Re: TechnoWeenie]
SilverSport Offline
Loc: Lower Hudson Valley, NY
If I were you I would unistall those gears ASAP. Our SOHC engines do not favor those very high gears, they are much more suited to the DOHC with a stick (Cobra Mustangs). I think most Marauder guys go with 4.10's and even those are too high for the SOHC motors. I think the general consensous is to gear no higher than 3.73's for street driven Vics and even then I would not put that much gear in a stock motor. As the others have mentioned, a custom tune for the trans is mandatory for a major gear change.
04 Crown Vic LX Sport
Infinity Reference 6x8's/XM Radio/bc4ever dead pedal/BH1976 headlamp harness/Phillips Xtreme Power 9007
Addco Sway Bars/KYB PI struts/Moog PI front springs/Gabriel PI shocks/Mustang 17x8 split spoke
"Simon Bar Sinister"
#1433130 - 03/25/08 09:27 PM Re: Gear Swap: Did I bite off too much, went with [Re: SilverSport]
Loc: Minnesota
I think that much gear would be awesome, if you were willing to deal with the gas mileage and cruise rpms. He just needs a good tune and all will be well again.
#1433328 - 03/26/08 12:10 AM Re: Gear Swap: Did I bite off too much, went with [Re: kustomizingkid]
PantherP73 Offline
Relocated Yankee
Loc: Greenville, South Carolina
I would imagine he's over 2300 rpm or so with those gears...
Just out of curiosity, why would you go so high? That's hard on the engine and probably everything else.
2015 Kia Forte
2016 Hyundai Elantra
Someday I will have real cars again.
#1433377 - 03/26/08 01:05 AM Re: Gear Swap: Did I bite off too much, went with [Re: PantherP73]
jaybird Offline
Loc: San Jose Ca.
man thats quick off the line huh? i have 3.55 stck and i wonder what 3.73 were like 4.30 wow must boogie up to 60 then it gets loud? It may harm your engine w/o said tune ASAP
sounds like fun though..Enjoy & post a burnout Pic/Video
2000 CV LX HPP Loaded 3.55 RAR SOLD @ 191k MILES / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
#1433383 - 03/26/08 01:15 AM Re: Gear Swap: Did I bite off too much, went with [Re: jaybird]
SteelCityMarquis Offline
Fomerly 93MGMGS
Loc: Pittsburgh Area
Holy Jump!!!! Better get that forced lube, AMMX, and a tune ASAP!
If you decide to keep definitly post a pic/video!
2002 Mercury Grand Marquis LS. - 80k GF's Daily Driver
1991 Honda Accord LX Wagon 5 Speed - 258k My Daily Driver
1980 Oldsmobile Delta 88 Royal Diesel - 96k
#1433384 - 03/26/08 01:18 AM Re: Gear Swap: Did I bite off too much, went with [Re: jaybird]
96bluvic Offline
Loc: southeastern WI
its not gona harm the engine, just get a proper tune, the MMC driveshaft and maybe a loop.
did you correct the speedo.
I bet it feels nice, these cars need all the gearing from a stop, 4.30's arent high enough....
Back in with an 07 CVPI
#1433544 - 03/26/08 10:34 AM Re: Gear Swap: Did I bite off too much, went with [Re: 96bluvic]
Allen Maty Offline
Loc: Southern California
You should get a scangaugeII and see what RPM your driveshaft is spinning. In fact does anyone know what the resonate frequency (in RPM) of a steel or aluminum drivshaft is?
If you knew then you could read it right off your scangauge and avoid that speed.
'99 Crown Victoria LX HPP w/ Digi-Dash 11/2001-12/2011 Sold! Still on road with 219K miles as of 1/15
2012 Mustang GT Premium 5.0 6 Speed Man /w 3.73 LSD. wink
For Sale: Maurader Air Intake, Zip tube & 80mm MAF with matching BOC Custom Tune Chip and ECU computer (will fit '99-'00).
7 registered (bluejay_32, DudeAbides, RiotRN, Clark, Davidzq, 1 invisible), 66 Guests and 233 Spiders online.
bluejay_32 208
a_d_a_m 130
DudeAbides 123
CrystalPistol 118
Old_Guy_Stu 115
Moby_Vic 80
ford05 60
Ponyguy 56
Warped9 56
RF_Overlord 49
