#1427858 - 03/19/08 04:00 PM Looking for...
Sonders Offline
Loc: Laval, Quebec, Canada
A shop in laval and montreal that will change my open diff. to a trak-lock for a good price.
Thanks.
2006 Ford Crown Victoria P71
#1429028 - 03/20/08 11:11 PM Re: Looking for... [Re: Sonders]
there is a place in st-jerome who did my friends 3.73 rar and the same guy will do my diff this summer.
He is an experienced mechanic who used to run his mustang on the 1/4 mile in the low 12 he knows what he is doing and as i had the chance to work with him i know he is doing amazing work.
it really worth it to come up there.
comming back this fall
#1429618 - 03/21/08 05:12 PM Re: Looking for... [Re: 2004_p71]
Sonders Offline
how much does he charge? labour and all.
#1433874 - 03/26/08 06:51 PM Re: Looking for... [Re: Sonders]
Sonders Offline
Do you have an idea of how much?
#1434560 - 03/27/08 01:48 PM Re: Looking for... [Re: Sonders]
pretty good question....i'll ask him..
sorry for being slow to respond i forgot abouth your question
#1449005 - 04/13/08 04:08 PM Re: Looking for... [Re: 2004_p71]
Sonders Offline
Did u ask him yet?
#1450517 - 04/15/08 11:59 AM Re: Looking for... [Re: Sonders]
sorry for my late reply ..i dont watch this tread often
should be around 275 for a gear swap
Edited by 2004_p71 (04/15/08 12:00 PM)
#1452714 - 04/17/08 09:44 PM Re: Looking for... [Re: 2004_p71]
Check your door tag to see if you have the limited slip axle cause the clutch can wear to the point that the axle is unlock.
If you have a limited slip and only have to change the clutch it might be less expensive.
In the case that you have an open rear axle you have to get another cage who is made to have clutch inside as yours wasnt designed to be locked....that is geting expensive.
#1453626 - 04/19/08 02:06 AM Re: Looking for... [Re: 2004_p71]
Sonders Offline
I used to have a posi-traction (limited slip) but i guess somthing happend to it and it got swaped out, and now I have a open diff.
So its 275, just to change the diff right?
#1455187 - 04/21/08 09:26 AM Re: Looking for... [Re: Sonders]
im pretty sure it's still in but the clutches are dead.
275 is for the swap of the gears wich invole even more work than just replacing the clutch as the gears have to be perfecly allingned.
So the mechanic will only have to remove the cage and changes the clutches and put everything back . so there is less work involve but with the clutches the total should come under 275 but i,m not sure
#1460570 - 04/27/08 04:24 PM Re: Looking for... [Re: 2004_p71]
Sonders Offline
Nope, I already checked it. They replaced my old diff with this one, which is an open diff.
Moderator:  a_d_a_m
0 registered (), 42 Guests and 67 Spiders online.
bluejay_32 112
JeffBoudah 89
Armada Master 74
Moby_Vic 73
Old_Guy_Stu 69
Dmblanch 56
DudeAbides 53
a_d_a_m 47
SocalSam 41
