#1495135 - 06/11/08 02:15 PM
20x9 with 30mm offset and 255/35/20's?
Hey I've got a 1999 Grand Marquis LS and I have some 20x9" rims with a 30mm offset I want to put on my car. I ordered some General Exclaim UHP 255/35/20's from tirerack but a representative from tirerack called and said he wasn't sure they were going to fit without rubbing. Can anyone help me out? Have any of you guys put 20's on a 99 Grand Marquis? My tirerack order is on hold right now so I need to find out asap.
#1495143 - 06/11/08 02:23 PM
Re: 20x9 with 30mm offset and 255/35/20's?
[Re: themerc]
Insert Title Here
The new tire is almost exactly the same dia. as the factory tires (~.50" bigger), and only ~1" wider, given the 30mm offset you should be fine. the back tires will definitely be ok but the fronts may rub the fenders on sharp turns. Considering people have used 1" spacers with no problems you may be ok.
Disclaimer: I have zero experience with large rims and low profile tires so you may want a second opinion before you spend your money. Just giving an opinion based on information gathered from teh CVN.
RebelVic2000:"Remember, Panthers are mostly owned by old people who don't understand internet talk."  2000 P71 100k mis. (DC-Metro unit 333)  PI intake, Teh MZT, Remote start w/ keyless entry, Heinous RCAs, Bilsteins 1995 Dodge Ram 1500 4x4 318 5spd. 180k mis. SJ class II 3", Accel coil, Hughes Engines plenum kit, 2-1/2" stainless exaust, free flow cat, flowmaster 40 series
#1495151 - 06/11/08 02:29 PM
[Re: mblazakep]
[email protected]
Loc: ATL
actually the problem is the rims or the tires may rub the upper ball joint if the offset and width is to much. Do a google search for tire calcs and put the factory specs in and then go from there. I use this one http://www.wheelsmaster.com/rt_specs.jsp
#1495163 - 06/11/08 02:39 PM
[Re: 98VicP71]
[email protected]
Loc: ATL
by th calculation I see using that tool You would want a 1" spacer on the fronts for clearance.
The 20" rims are
1.1" wider (tire) .4" taller 2" more backspace with that offset which is why you would want to get a 1" spacer if not 2" spacer to reduce that so it is the same as the factory backspace of 4.2"
#1495182 - 06/11/08 02:50 PM
[Re: 98VicP71]
The guy from tirerack said my stock offset is 35mm? Is it 35mm or 6mm? Those are my rims.
#1495184 - 06/11/08 02:54 PM
[Re: themerc]
[email protected]
Loc: ATL
for a 99 it should be 6mm 03+ is the higher offset of 40-50mm refer to This
#1495197 - 06/11/08 03:11 PM
[Re: 98VicP71]
Hm, well they gave me 8mm spacers for free. But either way, I should be fine with those tires with the right spacers right? I'd rather not order the 245/35/20's.
#1495283 - 06/11/08 05:14 PM
[Re: Bangster]
Well I ended up changing the tires to the 245/35/20 Kumho Ecsta SPT's. We put the rim on the car without the tire and it looked like it would be okay. I'll find out on Friday when the tires come in. I'll post up pictures.
#1495610 - 06/11/08 11:50 PM
[Re: Bangster]
#1498626 - 06/16/08 10:19 PM
[Re: themerc]
Loc: Las Vegas
at least it aint donked
#1499535 - 06/18/08 06:47 AM
[Re: musclemarquis]
Loc: Colorado Springs, CO
Why didn't you get a wheel with proper spacing to start with? It'd look better if they were farther out.
 '92 P74 w/5.0 HO/GT-40P/T5 swap and bolt ons. '02 CVPI cut front springs/swaybar/brake swap, rear HPP bags/sway. [email protected], 2.4 60', 4700' elevation, 5500' DA.
3 registered (hot__box, Old_Guy_Stu, 1 invisible),
58
259
