Page 1 of 4 1 2 3 4 >
#1599656 - 10/31/08 02:49 PM Lifters ticking.
Spook Offline
Loc: Missouri
Hey all, after my oil change I noticed a slight ticking. Sounds like lifters. I used some Lucas treatment and 10W 40 weight oil. It's not real loud and some people can't even hear it. My question is this. Is it normal? Or, what should I do? Would hate to redo an oil change...lol
Also, if it is the lifters, I hear roller rockers are good. How bad of an install?
Spook
#1599666 - 10/31/08 03:00 PM Re: Lifters ticking. [Re: Spook]
Crownvicman289 Offline
Loc: Colorado Springs, CO
What do you drive? Box's lifters are easily adjustable but I don't know about the modulars'. I'm sure they are somehow, maybe you shim them or something.
[email protected], 2.4 60', 4700' elevation, 5500' DA.
#1599678 - 10/31/08 03:08 PM Re: Lifters ticking. [Re: Crownvicman289]
04RauderDTR Offline
Loc: PA
Its injector tick, and i think you should be running 5W-20, unless the 2v is different than the 4v in oil requirement wise.
Ryan #2
2004 Mercury Mcgruber Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, Tremec T-56 Magnum, 4.10's, Stainless Works LT's, 2.5" Exhaust W/ Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder Stainless Works LT's, Stainless Works catback, Mo's tune, JLT
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
2000 BMW M5 Evolve CAI + AlphaN Tune, Dinan strut bar + rear swaybar, Stoptech ST40BBK, UUC Shifter
2016 Ford Mustang GT Performance Pack
#1599693 - 10/31/08 03:23 PM Re: Lifters ticking. [Re: 04RauderDTR]
Mileaway Offline
Loc: Sacto. Calif.
You have a somewhat common complaint. I ignore the tick. It's been doin it off and on for 6 years now so.. More so right after an oil change too.- Not sure why?
What year panther do you have?
Put it where others do - below your text area and where your car picture would be if you had one .
Then we won't be asking you that question.\:\)
Click on My Stuff and scroll down to My Profile click on that and then scroll down to My Signature and type it /enter it-year,make,model
Edited by Mileaway (10/31/08 03:41 PM)
#1599730 - 10/31/08 04:09 PM Re: Lifters ticking. [Re: Mileaway]
04RauderDTR Offline
Loc: PA
he has a 99 P71
Ryan #2
#1599854 - 10/31/08 06:39 PM Re: Lifters ticking. [Re: 04RauderDTR]
Spook Offline
Loc: Missouri
Thanks guys. I will definitely put the info in. Man, I need a pic!! OK, about the 2v and 4v, not sure what you mean by that. Now, in the winter, you want thinner weight oil right? Do you all let your car warm up before you go. I have been. When I had a TT ZX, I always did. Also, you guys are awesome in responding. Thanks.
Spook
#1600634 - 11/01/08 01:09 PM Re: Lifters ticking. [Re: Spook]
Mileaway Offline
Loc: Sacto. Calif.
I see...a 99. Cool. I do let it warm up due to somewhat high idling. Maybe 2 min is all. The rear end will clunk if I put it in reverse without letting it idle some. Might be normal. Might be the rear u-joint ? IDK. Keeps going and snd going though. Just have to baby ir a little sometimes like the cold startup. The mechanics and tire/oil/lube guys just jump in and put it in gear before the idle comes dowm..period. Can't possibly make them understand the quirks of a Vic so..forgetaboutit. \:\)
#1600778 - 11/01/08 04:44 PM Re: Lifters ticking. [Re: Mileaway]
mrbear5300 Offline
professional grade
Loc: BUF
Put a new Motorcraft filter in. Some filters have inferior anti-drainback valves. Even the Motorcraft units can be defective as well.
#1601139 - 11/01/08 10:56 PM Re: Lifters ticking. [Re: mrbear5300]
You should be using 5w-30. You can use 10w-30 if it doesn't touch freezing, but seeing as you are in WV use 5w-30.
The injectors tick normally, but it should not be audible with the hood closed.
If the sound is almost like a sewing machine and matches engine rpm your timing chain guides may be shot. The debris can actually clog the oil pickup, dropping oil pressure and killing the engine.
Try to pinpoint the noise better.
#1601395 - 11/02/08 09:38 AM Re: Lifters ticking. [Re: dRock96Marquis]
Fordiesel69 Offline
Loc: Erie, PA
DUMP THE OIL!!!!!!!!!
10w-40 is a total waste of 0.5 MPG and a waste period. On top of lucas, im sure you have a 20w-50 mixture now. There is nothing gained by using it in a modern engine. If you have winter in your area, dump it and go with 5w-20 or 5w-30, whichever will make you sleep better. Don;t get caught up in the 20 vs 30 debate as ford has approved both for your engine. Use what you want to.
Also you need to run a motorcraft FL-820s or a Wix 51372. Other filters have crappy rubber ADV that will cause a tick on startup.
The 4.6's are noisy on startup, all mine are slightly more audiable when cold and every one I have ever owned made some kind of noise. If is not very noticable but I can tell.
-'14 Fusion S - 160K
#1601420 - 11/02/08 10:21 AM Re: Lifters ticking. [Re: Fordiesel69]
TheDriver959 Offline
Loc: Oshawa, ON
Mine ticks...always has, ever since I got it. Everyone keeps asking if it's lifter tick and if I should have it checked. I tell them it's my injectors, and that their Hondas do it too. They would just need to put an actual muffler on the exhaust to hear it first. All OHC engines, the 4.6 included, are noisy engines on startup. Once the revs come down, it's fine.
2004 Ford Crown Victoria Police Interceptor
LX Sport Console & Floor Shifter, Gentex Electrochromic Mirror w/compass, Marauder Cluster, Speed Control w/leather wheel, LED turn signals, HID headlights (projectors coming), EATC (DIY, in progress), Marauder corners, Rewired DRL, Rewired turn signals, Maraudered headlights, Grille Mounted Driving Lights, Bullitt Wheels, Pirelli Tires and a Custom Ram Air System. More to come!
#1601461 - 11/02/08 11:01 AM Re: Lifters ticking. [Re: TheDriver959]
BigJon Offline
you can do some serious damage running too heavy of an oil. 5w-30 for me.
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#1601570 - 11/02/08 12:40 PM Re: Lifters ticking. [Re: BigJon]
Spook Offline
Loc: Missouri
Great info guys!! I will definitely use 5w-30 next oil change and use the motorcraft or wix filter.
Flight of the bumble bees...lol
Spook
Edited by Spook (11/02/08 12:46 PM)
#1601594 - 11/02/08 01:21 PM Re: Lifters ticking. [Re: Spook]
cfrank Offline
Loc: North Florida
The 10-40w you used was too heavy of an oil and on top of that you used lucas oil treatment. People claim that it is a miracle product but all it does is thicken up your oil to hide engine noises. So on top of using 10-40w it has been thickened by the lucas so it is probably more like 20-50w like fordiesel69 says and being in WV you really need the reccomended 5-20w, so i would change the oil agian and use the reccomended weight of oil and go from there on pinpointing your ticking noise. For some reason ford seems to vary between 5-20w and 5-30w for reccomended oil weight, on my 2001 mustang gt it calls for 5-20w and my 2000 crown vic calls for 5-30w. But i checked and your car calls for 5-20w.
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1604985 - 11/05/08 02:47 PM Re: Lifters ticking. [Re: cfrank]
Spook Offline
Loc: Missouri
5-20w! Damn, OK. I bought one of those Haynes manuals and it calls for 10w-30 between 0 degrees F and 100+ F. For cold weather below 0 degrees F, it says 5w-30.
This is what confuses me. All these damn choices...lol
Spook
6 registered (95TownCar, 02_LSE, Lance01, f00barbob, quedog07, 1 invisible), 46 Guests and 241 Spiders online.
bluejay_32 185
a_d_a_m 147
Old_Guy_Stu 130
DudeAbides 87
Ponyguy 66
CrystalPistol 47
Moby_Vic 42
LTC_Dave 42
Davidzq 38
Bangster 35
