Page 1 of 4 1 2 3 4 >
#1599656 - 10/31/08 02:49 PM Lifters ticking.
Spook Offline
Loc: Missouri
Hey all, after my oil change I noticed a slight ticking. Sounds like lifters. I used some Lucas treatment and 10W 40 weight oil. It's not real loud and some people can't even hear it. My question is this. Is it normal? Or, what should I do? Would hate to redo an oil change...lol
Also, if it is the lifters, I hear roller rockers are good. How bad of an install?
Spook
#1599666 - 10/31/08 03:00 PM Re: Lifters ticking. [Re: Spook]
Crownvicman289 Offline
Loc: Colorado Springs, CO
What do you drive? Box's lifters are easily adjustable but I don't know about the modulars'. I'm sure they are somehow, maybe you shim them or something.
[email protected], 2.4 60', 4700' elevation, 5500' DA.
#1599678 - 10/31/08 03:08 PM Re: Lifters ticking. [Re: Crownvicman289]
04RauderDTR Offline
Loc: PA
Its injector tick, and i think you should be running 5W-20, unless the 2v is different than the 4v in oil requirement wise.
Ryan #2
2004 Mercury Mcgruber Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, Tremec T-56 Magnum, 4.10's, Stainless Works LT's, 2.5" Exhaust W/ Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder Stainless Works LT's, Stainless Works catback, Mo's tune, JLT
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
2000 BMW M5 Evolve CAI + AlphaN Tune, Dinan strut bar + rear swaybar, Stoptech ST40BBK, UUC Shifter
2016 Ford Mustang GT Performance Pack
#1599693 - 10/31/08 03:23 PM Re: Lifters ticking. [Re: 04RauderDTR]
Mileaway Offline
Loc: Sacto. Calif.
You have a somewhat common complaint. I ignore the tick. It's been doin it off and on for 6 years now so.. More so right after an oil change too.- Not sure why?
What year panther do you have?
Put it where others do - below your text area and where your car picture would be if you had one .
Then we won't be asking you that question.\:\)
Click on My Stuff and scroll down to My Profile click on that and then scroll down to My Signature and type it /enter it-year,make,model
Edited by Mileaway (10/31/08 03:41 PM)
#1599730 - 10/31/08 04:09 PM Re: Lifters ticking. [Re: Mileaway]
04RauderDTR Offline
Loc: PA
he has a 99 P71
Ryan #2
#1599854 - 10/31/08 06:39 PM Re: Lifters ticking. [Re: 04RauderDTR]
Spook Offline
Loc: Missouri
Thanks guys. I will definitely put the info in. Man, I need a pic!! OK, about the 2v and 4v, not sure what you mean by that. Now, in the winter, you want thinner weight oil right? Do you all let your car warm up before you go. I have been. When I had a TT ZX, I always did. Also, you guys are awesome in responding. Thanks.
Spook
#1600634 - 11/01/08 01:09 PM Re: Lifters ticking. [Re: Spook]
Mileaway Offline
Loc: Sacto. Calif.
I see...a 99. Cool. I do let it warm up due to somewhat high idling. Maybe 2 min is all. The rear end will clunk if I put it in reverse without letting it idle some. Might be normal. Might be the rear u-joint ? IDK. Keeps going and snd going though. Just have to baby ir a little sometimes like the cold startup. The mechanics and tire/oil/lube guys just jump in and put it in gear before the idle comes dowm..period. Can't possibly make them understand the quirks of a Vic so..forgetaboutit. \:\)
#1600778 - 11/01/08 04:44 PM Re: Lifters ticking. [Re: Mileaway]
mrbear5300 Offline
professional grade
Loc: BUF
Put a new Motorcraft filter in. Some filters have inferior anti-drainback valves. Even the Motorcraft units can be defective as well.
#1601139 - 11/01/08 10:56 PM Re: Lifters ticking. [Re: mrbear5300]
You should be using 5w-30. You can use 10w-30 if it doesn't touch freezing, but seeing as you are in WV use 5w-30.
The injectors tick normally, but it should not be audible with the hood closed.
If the sound is almost like a sewing machine and matches engine rpm your timing chain guides may be shot. The debris can actually clog the oil pickup, dropping oil pressure and killing the engine.
Try to pinpoint the noise better.
#1601395 - 11/02/08 09:38 AM Re: Lifters ticking. [Re: dRock96Marquis]
Fordiesel69 Offline
Loc: Erie, PA
DUMP THE OIL!!!!!!!!!
10w-40 is a total waste of 0.5 MPG and a waste period. On top of lucas, im sure you have a 20w-50 mixture now. There is nothing gained by using it in a modern engine. If you have winter in your area, dump it and go with 5w-20 or 5w-30, whichever will make you sleep better. Don;t get caught up in the 20 vs 30 debate as ford has approved both for your engine. Use what you want to.
Also you need to run a motorcraft FL-820s or a Wix 51372. Other filters have crappy rubber ADV that will cause a tick on startup.
The 4.6's are noisy on startup, all mine are slightly more audiable when cold and every one I have ever owned made some kind of noise. If is not very noticable but I can tell.
-'14 Fusion S - 160K
#1601420 - 11/02/08 10:21 AM Re: Lifters ticking. [Re: Fordiesel69]
TheDriver959 Offline
Loc: Oshawa, ON
Mine ticks...always has, ever since I got it. Everyone keeps asking if it's lifter tick and if I should have it checked. I tell them it's my injectors, and that their Hondas do it too. They would just need to put an actual muffler on the exhaust to hear it first. All OHC engines, the 4.6 included, are noisy engines on startup. Once the revs come down, it's fine.
2004 Ford Crown Victoria Police Interceptor
LX Sport Console & Floor Shifter, Gentex Electrochromic Mirror w/compass, Marauder Cluster, Speed Control w/leather wheel, LED turn signals, HID headlights (projectors coming), EATC (DIY, in progress), Marauder corners, Rewired DRL, Rewired turn signals, Maraudered headlights, Grille Mounted Driving Lights, Bullitt Wheels, Pirelli Tires and a Custom Ram Air System. More to come!
#1601461 - 11/02/08 11:01 AM Re: Lifters ticking. [Re: TheDriver959]
BigJon Offline
you can do some serious damage running too heavy of an oil. 5w-30 for me.
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#1601570 - 11/02/08 12:40 PM Re: Lifters ticking. [Re: BigJon]
Spook Offline
Loc: Missouri
Great info guys!! I will definitely use 5w-30 next oil change and use the motorcraft or wix filter.
Flight of the bumble bees...lol
Spook
Edited by Spook (11/02/08 12:46 PM)
#1601594 - 11/02/08 01:21 PM Re: Lifters ticking. [Re: Spook]
cfrank Offline
Loc: North Florida
The 10-40w you used was too heavy of an oil and on top of that you used lucas oil treatment. People claim that it is a miracle product but all it does is thicken up your oil to hide engine noises. So on top of using 10-40w it has been thickened by the lucas so it is probably more like 20-50w like fordiesel69 says and being in WV you really need the reccomended 5-20w, so i would change the oil agian and use the reccomended weight of oil and go from there on pinpointing your ticking noise. For some reason ford seems to vary between 5-20w and 5-30w for reccomended oil weight, on my 2001 mustang gt it calls for 5-20w and my 2000 crown vic calls for 5-30w. But i checked and your car calls for 5-20w.
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1604985 - 11/05/08 02:47 PM Re: Lifters ticking. [Re: cfrank]
Spook Offline
Loc: Missouri
5-20w! Damn, OK. I bought one of those Haynes manuals and it calls for 10w-30 between 0 degrees F and 100+ F. For cold weather below 0 degrees F, it says 5w-30.
This is what confuses me. All these damn choices...lol
Spook
#1604993 - 11/05/08 03:04 PM Re: Lifters ticking. [Re: Spook]
See if this makes it more clear:
What your manual told you was correct for the year your car was made. Since then (2001, IIRC) Ford issued a TSB allowing the use of 5W-20 in many earlier motors, including yours. So the short answer is you can use 10W-30, 5W-30, or 5W-20 without worry. In your climate, 5W-30 and 5W-20 would be the recommended choices. I also agree with the posters comments ^^^ about using a Motorcraft, WIX or NAPA Gold filter.
As far as your 2V-4V question, it means 2-valve or 4-valve (per cylinder)...you have a 2-valve. The 2V is also commonly referred to as a SOHC (Single OverHead Cam) while the 4V is called a DOHC (Double OverHead Cam).
Edited by RF_Overlord (11/05/08 03:08 PM)
#1604995 - 11/05/08 03:07 PM Re: Lifters ticking. [Re: Spook]
Nomad8326 Offline
Loc: Ohio
I never liked those haynes manuals. Crappy photos and very vaguely written most of the time.
I ordered a set of Ford manuals for my CVPI $30
#1605061 - 11/05/08 04:24 PM Re: Lifters ticking. [Re: Spook]
battyice Offline
Loc: Northern, NY
Spook
Your engine doesn't have lifters, it has hydraulic lash adjusters and roller cam followers (which look a lot like a roller rocker). Here is a picture. The factory setup is very durable and should last a long time with proper maintenance.
2001 Grand Marquis
#1605345 - 11/05/08 08:21 PM Re: Lifters ticking. [Re: battyice]
Spook Offline
Loc: Missouri
Guys, thanks so much. I'm learning mounds of information here. Next oil change, I will be using the proper stuff!!
Spook
#1606272 - 11/06/08 07:54 PM Re: Lifters ticking. [Re: Spook]
Fordiesel69 Offline
Loc: Erie, PA
Spook,
If you had just put in 10w-40 all by itself, I would say wait till next oil change. However being you used lucas with it, your oil is way to thick for saftey. The wear on startup is going to be considerable. Dump it now for a lighter weight.
Running too thick of oil will allow your oil filter to run in bypass mode very frequently. This, depending on the design of the filter, can case a lot of the particulate trapped in the filter to go directly into your oil passages. If it is a cheapo filter, the material itself can collapse and then you will not even have a filter anymore. You will have a mini tin can acting as a surge tank.
I vote for dumping it out now before the weather gets cold. Your starter, batteries, fuel economy, and engine will all thank you.
#1606699 - 11/07/08 11:05 AM Re: Lifters ticking. [Re: Fordiesel69]
P71CVMAN Offline
Loc: wIScONSiN
I noticed what I thought was injector ticking with my hood closed once and it turned out to be one of my spark plugs was a little loose...not cool! I could actually feel a heavier pulsation on the top of the coil then the rest...maybe worth a quick feel. \:\)
Exhaust/dragstrip videos
#1608869 - 11/09/08 09:49 PM Re: Lifters ticking. [Re: P71CVMAN]
moondog Offline
Loc: East Central IL
I started hearing that after I changed oil. Was using Mobil 1 5w20 and no noise, then switched to Royal Purple 5w30 and hearing tick on cold startup. Not sure if that's it or cuz of colder weather, but I'm switching back to see how she does.
2002 Crown Victoria HPP
P71 grille
Magnaflow mufflers with Marauder tips
Clear corners
Continental Shifter/Marauder Console
#1615353 - 11/16/08 09:10 PM Re: Lifters ticking. [Re: moondog]
Spook Offline
Loc: Missouri
Well, the thing is, when I started the car up at the auction place, there was no tick. Only after the oil change did it do that.
Like I said before, I just let the car warm up. I just hate to think of the damage it's doing while ticking.
Lastly, this may be a stupid question. Keeping the p71 a p71 on replacement parts, is there specific parts you need to buy? I don't want to replace stuff on the car that is less then Police Interceptor quality.
Also, I have the Flowmasters on, what is the next upgrade I should do? This is related to performance or just anything I should know. i.e. Spark plugs, wires etc.
Spook
#1615429 - 11/16/08 10:22 PM Re: Lifters ticking. [Re: Spook]
luv-my-2002-p71 Offline
Loc: New York
Spook
I'd recommend 0w-20 Amsoil and a motorcraft filter. 10-40 oil is too thick. Our cars have overhead cams, the oil must be thin enough to slpash easliy on the cams. 10-40 when cold is way too thick. You are grinding cams everytime you start it.
Ticking can also be your timing chains eating into the tensioners.
How many miles?
#1615477 - 11/16/08 10:58 PM Re: Lifters ticking. [Re: luv-my-2002-p71]
ford05 Offline
Loc: New Jersey
i get some king of ticking only when accelarating. What can that be?
#1615514 - 11/17/08 12:00 AM Re: Lifters ticking. [Re: ford05]
P71CVMAN Offline
Loc: wIScONSiN
^Leaky exhaust manifold/gasket?
Here is a video clip I found of really bad timing chain/tensioner noise on a 4.6 Mustang, in case someone was interested in what it will sound like:
http://www.youtube.com/watch?v=R0tBoYw_Pow&NR=1
#1615834 - 11/17/08 01:41 PM Re: Lifters ticking. [Re: ford05]
Mileaway Offline
Loc: Sacto. Calif.
That would be pinging no doubt/ different deal entirely. What octane do you use. Hows the cooling system? What's the mileage? What temp thermst?
#1615850 - 11/17/08 02:06 PM Re: Lifters ticking. [Re: Mileaway]
ford05 Offline
Loc: New Jersey
i use exxon 93(super) always. cooling system is good. it's a little dirty. 114K miles. 160 thermst.
#1615856 - 11/17/08 02:14 PM Re: Lifters ticking. [Re: ford05]
Mileaway Offline
Loc: Sacto. Calif.
Might be the thermst is too cold and the octane too high but? Maybe an expert can add some worthwhile info. here. You should not have pinging.
#1615858 - 11/17/08 02:19 PM Re: Lifters ticking. [Re: Mileaway]
ford05 Offline
Loc: New Jersey
i mean it only happens when i accelarate and not always, just sometimes. my dads 98 towncar does the same thing.
#1616010 - 11/17/08 06:12 PM Re: Lifters ticking. [Re: ford05]
Mileaway Offline
Loc: Sacto. Calif.
Shouldn't though. What gas do you use? Try Chevron.
#1616231 - 11/17/08 09:31 PM Re: Lifters ticking. [Re: ford05]
Panther71 Offline
Can you hear it with the car in park and reving the motor?
2000 P71 Former Ridgecrest,CA PD Captains Unit -- 125K -- P71 Pic in link below...
http://4.bp.blogspot.com/_M4HMCCz1jm8/SUVu1QY70iI/AAAAAAAAAAU/iMXwNDv8eGk/s1600-h/DSC_0028.JPG
#1616240 - 11/17/08 09:37 PM Re: Lifters ticking. [Re: Panther71]
p71towny Offline
Loc: Ft. Wayne IN
My towncar would do that every once and a while. Then it started doing it non-stop. It's my excuse to put in a PI engine now. Still runs fine. Well, it did when I parked it anyhoo.
1995 Town Car, flowmaster 50's, gutted cats, gutted evap system, cold air tube, MMairbox & 80mm maf, K&N air filter, DR chip, 180 thermostat, 22pp plugs, Steeda underdrive pulleys w/gatorback belt, transgo shift kit, cross-drilled rotors w/performance friction pads, addco swaybars front and rear, poly bushings, edelbrock IAS shocks all around, deleted mechanical fan, Kenwood MP4028 w/kenwood 6x9's and 6x8's and more to come
1982 Crown Vic LTD 2dr No air pump or cats, cragar ss's, dual exhaust, tach, volt, oil, temp gauges.
#1616389 - 11/17/08 11:48 PM Re: Lifters ticking. [Re: p71towny]
Spook Offline
Loc: Missouri
Well, the ticking is starting to get to me. I can sort of hear it when I'm driving and of course I'm listening for it. Also, in park, I rev it up and can hear it. I just wish I knew what it was then I would try and take care of it.
So, I have the 5w-30 oil in it. Should I add something to make it thicker? I did use the oil filter that was recommended. Motorcraft one.
Lastly, should I be concerned about this? What's the worse that can happen??
Spook
#1616482 - 11/18/08 02:47 AM Re: Lifters ticking. [Re: Spook]
Marqed_Man Offline
Loc: il
Did you take it in to the dealership? Maybe you can get a mechanic to just drive it for a few minutes. I fel its hard to diagnose without listening where the ticking is coming from.
2004 LIncoln Town Car - Dark Charcoal Metalic. Motor has 82K miles. The rest of her has 290K miles. Past owner didnt take care of her. Im bringing her back to exceptional condition
#1616727 - 11/18/08 01:58 PM Re: Lifters ticking. [Re: Marqed_Man]
Spook Offline
Loc: Missouri
Shallot,
That was definitely the next step. I need to check out a rubbing noise in my right front wheel well anyway. Probably going to take it to Ford. Just don't want to get charged up the ( ! ) for them looking. (Not my ass, but the car.) But, at least I will know right?
Spook
#1616753 - 11/18/08 02:50 PM Re: Lifters ticking. [Re: Spook]
MGM4Dad Offline
Loc: California
Why would you want to make it thicker?
2004 MGM LS
"There is no substitute for experience"
#1616757 - 11/18/08 02:55 PM Re: Lifters ticking. [Re: MGM4Dad]
Mileaway Offline
Loc: Sacto. Calif.
5-30 is good.
#1616935 - 11/18/08 06:44 PM Re: Lifters ticking. [Re: Mileaway]
P71CVMAN Offline
Loc: wIScONSiN
I am running 5w-20 like recommended by my oil cap without any issues...at least that I know of.
#1616962 - 11/18/08 07:13 PM Re: Lifters ticking. [Re: P71CVMAN]
Spook Offline
Loc: Missouri
Well, I thought thicker substance would coat the parts better. See, I'm noob...lol
Spook
#1617075 - 11/18/08 09:24 PM Re: Lifters ticking. [Re: Spook]
Panther71 Offline
You sure it's a lifter ticking and not an exhaust leak ? My passenger side exhaust manifold has a broken rear stud that I haven't got around to replacing yet and it has a ticking sound very similar to a lifter tick. You can hear it more under power and when engine is reving then you can when it's just idleing. Sometimes the ticking will go away as the motor heats up and the exhaust manifold expands and seals the leak a little more.
#1617077 - 11/18/08 09:25 PM Re: Lifters ticking. [Re: Panther71]
Panther71 Offline
BTW............. 5W - 30 conventional is fine but synthetic is best.
#1617174 - 11/18/08 11:14 PM Re: Lifters ticking. [Re: Panther71]
P71CVMAN Offline
Loc: wIScONSiN
What about the Ford snythetic blend oil they sell at Wal-Mart?
#1617201 - 11/18/08 11:38 PM Re: Lifters ticking. [Re: P71CVMAN]
86tbird Offline
Loc: Ontario, Canada
If its only on accelerating it might be a ping. Try pulling the octane adjust jumper in the engine compartment and see if it changes. Could be a plugged EGR. My Two Cents
86tbird
#1617502 - 11/19/08 12:47 PM Re: Lifters ticking. [Re: 86tbird]
Spook Offline
Loc: Missouri
OK, well, I listened very close today down at Advance and here is what I got. The guy listened to it and said it was no big deal and that he could barley here anything.
Second, I checked the oil and I said,"Hows it look.?" They said it looked like I just changed my oil. (150 miles ago.) I said I changed due to the thicker weight. She said I should use thicker oil in higher mileage cars. (154,xxx) I said, well, I have been researching it (CV.Net)and I was told to use what you all said. 5w-30 (I did use Valvoline Max Life for engines over 75,XXX miles.) <-- Is that OK?
Now, back to the ticking. Again, it sounds not at the top of the engine like where the lifters are, but more mid to bottom engine.
It almost sounds like a "tock" instead of a "tick" When the car first starts, it's ticking up around the top of the engine,(I don't drive until that goes away. 2 mins. or so.) but the "tock" sounds like it's at the bottom. You could almost say it has a slight rattle sound without the rattle. ...Damn, I'm confusing myself.
I'm sorry for beating this thread to death but hopefully it has been useful to everyone here.
Spook
#1617589 - 11/19/08 02:19 PM Re: Lifters ticking. [Re: Panther71]
b1kfd Offline
Loc: Mississippi
Mine does exactly the same thing. Right now it's just annoying. I'm sure that after a while it will get aggravating, and I will
have to fix it.
2001 p71 former Jefferson County, Mo Sherriff Deputy's car, 2005 Ford Freestyle (wife's car) 1992 pos Nissan pickup, 1989 Kawasaki ZX10 Ninja.
#1617590 - 11/19/08 02:20 PM Re: Lifters ticking. [Re: Spook]
Mileaway Offline
Loc: Sacto. Calif.
That rattle sound or whatever it really is...yep-I know that sound.mine does it somewaht at startupwhen cold. Might be tensioners/timing chain. I'll worry about it in a few years when I approach 200 thousand on the odometer. Car is tough.
The sound will be most evident in a carport or garage due to the sound bouncing off the walls. Can't really hear it out in the open. It's probably ok. Could very well be a slight exhaust leak. Keep it in mind. Expansion and contraction-just like said above^^ Maybe.
#1617886 - 11/19/08 08:33 PM Re: Lifters ticking. [Re: Mileaway]
Panther71 Offline
The 5W - 30 at Walmart your talking about is a Blend. It will work fine but I personally like the fully synthetic. The fully Synthetic will give you about as much protection as you can get, especially on cold start up where most of the wear and tear on your engine takes place. The other option is to use conventional oil with a Lucas Oil additive or the like but by the time you buy the oil and additive, it cost about the same as Synthetic.
#1618619 - 11/20/08 04:55 PM Re: Lifters ticking. [Re: Panther71]
Spook Offline
Loc: Missouri
Thanks all. I took it to the exhaust shop where I got the Flowmasters on and he did weld a small part of a heat shield back but it wasn't it.
Guys, today it was sort of louder. Could it be a piston?
I can really hear it when I'm sitting in the car and rev it up. That's where it is the loudest. Then, when I open the hood and use the engine throttle, it's not as noticeable.
This may be part of the problem as well. Sometimes when I sit in the car at idle, the car vibrates for a split second, goes away and them comes back. Like a cycle. It does it within 2 seconds. Could one of my spark plugs be out or something? Maybe need new ones?
I think I may just take it to Ford and get it tuned up. Maybe they can tell me what it is.
I really do appreciate all the feed back guys.
Spook
#1618633 - 11/20/08 05:09 PM Re: Lifters ticking. [Re: Spook]
Big_Bad_Joe Offline
Loc: Rochester NY
5-30 oil is fine.. the argument about synthetic and conventional oils goes on endlessly on here .. its make me laugh constantly
just use a decent motorcraft or wix filter.... pure one is fine... change your oil at 3K or so with conventional and 5-7K on syn and you should be fine....
it is hard to imagine your sound... but if it is more noticeable in the car when you rev it that would sound like an exhaust leak... you said they put flowmasters on... i would say they need to check again..
did you hear this noise before they did that or after?
always start with the obvious first
heavy weight oils in high mileage motors is OLD SCHOOL... auto zone, advance, pep boys the whole retail chain will employ anyone so just ignore them unless you know the guy... overhead cam motors in general have major issues with heavy oils.. but speaking for the mod motor crowd its totally bogus in your climate... no reason to do it....
your car doesnt burn much oil i bet... these motos last a long time ...
Underdrives from ADTR.net
Given to DG in Ohio
#1618646 - 11/20/08 05:30 PM Re: Lifters ticking. [Re: Big_Bad_Joe]
P71CVMAN Offline
Loc: wIScONSiN
What about Fram oil filters Joe?
#1618731 - 11/20/08 07:06 PM Re: Lifters ticking. [Re: P71CVMAN]
Spook Offline
Loc: Missouri
I heard the sound before the exhaust work. So, I don't think that's it. It sounds like it's mid motor to bottom. Car doesn't burn anything. Good sign.
I just need to take it in. I'm beating this thread to death!!
Spook
1 registered (1 invisible), 39 Guests and 130 Spiders online.
bluejay_32 204
a_d_a_m 126
Old_Guy_Stu 124
DudeAbides 95
Ponyguy 68
Davidzq 47
CrystalPistol 46
Moby_Vic 44
ClayBelt 38
Bangster 35
