Page 3 of 4 < 1 2 3 4 >
#1616010 - 11/17/08 06:12 PM Re: Lifters ticking. [Re: ford05]
Mileaway Offline
Loc: Sacto. Calif.
Shouldn't though. What gas do you use? Try Chevron.
#1616231 - 11/17/08 09:31 PM Re: Lifters ticking. [Re: ford05]
Panther71 Offline
Can you hear it with the car in park and reving the motor?
2000 P71 Former Ridgecrest,CA PD Captains Unit -- 125K -- P71 Pic in link below...
http://4.bp.blogspot.com/_M4HMCCz1jm8/SUVu1QY70iI/AAAAAAAAAAU/iMXwNDv8eGk/s1600-h/DSC_0028.JPG
#1616240 - 11/17/08 09:37 PM Re: Lifters ticking. [Re: Panther71]
p71towny Offline
Loc: Ft. Wayne IN
My towncar would do that every once and a while. Then it started doing it non-stop. It's my excuse to put in a PI engine now. Still runs fine. Well, it did when I parked it anyhoo.
1995 Town Car, flowmaster 50's, gutted cats, gutted evap system, cold air tube, MMairbox & 80mm maf, K&N air filter, DR chip, 180 thermostat, 22pp plugs, Steeda underdrive pulleys w/gatorback belt, transgo shift kit, cross-drilled rotors w/performance friction pads, addco swaybars front and rear, poly bushings, edelbrock IAS shocks all around, deleted mechanical fan, Kenwood MP4028 w/kenwood 6x9's and 6x8's and more to come
1982 Crown Vic LTD 2dr No air pump or cats, cragar ss's, dual exhaust, tach, volt, oil, temp gauges.
#1616389 - 11/17/08 11:48 PM Re: Lifters ticking. [Re: p71towny]
Spook Offline
Loc: Missouri
Well, the ticking is starting to get to me. I can sort of hear it when I'm driving and of course I'm listening for it. Also, in park, I rev it up and can hear it. I just wish I knew what it was then I would try and take care of it.
So, I have the 5w-30 oil in it. Should I add something to make it thicker? I did use the oil filter that was recommended. Motorcraft one.
Lastly, should I be concerned about this? What's the worse that can happen??
Spook
#1616482 - 11/18/08 02:47 AM Re: Lifters ticking. [Re: Spook]
Marqed_Man Offline
Loc: il
Did you take it in to the dealership? Maybe you can get a mechanic to just drive it for a few minutes. I fel its hard to diagnose without listening where the ticking is coming from.
2004 LIncoln Town Car - Dark Charcoal Metalic. Motor has 82K miles. The rest of her has 290K miles. Past owner didnt take care of her. Im bringing her back to exceptional condition
#1616727 - 11/18/08 01:58 PM Re: Lifters ticking. [Re: Marqed_Man]
Spook Offline
Loc: Missouri
Shallot,
That was definitely the next step. I need to check out a rubbing noise in my right front wheel well anyway. Probably going to take it to Ford. Just don't want to get charged up the ( ! ) for them looking. (Not my ass, but the car.) But, at least I will know right?
Spook
#1616753 - 11/18/08 02:50 PM Re: Lifters ticking. [Re: Spook]
MGM4Dad Offline
Loc: California
Why would you want to make it thicker?
2004 MGM LS
"There is no substitute for experience"
#1616757 - 11/18/08 02:55 PM Re: Lifters ticking. [Re: MGM4Dad]
Mileaway Offline
Loc: Sacto. Calif.
5-30 is good.
#1616935 - 11/18/08 06:44 PM Re: Lifters ticking. [Re: Mileaway]
P71CVMAN Offline
Loc: wIScONSiN
I am running 5w-20 like recommended by my oil cap without any issues...at least that I know of.
Exhaust/dragstrip videos
#1616962 - 11/18/08 07:13 PM Re: Lifters ticking. [Re: P71CVMAN]
Spook Offline
Loc: Missouri
Well, I thought thicker substance would coat the parts better. See, I'm noob...lol
Spook
#1617075 - 11/18/08 09:24 PM Re: Lifters ticking. [Re: Spook]
Panther71 Offline
You sure it's a lifter ticking and not an exhaust leak ? My passenger side exhaust manifold has a broken rear stud that I haven't got around to replacing yet and it has a ticking sound very similar to a lifter tick. You can hear it more under power and when engine is reving then you can when it's just idleing. Sometimes the ticking will go away as the motor heats up and the exhaust manifold expands and seals the leak a little more.
#1617077 - 11/18/08 09:25 PM Re: Lifters ticking. [Re: Panther71]
Panther71 Offline
BTW............. 5W - 30 conventional is fine but synthetic is best.
#1617174 - 11/18/08 11:14 PM Re: Lifters ticking. [Re: Panther71]
P71CVMAN Offline
Loc: wIScONSiN
What about the Ford snythetic blend oil they sell at Wal-Mart?
#1617201 - 11/18/08 11:38 PM Re: Lifters ticking. [Re: P71CVMAN]
86tbird Offline
Loc: Ontario, Canada
If its only on accelerating it might be a ping. Try pulling the octane adjust jumper in the engine compartment and see if it changes. Could be a plugged EGR. My Two Cents
86tbird
#1617502 - 11/19/08 12:47 PM Re: Lifters ticking. [Re: 86tbird]
Spook Offline
Loc: Missouri
OK, well, I listened very close today down at Advance and here is what I got. The guy listened to it and said it was no big deal and that he could barley here anything.
Second, I checked the oil and I said,"Hows it look.?" They said it looked like I just changed my oil. (150 miles ago.) I said I changed due to the thicker weight. She said I should use thicker oil in higher mileage cars. (154,xxx) I said, well, I have been researching it (CV.Net)and I was told to use what you all said. 5w-30 (I did use Valvoline Max Life for engines over 75,XXX miles.) <-- Is that OK?
Now, back to the ticking. Again, it sounds not at the top of the engine like where the lifters are, but more mid to bottom engine.
It almost sounds like a "tock" instead of a "tick" When the car first starts, it's ticking up around the top of the engine,(I don't drive until that goes away. 2 mins. or so.) but the "tock" sounds like it's at the bottom. You could almost say it has a slight rattle sound without the rattle. ...Damn, I'm confusing myself.
I'm sorry for beating this thread to death but hopefully it has been useful to everyone here.
Spook
3 registered (dixiebandit69, 2 invisible), 61 Guests and 289 Spiders online.
bluejay_32 177
CrystalPistol 152
a_d_a_m 131
DudeAbides 128
Old_Guy_Stu 120
Moby_Vic 89
ford05 65
Warped9 62
JeffBoudah 59
Ponyguy 58
