#1614818 - 11/16/08 11:40 AM LSD- How to check if I have it?
Cabhammer Offline
Loc: Da South
Bought my 06 P74 used. Car has a "traction control" on/off switch. Want to know if ti has an LSD or not. How to check?
If it does not have one, what am I looking at to get the dealer (or me under the shade tree) to install one?
-Cabby
'06 Smokestone P74 - 17" S197 Bullits w/ Pirelli P-Zero Nero. Tint by Purvis. '07 CD6 Stereo, Sony Xplod 10 Disc MP3 Changer. 3M Headlamp Shields. K&N Filter. Relay Kit and XtraVisions. Reinhardt Rear Valance Plate, 17mm P71 Rear Bar.
Next: Duals, P71 Box/MAF/Zip Tube. Custom Tune. Addco F&R Swaybars.
'75 Cutlass Supreme->'78 VW Dasher->'80 VW Scirocco->'80 VW Jetta->'82 VW Rabbit Convertible->'84 VW Jetta GLi->'95 VW Jetta GLX VR6->'06 Ford CVLX
#1614822 - 11/16/08 11:45 AM Re: LSD- How to check if I have it? [Re: Cabhammer]
04RauderDTR Offline
Loc: PA
99.9% of me says you dont, because civilian crown vic's only caem with 2.73 or 3.27 open rear ends.
however, just go in the street and light em up. Simplest way to know if you have a limited slip.
Ryan #2
2004 Mercury Mcgruber Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, Tremec T-56 Magnum, 4.10's, Stainless Works LT's, 2.5" Exhaust W/ Borla Stingers, FX-R projectors, Addco F/R swaybars
2003 Mercury Marauder Stainless Works LT's, Stainless Works catback, Mo's tune, JLT
1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors
2000 BMW M5 Evolve CAI + AlphaN Tune, Dinan strut bar + rear swaybar, Stoptech ST40BBK, UUC Shifter
2016 Ford Mustang GT Performance Pack
#1614836 - 11/16/08 12:01 PM Re: LSD- How to check if I have it? [Re: Cabhammer]
gDMJoe Offline
Loc: Timbuk3, MI
Door Sticker Decoder <<<<< -click-
-click the Vic-
#1614843 - 11/16/08 12:18 PM Re: LSD- How to check if I have it? [Re: gDMJoe]
metroplex Offline
Loc: Motor City, USA
They no longer use an axle tag and the L code for some of the Ford 8.8" rear ends. My GT has a sticker that says "SYNTH LUBE ONLY 3.55"
#1614844 - 11/16/08 12:21 PM Re: LSD- How to check if I have it? [Re: metroplex]
98VicP71 Offline
13.97@99MPH
Loc: ATL
jack the rear of the car up so both rear tires are off the ground. (Make sure to block the front wheels).
with both rear tires off the ground rotate one of the rear tires. If the tire on the other side spins in the same direction then you have an LSD but if it doesn't then you don't
#1614872 - 11/16/08 12:53 PM Re: LSD- How to check if I have it? [Re: 98VicP71]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
I have seen an explorer diff with both. the syn only tag and the gear tag. Its a 2001 Explorer sport.
The Jmod video is done! LINK!
#1614980 - 11/16/08 02:56 PM Re: LSD- How to check if I have it? [Re: Rizzo]
kustomizingkid Offline
Loc: Minnesota
My tag is wrong... I wouldn't trust them...
2000 CVPI 121,000 miles
#1615055 - 11/16/08 04:33 PM Re: LSD- How to check if I have it? [Re: 98VicP71]
Traction control is electronic and uses the ABS (low speed) to modulate the spinning rear wheel's brake caliper along with torque modulation by the PCM to reduce wheel slippage.
It is an independent option from traction-lok (LSD)
Traction-lok was not available for your model regardless of gear ratio, so you won't have it.
I was optional for fleet/CVPI models for both the 3.27 and 3.55 axle ratio for your year.
You can purchase one from adtr.net, installation will probably be ~$200-$300 since the pinion won't be touched..
...driveshaft/transmission also needs to be in neutral if it has an LSD for them both to spin. If open it will spin the other side the opposite direction even with shaft locked/park.
The AXLE tag should always be right. The door sticker, OTOH, can't always be trusted. Most who have found discrepancies with the axle tag bought their cars used, and/or with higher mileage from fleet use (police) so the rear axle had probably been opened up at some point. Though, it's not completely impossible but would be extremely rare.
#1615066 - 11/16/08 04:46 PM Re: LSD- How to check if I have it? [Re: dRock96Marquis]
Loc: Minnesota
On my car the door tag and axle tag say 3.55 no locker... but when Roylpita ran the OASIS on it 3.55 locked is what comes back... dunno.
#1615087 - 11/16/08 05:03 PM Re: LSD- How to check if I have it? [Re: kustomizingkid]
metroplex Offline
Pull the cover and look for the S-Spring. At 100k, you might want to change the gear oil anyhow.
#1615093 - 11/16/08 05:06 PM Re: LSD- How to check if I have it? [Re: metroplex]
Loc: Minnesota
I need to change my fluid and replace the clutches..
#1615609 - 11/17/08 07:50 AM Re: LSD- How to check if I have it? [Re: kustomizingkid]
Cabhammer Offline
Loc: Da South
Whats and LSD and install cost? Would I need to go to 3.27 gears to be able to use it??
#1615614 - 11/17/08 08:01 AM Re: LSD- How to check if I have it? [Re: Cabhammer]
metroplex Offline
You just swap out the differential carrier. Install cost in new parts:
$230 for new Traction-Lok
$30 for new carrier bearings and races
$10 for new ring gear bolts
$24 for new synthetic gear oil (Redline 75W-140)
$4 for 3 oz of XL-1 Ford friction modifier
Do the 2006 Vics get 31 spline axles? I think Ford went to 31 spline for 2005-up, just like the S197 Mustangs. If so, you cannot use take-off Traction-Loks from 99-04 Mustang GTs.
#1615966 - 11/17/08 05:32 PM Re: LSD- How to check if I have it? [Re: Cabhammer]
46time Offline
Loc: Florida
It will probably cost around $300 for labor at a shop. You don't have to have 3.27's. You could keep your 2.73's if you like. But, if you are thinking about uprading gears in the future, it would be best to get it all done at the same time. You would save yourself the labor costs a second time.
2002 Mercury Grand Marquis LSE.
*Purchased: June 2018 w/ 50K miles.
*5 speed swapped: October 2019 @ 64K.
Mods:
*Vortech V2 (Tuned by Marty - Mo's Speed Shop)
*JMOD w/ modified shift schedule
*Projector headlamp retrofit
*1/0 Big 3 wires.
#1617102 - 11/18/08 10:08 PM Re: LSD- How to check if I have it? [Re: Cabhammer]
Steve83 Offline
Lick the stamp.
Traffic22 15
