#1646287 - 12/24/08 07:41 PM 03-up rearend width
61forduni Offline
can anyone tell me what the width from brake mounting surface to brake mounting sufrace on a 03 up crown vic?we put these suspensions in f100's and ive got the front mounted (04) and everyone says the later rears are too wide and i dont see how or why ford would make a rear wider tahn they would the front so i was going to try to get some measurements before i went a spent a bunch of money
#1646548 - 12/25/08 03:09 AM Re: 03-up rearend width [Re: 61forduni]
Hmm.
I can give you the rear track, which is ~65.6"
The front track 63.4" for comparison.
This rear track is about the same as '98-'02 panthers - but the overall axle axle width is a little over ~3" wider because of the VERY high positive offset wheels used on 2003+ panthers
If you need a narrower axle housing width, use the '98-'02 panther axle housing. It uses the same control arms, watts linkage and spring perches as the '03+ axle housings, it just doesn't have the shocks outboard of the frame rails.
#1646671 - 12/25/08 12:18 PM Re: 03-up rearend width [Re: dRock96Marquis]
61forduni Offline
thanks for the info that helps some. i guess ill have to use one of the 90s rear and use something like 18x8 in front with 18 x 10 in rear is what im gathering to get it to line up straight.the suspension is not a big deal as im using stock truck springs from my truck.do you know anywhere maybe it gives axle length from other years or maybe to many makes of cars?
1 registered (a_d_a_m), 32 Guests and 260 Spiders online.
bluejay_32 185
a_d_a_m 146
Old_Guy_Stu 129
DudeAbides 87
Ponyguy 66
Moby_Vic 42
LTC_Dave 42
Davidzq 38
Bangster 38
