#1692218 - 02/18/09 06:09 AM whats my gear ratio
I_AM_SEAN Offline
Loc: Lexington,KY
i'm not sure if my gear ratio is correct, it says my axle is "X5" and when I rev my car to burn out both tires spin, does that mean posi-trac?
also i want max MPG so what should i switch to?
Edited by I_AM_SEAN (02/18/09 06:09 AM)
2001 CVPI -147.979k Miles Former KSP
Interior Paint job, 180F Temp, Typhoon PI Intake Manifold, Headlight Wiring mod, ZIP tube, 37k Transmission,5% tint rear/25%front.
#1692239 - 02/18/09 07:25 AM Re: whats my gear ratio [Re: I_AM_SEAN]
98VicP71 Offline
[email protected]
Loc: ATL
yes that would mean you have a trac-loc.
As for rear gears for the best fuel economy you would want to switch to 2:73's
You currently have 3:27's
#1692255 - 02/18/09 07:43 AM Re: whats my gear ratio [Re: 98VicP71]
I_AM_SEAN Offline
Loc: Lexington,KY
Okay so for the swap
1 do you know where i can get them
2 is there any major thing i have to do?
#1692257 - 02/18/09 07:48 AM Re: whats my gear ratio [Re: I_AM_SEAN]
98VicP71 Offline
[email protected]
Loc: ATL
1.) you can find them anywhere, Ebay, On this board, adtr.net summit and so forth.
I would look on here and ebay to find the best deal. Most people swap their gear out to go to a lower gear so there should be some that have a set of 2:73 gears that they would be willing to part with pretty cheap.
2.) You will want to have them installed by a professional. it is about a 4 hour process if you know what you are doing and there are very tight tolerances you have to deal with and would need a dial indicator and such.
personally if you are going to swap gears and will have the rear end torn apart anyway now would be a perfect time to get a rear end rebuild kit and replace all the bearings and seals in the rear end as well as the axle seals and bearings.
#1692262 - 02/18/09 07:54 AM Re: whats my gear ratio [Re: 98VicP71]
I_AM_SEAN Offline
Loc: Lexington,KY
I check adtr and ebay neither have them
Edited by I_AM_SEAN (02/18/09 08:25 AM)
#1692416 - 02/18/09 12:12 PM Re: whats my gear ratio [Re: I_AM_SEAN]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Check out the for sale section here... A near free set of 2.73's will become more available as peeps get tax refunds and want a higher ratio.
If you buy used... Ask for pics...If the teeth arent saw "blade sharp" so to speak... Walk.
The Jmod video is done! LINK!
#1692430 - 02/18/09 12:25 PM Re: whats my gear ratio [Re: Rizzo]
kustomizingkid Offline
Loc: Minnesota
Just pick up a complete rear axle assembly form a junk yard with the 2.73's in it...
2000 CVPI 121,000 miles
#1692449 - 02/18/09 12:40 PM Re: whats my gear ratio [Re: I_AM_SEAN]
X5 is 3.27 w/ Traction-lok for 2001 MY
Complete door sticker axle code chart for '01:
The axle ratios are:
l C8 2.73 conventional (non-locker)
l 58 2.73 conventional (non-locker)
l AZ 3.08 conventional (non-locker)
l R2 3.55 conventional (non-locker)
l Z5 3.27 conventional (non-locker)
l X5 3.27 locker
There is also a tag on the rear differential cover with the ratio stamped on it. For a 3.27 w/ TL it would be 3L27, then the plant/buil sequence under it.
For a 3.27 open it would read 3 27, with the open space between.
The first digit is often partially under the diff cover bolt. If it ends in 27, 08, or 55 it is a 3. If it ends with 73 it has 2.73s (which weren't installed in CVPIs, but are in all base CV/GMQ)
#1692488 - 02/18/09 02:10 PM Re: whats my gear ratio [Re: dRock96Marquis]
RiceBurnt6 Offline
Loc: SWMI
You Rock!! Drock. I have x5 as well. But when i encountered 7' of snow. Only 1 wheel was spinning? If i hold down the brakes and do a burnout both wheels spin?
Originally Posted By: RiceBurnt6
You're getting mad at the content of a thread of which you clicked on? Maybe you need to get a life? Yes?
#1692493 - 02/18/09 02:26 PM Re: whats my gear ratio [Re: RiceBurnt6]
98VicP71 Offline
[email protected]
Loc: ATL
sounds like you need new clutches.. Average life span is around 50k-75k
#1692494 - 02/18/09 02:27 PM Re: whats my gear ratio [Re: 98VicP71]
RiceBurnt6 Offline
Loc: SWMI
Great \:\( How difficult is it to replace the clutches, and Where can i find the kit?
#1692607 - 02/18/09 05:45 PM Re: whats my gear ratio [Re: RiceBurnt6]
ludwigvan968 Offline
Loc: Austin, Tx
adtr.net sells them, get the carbon ones they rock!
96 GM HPP 206K mi.(chassis), Tuned by Manny at HPP, 76mm DBB PT, SQV BOV, Accufab TB/UP, Tial 44mm WG, 3" Intake and 3" Single Exhaust piping, PI Intake, PI Cams, MMR Stainless Valves, Manley Springs, P&P PI Heads, Forged Rods and Pistons, 90mm Lightening MAF and injectors (42lbs), 255 Walbro, BOC Trans, BOC Stage II TC 3,000 stall, 3.73, Trac-Loc, Cobra Carbon Clutches, AMMX driveshaft, SCT Xcal II J-Tune, Transmission cooler, PowerSlot Brakes, ENS front control arm bushings, Addco Front and Rear Swaybars, Poly Endlinks and Clamps, Front and Rear Bilstien Shocks, F/R PI springs, Rear ENS Control Arm Bushings, custom structural re-enforcement(stabilizer bar mounts and lower control arm mounts, among other spots), Custom Boxed Lower Rear Control Arms, Kenwood HU, Alpine Type R 5X7's, Kicker Comp 6X9's,Alpine 4X50, Crunch 1100 subwoofer Amp, Image Dynamics 12" subwoofer, Yellow Top
#1692827 - 02/18/09 11:07 PM Re: whats my gear ratio [Re: ludwigvan968]
innertwist Offline
Loc: Huntersville, NC
I'm confused. My door sticker has 'X5' for the axle as well, but it's definitively not a locker (I've changed the gear oil - no clutches). It's a 1997. Is it still a 3.27? Should it have an LSD based on the code on the door?
#1692886 - 02/19/09 12:39 AM Re: whats my gear ratio [Re: innertwist]
No, the code doesn't have the same description every year - hence the confusion.
On the OP's 2001 it's a 3.27 w/ traction-lok
On your '97 it should be a 3.27 OPEN differential.
Look at the tag on the diff cover to confirm
#1692898 - 02/19/09 01:04 AM Re: whats my gear ratio [Re: dRock96Marquis]
hotrodjcc Offline
Loc: DFW, TX
Sean i know a shop in lexington who will do a gear swap for you for a decent price. He swapped my gears out
98 cv lx. -sold
2003 Cobra: cold air, catback,2.8in pulley, O/R upr x pipe,Accufab TB/Plenum and hurst shifter only. #5983
2014 Jeep Cherokee 5.7
2008 F-250 King Ranch 6.4 Spartan and deleted
http://www.facebook.com/home.php?#/profile.php?id=576101863&ref=profile
4 registered (Rainbowpizza, TheCableGuy, astrae, Tove), 63 Guests and 281 Spiders online.
bluejay_32 163
Old_Guy_Stu 91
a_d_a_m 79
CrystalPistol 68
TheCableGuy 53
DudeAbides 51
RF_Overlord 48
Moby_Vic 47
Ponyguy 45
Bangster 42
