#1694692 - 02/21/09 04:13 AM Speedo gear question ?????????
SVT_Merc Offline
Loc: Cape Coral, FL
I plan on installing a limited slip 3:55 unit in place of the 2:73 open one on my '02 MGM. What speedometer gear do I need to get to correct my speed? Ford p/n:???????
#1694791 - 02/21/09 09:59 AM Re: Speedo gear question ????????? [Re: SVT_Merc]
musclemarquis Offline
Loc: chicago burbs
I'm running the 23tooth. The speedo is within a half mile of what it's supposed to be, so it's as accuarate as you'll get.
I think I got mine from mustangsunlimited.com
Mercury Special Edition wink
http://www.supermotors.net/vehicles/registry/19273
Click the link for more info on my car.
Horsepower is an addiction. smile
#1694809 - 02/21/09 10:28 AM Re: Speedo gear question ????????? [Re: SVT_Merc]
gDMJoe Offline
Loc: Timbuk3, MI
Speedo Gear Selection <<<<< -click-
> Step 3: Obtain the proper speedo gear.
-click the Vic-
#1694856 - 02/21/09 11:27 AM Re: Speedo gear question ????????? [Re: gDMJoe]
2000 - 2002 models with factory 2.73 gears SHOULD have a 8 tooth output shaft drive gear.
Check your exisiting speedo gear to confirm, if you do not want to pay the approx $29 for the gear plus shipping and find out you need the $9 orange gear you can get locally.
The VSS location as you will see it under the car
Slide out the clip and remove the old gear, note I have the Green 17 tooth gear, Using Liquids chart this confirms my 8 tooth output shaft drive gear.
New vs old
Part# black 23 tooth gear DFM17271J 01 From Mustangs unlimited
Shipping is high as they use a box, perhaps it avoids the small gear from getting damaged by sending in a padded envelope??
http://www.mustangsunlimited.com/itemdy00.asp?T1=DFM17271J+01
2004 Crown Vic LX SOLD!!
#1694869 - 02/21/09 11:45 AM Re: Speedo gear question ????????? [Re: Chevyguy]
Loc: chicago burbs
heh, you got the same one as me from the same place too.
#1695264 - 02/21/09 08:15 PM Re: Speedo gear question ????????? [Re: musclemarquis]
SVT_Merc Offline
Loc: Cape Coral, FL
Great stuff......... Anyone have a good used limited slip 3:55 unit??? Or recommendations (FRPP, Richmond, etc......)
#1695266 - 02/21/09 08:19 PM Re: Speedo gear question ????????? [Re: SVT_Merc]
Loc: chicago burbs
I just pulled one out of a used interceptor, threw in new bearings and clutches, with ford racing ring&pinion, and she drives good as new. Don't cost too much either.
#1695296 - 02/21/09 09:09 PM Re: Speedo gear question ????????? [Re: musclemarquis]
cfrank Offline
Loc: North Florida
I am planning on swapping my 3.55 for a 2.73, Where exactly is the speedo gear and how is it replaced?
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1695337 - 02/21/09 10:18 PM Re: Speedo gear question ????????? [Re: cfrank]
Loc: chicago burbs
All the pics are ^^^up there^^^
I think it's on the passenger side of the transmission....could be wrong tho.
#1695338 - 02/21/09 10:18 PM Re: Speedo gear question ????????? [Re: cfrank]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
Why would you do that?
#1695339 - 02/21/09 10:19 PM Re: Speedo gear question ????????? [Re: Quickvic30]
Loc: chicago burbs
Maybe he wants better mileage..... that's the only valid reason I can think of.
#1695366 - 02/21/09 11:00 PM Re: Speedo gear question ????????? [Re: musclemarquis]
cfrank Offline
Loc: North Florida
yea, that's why
#1695368 - 02/21/09 11:01 PM Re: Speedo gear question ????????? [Re: cfrank]
cfrank Offline
Loc: North Florida
Do you just have to pull that black c-clip and pull the old gear off and then replace with new gear and the c-clip?
#1695371 - 02/21/09 11:04 PM Re: Speedo gear question ????????? [Re: cfrank]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
yup
2002 CV P73
#1695388 - 02/21/09 11:34 PM Re: Speedo gear question ????????? [Re: coldfusion11]
Belteshazzar Offline
Loc: Lincoln, NE
I did mine in 5 minutes. didn't even jack up the car. and the ford dealer got me the gear in 24 hours, don't remember how much, but it was under $5. Like 2 or 3 iirc.
the longer the mod list in your signature, the slower your car probably is.
2 registered (bluejay_32, Traffic22), 61 Guests and 269 Spiders online.
bluejay_32 166
a_d_a_m 105
