#1712096 - 03/12/09 09:36 AM No Crank Condition
Codyy Offline
Fearless Leader
Loc: Up North Eh
So last night my 2004 CVPI was perfect. Fired up more than once, no issues whatsoever. After a bit of lengthy driving last night, it won't start this morning. I found this list of questions below in someone else's no start thread, I figured it may be helpful.
Can you turn the key in the ignition? (Yes)
- When you switch the ignition ON before starting the car, does the "check engine" light come on? (Yes)
- Do you hear the cranking sound when you're trying to start your car? (No cranking sound)
- Is the engine being turned over by the starter too slowly? (No cranking)
Before your engine died, did you experience any prior events such as:
- leaving the lights ON overnight (No)
- driving through a deep puddle, or washing the engine compartment? (Yes - engine was detailed Tuesday by a professional cleaner, but like I said no starting issues until now)
- having only a little fuel in a tank? (Fuel tank over half full)
- having had the engine repaired recently? (No)
- extremely low oil pressure? (No low oil pressure)
- unusual noises such as knocking, pinging, whistling? (Only noise was that sometimes when firing up in the cold, I heard a slight ring or whistle maybe when it went to high idle, just for a second)
- smoking from exhaust pipe? (No)
The battery is brand spanking new, and I checked the voltage, it was reading 11.9V at -22 degrees Celsius over here. I still got all lights and everything though, but the no cranking sound is what bothers me. I only hear a relay click when the ignition is moved to start and then to on.
Thanks, much appreciation for any quick responses here!
#1712239 - 03/12/09 12:39 PM Re: No Crank Condition [Re: Codyy]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Focus on the starter.
Jump the solenoid with a screwdriver. Or better yet get a rubber dead blow hammer and smack it a few times. The idea is to rattle the brushes.
Also test the red plastic covered wire at the solenoid while someone tries to crank it. Getting any volts's ?
The Jmod video is done! LINK!
#1712261 - 03/12/09 01:05 PM Re: No Crank Condition [Re: Rizzo]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
If you are in Park-- move the lever to Neutral and wiggle the lever while turning the key to start. You have a "neutral" safety switch that must be in the correct position to engage the starter.
#1712314 - 03/12/09 02:07 PM Re: No Crank Condition [Re: gord_bolton]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Thats pretty smart.
Lets do the easy clean stuff before we go rollin around in the dirt.
Nice
#1712380 - 03/12/09 03:18 PM Re: No Crank Condition [Re: Rizzo]
logan126 Offline
Loc: Jefferson, Ga
x2 with Rizzo. Sounds like a bad starter (solenoid) or a bad wire connection.
'93 cvlx P74 240k+(not sure anymore. odo quit working a while back..)
dual exhaust
headlight relay upgrade
#1712428 - 03/12/09 03:55 PM Re: No Crank Condition [Re: logan126]
Codyy Offline
Fearless Leader
Loc: Up North Eh
I'll try the neutral safety switch thing as soon as I can. My first thought when this happened was that it was the starter, our old Caravan did the exact same thing lol.
#1712486 - 03/12/09 04:50 PM Re: No Crank Condition [Re: Codyy]
Codyy Offline
Fearless Leader
Loc: Up North Eh
Won't start in neutral or park. Starter/solenoid idea is looking stronger now.
Which area is the starter/solenoid located underneath. It is pretty tight under there, how hard is this thing to reach? Jack/jack stands needed I'm guessing (I managed to do the Caravan without lifting).
Edited by Codyy (03/12/09 05:03 PM)
#1712527 - 03/12/09 05:28 PM Re: No Crank Condition [Re: Codyy]
gord_bolton Offline
Passenger side-bottom side rear of block.
#1713134 - 03/13/09 01:33 AM Re: No Crank Condition [Re: gord_bolton]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
#1713155 - 03/13/09 01:46 AM Re: No Crank Condition [Re: Rizzo]
Codyy Offline
Fearless Leader
Loc: Up North Eh
Yikes... bigger job than I thought. Need to remove belts and looks really tight. I don't know if I'll be able to DIY this one now, especially since I've got limited time and space with the cold weather. Thanks for the link.
#1713542 - 03/13/09 05:03 PM Re: No Crank Condition [Re: Codyy]
Codyy Offline
Fearless Leader
Loc: Up North Eh
All of a sudden the vehicle started today. It is also much warmer today, and when it wouldn't start yesterday, it was approx. -22. So... now what is it then? I'm guessing related to my engine wash? Now, I need to know as fast as possible what to do to make sure whatever happened doesn't happen again, so we can take the car out. Thanks!!
#1713555 - 03/13/09 05:08 PM Re: No Crank Condition [Re: Codyy]
jaybird Offline
Loc: San Jose Ca.
do not wash the engine! or if yuou must cover the coil on plugs? just my opinion
2000 CV LX HPP Loaded 3.55 RAR SOLD @ 191k MILES / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
#1713557 - 03/13/09 05:09 PM Re: No Crank Condition [Re: Codyy]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
This is exactly how my 97's starter did me...
I still think its gonna die.
#1713574 - 03/13/09 05:33 PM Re: No Crank Condition [Re: Rizzo]
Mileaway Offline
Loc: Sacto. Calif.
I've had starters do that.Usually when the engine is hot. The starter on my 84 would do that only when hot but worked every time when cold. Now I did have a starter on a Geo Prizm that did it regardless - Hot or cold.
#1713744 - 03/13/09 09:09 PM Re: No Crank Condition [Re: Mileaway]
2vmodular Offline
Loc: New England
you might have problems with your battery cables too.
http://www.p71interceptor.com
3 registered (Tenevic_P71, Old_Guy_Stu, 1 invisible), 86 Guests and 283 Spiders online.
bluejay_32 159
CrystalPistol 97
Old_Guy_Stu 87
a_d_a_m 79
TheCableGuy 54
Moby_Vic 52
DudeAbides 51
Bangster 49
Ponyguy 46
RF_Overlord 42
