#1712096 - 03/12/09 09:36 AM
No Crank Condition
Fearless Leader
Loc: Up North Eh
So last night my 2004 CVPI was perfect. Fired up more than once, no issues whatsoever. After a bit of lengthy driving last night, it won't start this morning. I found this list of questions below in someone else's no start thread, I figured it may be helpful.
Can you turn the key in the ignition? (Yes) - When you switch the ignition ON before starting the car, does the "check engine" light come on? (Yes) - Do you hear the cranking sound when you're trying to start your car? (No cranking sound) - Is the engine being turned over by the starter too slowly? (No cranking) Before your engine died, did you experience any prior events such as: - leaving the lights ON overnight (No) - driving through a deep puddle, or washing the engine compartment? (Yes - engine was detailed Tuesday by a professional cleaner, but like I said no starting issues until now) - having only a little fuel in a tank? (Fuel tank over half full) - having had the engine repaired recently? (No) - extremely low oil pressure? (No low oil pressure) - unusual noises such as knocking, pinging, whistling? (Only noise was that sometimes when firing up in the cold, I heard a slight ring or whistle maybe when it went to high idle, just for a second) - smoking from exhaust pipe? (No)
The battery is brand spanking new, and I checked the voltage, it was reading 11.9V at -22 degrees Celsius over here. I still got all lights and everything though, but the no cranking sound is what bothers me. I only hear a relay click when the ignition is moved to start and then to on.
Thanks, much appreciation for any quick responses here!
#1712261 - 03/12/09 01:05 PM
Re: No Crank Condition
[Re: Rizzo]
Loc: Saskatoon, Saskatchewan
If you are in Park-- move the lever to Neutral and wiggle the lever while turning the key to start. You have a "neutral" safety switch that must be in the correct position to engage the starter.
#1712380 - 03/12/09 03:18 PM
[Re: Rizzo]
Loc: Jefferson, Ga
x2 with Rizzo. Sounds like a bad starter (solenoid) or a bad wire connection.
'93 cvlx P74 240k+(not sure anymore. odo quit working a while back..) dual exhaust headlight relay upgrade
#1712527 - 03/12/09 05:28 PM
[Re: Codyy]
Passenger side-bottom side rear of block.
#1713555 - 03/13/09 05:08 PM
[Re: Codyy]
Loc: San Jose Ca.
do not wash the engine! or if yuou must cover the coil on plugs? just my opinion
2000 CV LX HPP Loaded 3.55 RAR SOLD @ 191k MILES / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
#1713557 - 03/13/09 05:09 PM
[Re: Codyy]
J-MOD Master
Loc: Romulus,MI
All of a sudden the vehicle started today. It is also much warmer today, and when it wouldn't start yesterday, it was approx. -22. So... now what is it then? I'm guessing related to my engine wash? Now, I need to know as fast as possible what to do to make sure whatever happened doesn't happen again, so we can take the car out. Thanks!! This is exactly how my 97's starter did me... I still think its gonna die.
The Jmod video is done! LINK!
#1713574 - 03/13/09 05:33 PM
[Re: Rizzo]
Loc: Sacto. Calif.
I've had starters do that.Usually when the engine is hot. The starter on my 84 would do that only when hot but worked every time when cold. Now I did have a starter on a Geo Prizm that did it regardless - Hot or cold.
