Page 3 of 98 < 1 2 3 4 5 97 98 >
#1803679 - 07/02/09 07:09 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Bondfreak13]
hotrodjcc Offline
Loc: DFW, TX
Is there a timing chain cover difference that will cause a problem when using romeo heads on a windsor block?
98 cv lx. -sold
2003 Cobra: cold air, catback,2.8in pulley, O/R upr x pipe,Accufab TB/Plenum and hurst shifter only. #5983
2014 Jeep Cherokee 5.7
2008 F-250 King Ranch 6.4 Spartan and deleted
http://www.facebook.com/home.php?#/profile.php?id=576101863&ref=profile
#1804114 - 07/03/09 12:13 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: hotrodjcc]
nickmckinney Offline
Loc: Orlando
No but you need the front timing cover bolts from a Romeo head and make sure you have the head gaskets with the large oil feed oil.
#1804146 - 07/03/09 01:04 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
hotrodjcc Offline
Loc: DFW, TX
Nick which all bolts in the modulars are torque stress. Meaning when i get these heads and go back to assemble which are the bolts that need to b e replaced? I know the head bolts and main bolts need to be replaced from what I hear about these engines.
98 cv lx. -sold
#1808538 - 07/09/09 01:14 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: troyco]
Quickcrownvic Offline
 Originally Posted By: troyco
i have a question....what kind of mods need to be done to the windshield wiper housing for clearance? anyone have pics?
On a Lightning setup the fuel rail crossover line runs right through the wiper housing and sits on top of the motor and arm. No way to keep wipers functional if installed like this. Also, the fuel lines come up on the wrong side of the engine bay.
I ended up modifying the rails and installing them backwards so the crossover is on the front of the motor. Part of the rail still interferes with the housing, but only a small hole is required. I'll get some pics tomorrow.
'06 P71 - ADTR sway bars/19" Mustang wheels
'07 P71 - Stock
'00 Jeep Cherokee XJ 4x4
'00 Lincoln Town Car - Sold
'00 P73 Supercharged 5.4 - 2009 Panther of the year - Sold.
#1808744 - 07/09/09 10:37 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Quickcrownvic]
Georges93LX Offline
Loc: Owensboro, Ky.
I'm interested in seeing the photos. I'm using the 96-97 fuel rails that connect on the drivers side. Mine were converted when I did the PI engine swap.
1993 Crown Victoria LX. 5.4L Supercharged/6-Speed. SOLD. Black '03 Marauder 300a. SOLD.
If I gave a crap about gas mileage I would own a bicycle. It's time to start shopping.
#1808780 - 07/09/09 11:07 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: hotrodjcc]
Loc: Orlando
Words straight from a Ford engineer that worked on both the Romeo and Windsor designs:
"All bolts are designed for 5 uses minimum"
I have reused every bolt including head bolts and the only failures I have seen are from ARP bolts actually.
#1809119 - 07/09/09 07:11 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
wanderer Offline
Loc: georgia
What would you all suggest for an exhaust manifold for a 2004 Grand Marquis. I have heard the ford shorties won't work, and I haven't heard anything too positive about the kooks
#1809120 - 07/09/09 07:13 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
Here's some pics of my fuel rails and how I installed them backwards.
This photo shows the metal that had to be welded to the fuel rail so it can be bolted down. The rear bracket lined up properly without modification.
Also shown is the plastic crossover lines which I wrapped in heat shield.
Here shows how the fuel lines come up and attach to the rails.
Here shows the crossover lines on the driver side. The thermostat housing interferes with their path but the lines are flexible and just go over it. I wrapped them in heat shield and wire loom so they won't directly touch any hot metal or wear through by friction. Looks ugly yes, but I get to have working wipers.
Drivers side fuel rail. Arrow points to the metal tab welded to the rail. As you can see the front bracket lined up properly.
The lid on the wiper housing is not closed all the way in this photo, which is why it's touching the engine. It's not supposed to be this close but I broke off all the clips being careless and the lid never closes all the way now.
Here I'm pushing the lid down to where it's supposed to be. You can see the hole required for the fuel rail.
This is how far the rail protrudes into the housing. The arrow is pointing to a cut I made for the crossover lines to come through. They ran right into the wiper motor. Reversing the rails was the best way to get wipers working again. Custom rails may be a possible option and visually nicer too, but expensive.
'07 P71 - Stock
#1809126 - 07/09/09 07:20 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Quickcrownvic]
Loc: Ventura County, CA.
Thanks Quickcrownvic.
Remember now that was for a Lightning setup.
Anyone who as done an N/A setup could they please chime in on what they did, if they even had the same problem?
#1809401 - 07/09/09 11:48 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
Georges93LX Offline
Loc: Owensboro, Ky.
That's a hell of a risk to take but I'm willing to try it.
#1809408 - 07/10/09 12:06 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
Georges93LX Offline
Loc: Owensboro, Ky.
I think this will be an easy hook up.
#1809410 - 07/10/09 12:09 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
Georges93LX Offline
Loc: Owensboro, Ky.
To Quickcrownvic: Why did you use an alluminum flywheel verses a iron or steel?
#1809509 - 07/10/09 03:25 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
I went with aluminum for a few reasons; so the engine revs faster, the heatsink qualities of aluminum, and to remove some weight from the car. It does get through each gear a little faster at WOT and it weighs lots less than the steel I was using before. Rev matching in turns is more fun now.
I thought it would make normal driving more difficult compared to steel, but I honestly didn't notice much difference in the way it accelerates from a stop. I think the 5.4 engine paired with 4.10 gears lessens the downsides of aluminum for a street car.
I experienced a billet steel flywheel with my previous clutch. I have no complaints about the steel, it was nice, but if I needed to buy a new flywheel tomorrow, it would be aluminum again.
'07 P71 - Stock
#1809514 - 07/10/09 04:44 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Quickcrownvic]
hotrodjcc Offline
Loc: DFW, TX
bjorkmae could help out alot on a standard 5.4 swap though he quickly went to a vortech setup
98 cv lx. -sold
#1809515 - 07/10/09 04:46 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: wanderer]
hotrodjcc Offline
Loc: DFW, TX
I would go with the kooks longtubes but I see no reason why the FFRP shorties would not work, I have them on my 98 with no problems
98 cv lx. -sold
2 registered (SpitShine_PL, SDHOUHK07), 44 Guests and 87 Spiders online.
Old_Guy_Stu 100
bluejay_32 97
Dmblanch 73
a_d_a_m 59
RF_Overlord 45
GM_Guy 44
Moby_Vic 33
Tenevic_P71 33
SocalSam 32
Ponyguy 32
