Page 2 of 98 < 1 2 3 4 97 98 >
#1795914 - 06/21/09 02:12 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: troyco]
hotrodjcc Offline
Loc: DFW, TX
 Originally Posted By: troyco
i have a question....what kind of mods need to be done to the windshield wiper housing for clearance? anyone have pics?
I believe the wiper box clearing problems is with the 5.4 dohc engine. I have not heard of this clearance problem with a 2v, but the trimming you talk about it just trimming a bit off the underside of the box
98 cv lx. -sold
2003 Cobra: cold air, catback,2.8in pulley, O/R upr x pipe,Accufab TB/Plenum and hurst shifter only. #5983
2014 Jeep Cherokee 5.7
2008 F-250 King Ranch 6.4 Spartan and deleted
http://www.facebook.com/home.php?#/profile.php?id=576101863&ref=profile
#1795917 - 06/21/09 02:26 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: 2004_p71]
prodigalson Offline
Loc: Cleveland, OH USA
I agree the HVAC chamber could be a problem, especially if swapping the 5.4 DOHC. The brake booster might need to be downsized as well to clear the DOHC heads. At least that's what I'm looking at.
I don't know about the wiper cowl clearance but i wish my wipers were lower. Sounds like a conflict of interest with a bigger engine, but i dont like being able to see them in the park position from inside the vehicle. Those things are going to mess up my aero-drag, man.
Permanently banned.
#1796747 - 06/22/09 05:07 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: prodigalson]
95crwnvic54 Offline
Loc: Hillbillyville,KY
Nice write up!
#1797183 - 06/23/09 09:24 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: 95crwnvic54]
crown_vic_driver Offline
Loc: High Point, NC
Got this off-line. Thought I would add for people who plan on getting their engines from another vehicle.
5.4 L
The 5.4 L (5408 cc, 330 CID) V8 is a member of the Modular engine family first introduced in the redesigned 1997 Ford F-150 as a Triton V8. The 5.4 L is built in Windsor, Ontario at the Windsor Engine plant. The engine has been available in three different configurations since its 1997 introduction:
* SOHC 2-valve
* SOHC 3-valve with VCT
* DOHC 4-valve
2-valve
* 1997–2004 Ford F-Series, 2-valve SOHC, 260 hp (194 kW) and 350 lb·ft (475 N·m) ratings for 1999 and later model years
* 1997–2004 Ford Expedition, 2-valve SOHC, 260 hp (194 kW) and 350 lb·ft (475 N·m) ratings for 1999 and later model years
* 1997–present Ford E-Series, 2-valve SOHC, 255 hp (190 kW) and 350 lb·ft (475 N·m) ratings for 1999 and later model years
* 1999–2004 Ford SVT Lightning, 2-valve SOHC, Supercharged, 380 hp (283 kW) and 450 lb·ft (610 N·m) ratings for 2001 and later model years
3-valve
* 2003–2005 Ford Fairmont, 3-valve SOHC, 295 hp (220 kW) and 347 lb·ft (470 N·m)
* 2003–2004 Ford Fairlane G220, 3-valve SOHC, 295 hp (220 kW) and 347 lb·ft (470 N·m)
* 2004–2008 Ford F-Series, 3-valve SOHC, 300 hp (224 kW) and 365 lb·ft (495 N·m)
* 2005–present Ford Expedition, 3-valve SOHC, 300 hp (224 kW) and 365 lb·ft (495 N·m)
* 2005–present Lincoln Navigator, 3-valve SOHC, 300 hp (224 kW) and 365 lb·ft (495 N·m)
* 2005–2007 Ford Fairlane G8, 3-valve SOHC, 309 hp (230 kW) and 369 lb·ft (500 N·m)
* 2006–2007 Ford Fairmont, 3-valve SOHC, 309 hp (230 kW) and 369 lb·ft (500 N·m)
* 2009 Ford F-Series, 3-valve SOHC, 320 hp (239 kW) and 390 lb·ft (529 N·m) ratings on e85 biofuel
4-valve
* 1999–2004 Lincoln Navigator, 4-valve DOHC, 300 hp (224 kW) and 355 lb·ft (481 N·m)
* 2000 Ford Mustang SVT Cobra R, 4-valve DOHC, 385 hp (287 kW) and 385 lb·ft (522 N·m)
* 2002–2005 Ford Falcon XR8, 4-valve DOHC, 349 hp (260 kW) and 369 lb·ft (500 N·m)
* 2005–2006 Ford GT, 4-valve DOHC, Aluminum Block, Supercharged, 550 hp (410 kW) and 500 lb·ft (678 N·m)
* 2006 Ford Falcon FPV GT, 4-valve DOHC, 389 hp (290 kW) and 384 lb·ft (521 N·m)
* 2007–2009 Ford Shelby GT500, 4-valve DOHC, Supercharged, 500 hp (373 kW) and 480 lb·ft (651 N·m) SAE J1349 certified
* 2007 Ford Falcon FPV GT Cobra, 4-valve DOHC, 405 hp (302 kW) and 398 lb·ft (540 N·m)
* 2008 Ford Falcon FPV GT, 4-valve DOHC, 422 hp (315 kW) and 406.5 lb·ft (551 N·m)
* 2010 Ford Shelby GT500, 4-valve DOHC, Supercharged, 540 hp (403 kW) and 510 lb·ft (691 N·m)
1999 Ford Crown Victoria P73
3.27 gears, aluminum driveshaft, Dual Delta 40-series Flowmaster Exhaust without H-Pipe, Tint, new upgraded PI intake manifold, Michelin Defender Tires
2005 Dodge Ram 1500 Crew Cab
1966 Ford Galaxie 500 2 Door Hardtop Fastback - 390 FE Motor
#1798827 - 06/25/09 04:07 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Bondfreak13]
nickmckinney Offline
Loc: Orlando
 Originally Posted By: Bondfreak13
Some cam Ideas for the 5.4. This was posted in another thread.
http://www.modularheadshop.com/Cams.htm#2V_-_STAGE_2_-_NATURALLY_ASPIRATED_
BTW - that is the cam that Mark Chacon himself designed for his personal 5.4 Expedition.
#1801470 - 06/29/09 08:19 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
Georges93LX Offline
Loc: Owensboro, Ky.
Is a 99 Lightning engine PI or NPI.
1993 Crown Victoria LX. 5.4L Supercharged/6-Speed. SOLD. Black '03 Marauder 300a. SOLD.
If I gave a crap about gas mileage I would own a bicycle. It's time to start shopping.
#1801474 - 06/29/09 08:22 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
Loc: Orlando
PI
#1801575 - 06/29/09 10:53 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
Georges93LX Offline
Loc: Owensboro, Ky.
I bought a a '99 Lightning engine and am seriously considering swapping my Romeo heads with Comp cams and headers over to this engine. The Windsor heads have a been know to blow out spark plugs. Any reason I can't?
#1801720 - 06/30/09 04:32 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
BigJon Offline
the spark plug threads for romeo and windsor heads are 100% the same. it would be a waste of time to swap the heads for that reason.
what i would do is timesert each plug whole and never worry about it again. you would have to probably run a cooler plug to compensate though. maybe not.
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#1801794 - 06/30/09 09:14 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: BigJon]
Loc: Orlando
The threads are different on some Windsor heads. You notice this when full thread plugs are used like NGK. Some Windsors allow the plug threads to protrude into the chamber, I have seen about half a dozen like this now. Here is an article on it:
Windsor Spark Plug Issues
Here is an article showing some issues with Timesert installation. Timeserts do not change the plug heat range or heat conduction.
Timserts
#1801887 - 06/30/09 12:18 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: nickmckinney]
Georges93LX Offline
Loc: Owensboro, Ky.
I wanted to use my COMP 270ah cams but I may be better off to sell the engine and run the Lightning engine stock. Thanks for the links.
#1803175 - 07/01/09 11:40 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: Georges93LX]
MidnightStalker Offline
Loc: Chicagoland area
Just out of curiosity, how much did you pay for the lightning engine? I'm trying to decide between that and a 3 or 4 valve and puting my own forced induction on... eventually.
'96 MGM "Black 'n' Tan"
190k on the clock and still ticking.Optima red-top, custom air box, 80mm MAF, zip tube, 75mm throttle, P/P plenum, Procomp qualifier intake manifold, cat delete, flowmasters(on vacation), underdrive pulleys, A/C eliminator pulley, 190lph fuel pump, 24# injectors, 4R70W trans swap w/ stage 2 j-mod, 10" 3200RPM stall, 3.73 trak-lok, 170* Tstat, Reinhart tune, KYB gas-a-justs, ADDCO rear sway bar
http://www.ADTR.net/
ALL PARTS FOR SALE! PM FOR OFFERS
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2504664#Post2504664
#1803266 - 07/02/09 04:11 AM Re: 5.4 Swap FAQ's (Please Sticky) [Re: 2004_p71]
sikk_vic Offline
i was wondering if i use 4.6 heads do i still need to use adapter plates or can i use all my stock set up
k&n intake stage 2 pi head swap 2 1/2 inch exhaust flow master 40 series mufflers auburn posi 3.73 gear set 2 inch drop in the front 1 1/2 in the rear bilstein shocks all around zex wet kit 100 shot
#1803576 - 07/02/09 03:54 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: MidnightStalker]
Georges93LX Offline
Loc: Owensboro, Ky.
$1325.00
#1803669 - 07/02/09 06:50 PM Re: 5.4 Swap FAQ's (Please Sticky) [Re: sikk_vic]
Loc: Iwakuni, Japan.
Did you even read my First post? The 4.6 and 5.4 heads are the same. The reason why you need the adapter plates is because the 5.4 is wider than the 4.6 so the 4.6 intake isn't wide enough.
Edited by Bondfreak13 (07/02/09 06:51 PM)
1990 Mazda Miata
2000 Toyota Crown Estate Athlete V
1994 Autozam (Mazda) AZ-1 (Kei Car legend)
