#1804034 - 07/03/09 09:57 AM
ENGINE BELT THAT BYPASSES A/C
Loc: USA GA MD
Does anyone know what the dimensions are of an engine belt that bypasses the A/C on a 99 CVPI?
1999 Crown Vic Police Interceptor
#1804150 - 07/03/09 01:14 PM
Re: ENGINE BELT THAT BYPASSES A/C
[Re: BigNSlow]
Loc: Houston, TX
If you did manage to get the right size belt. How would you Install it and put tension on it?
1992 Crown Victoria LX 150K AOD 3.08gears -A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1804189 - 07/03/09 02:28 PM
[Re: IZ1111]
J-MOD Master
Loc: Romulus,MI
If you did manage to get the right size belt. How would you Install it and put tension on it? Uh... The tensioner.
The Jmod video is done! LINK!
#1804376 - 07/03/09 07:32 PM
[Re: Rizzo]
Loc: Cleveland, OH USA
Removing the compressor can be a bit of work and the bypass just becomes another idler. Pretty pointless to have 3 idlers in-line with a tensioner when you can just look for a grooved tensioner pulley and delete the rest. It's much less work IMHO.
Belt lengths are measured in 1/8ths of an inch if that helps too.
Permanently banned.
#1804384 - 07/03/09 07:40 PM
[Re: Rizzo]
Loc: Ohio
If you did manage to get the right size belt. How would you Install it and put tension on it? Uh... The tensioner. LMAO. Unless you want to try deleting that as well. Which should be interesting to watch to say the least. I would defintely try napa the local privately owned shop has been very good to me.
#1804496 - 07/03/09 10:45 PM
[Re: Rizzo]
Loc: Houston, TX
If you did manage to get the right size belt. How would you Install it and put tension on it? Uh... The tensioner. If you bypass the AC pulley completely (which is what the original poster wants to do), then the belt will go straight from the crsnk to alt pulley. How is tension placed when the belt is routed this way? Or is there another way to route the belt so it has tension and doesn't go around the AC pulley?
SOLD!!!!
#1804598 - 07/04/09 12:36 AM
[Re: IZ1111]
Whoa totally disregard what I said earlier I was looking at a Mustang diagram. I have no idea how you would reroute around the A/C on these cars.
Permanently banned.
#1804833 - 07/04/09 01:37 PM
[Re: prodigalson]
Loc: SoCal High Desert
A 3" grooved pulley on the tensioner should be enough, dependent on why you're doing the bypass. It should work temporarily, if, for instance your compressor seized and you need to accumulate money to replace it. As a permanent fix, don't expect miracles. A link to the first place I found on Search: http://www.vortechsuperchargers.com/product.php?p=63Routing would be the same, except when the belt comes around the crankshaft, put it on the outside of the new tensioner pulley, then to the alternator. The original idler pulley won't be doing much. Make sure you allow for tension on the belt when measuring!!! EDIT: Here's a Gates P/N: GATES Part # 38008 {Thermoplastic V-Ribbed 6 Grooved (70mm x 17mm x 25mm)} Grooved Pulley Available at Kragen, at least, and probably NAPA, etc.
Edited by TheShadow (07/04/09 01:51 PM) Edit Reason: Add info
'95 P71, 5xx,xxx miles, Rebuilt tranny, 2.73. Lives as a cab, and will die as a cab. (Died-FrontEnder) '96 P71, 640,xxx on original drivetrain. (Now parts car - T-bone & roll)(You should see the roof - A,B & C-pillars chopped on driver side) New to list: '96 MGM (Nice! @ 35x,xxx), '97 CV P71, '98 CV P71, '00 CV P71, 01 P71 (2 of 'em) '03 CV P71 (Nice so far) (All Ford Zinc Yellow w/Black decals & trim) And the list is growing........... Taxicab mechanic: I HATE DRIVERS!
#1805452 - 07/05/09 03:54 PM
[Re: TheShadow]
Here is a routing we used for another member's 93-99:  It 'worked' The tensioner's effective range will be almost nothing, so the belt will have to be sized just right. A 3" grooved pulley on the tensioner should be enough, dependent on why you're doing the bypass. It should work temporarily, if, for instance your compressor seized and you need to accumulate money to replace it. As a permanent fix, don't expect miracles. A link to the first place I found on Search: http://www.vortechsuperchargers.com/product.php?p=63Routing would be the same, except when the belt comes around the crankshaft, put it on the outside of the new tensioner pulley, then to the alternator. The original idler pulley won't be doing much. Make sure you allow for tension on the belt when measuring!!! I like that, or at least it sounds like it should work well (crank->tensioner (outside)->idler (UNDER)->alt)
#1805650 - 07/05/09 08:55 PM
[Re: dRock96Marquis]
I'm not sure shadows idea would work because of the motion of the tensioner arm. You would almost have to remove the idler and even then I don't think you could get the tensioner to ride properly it would be so close to bottoming out to function properly.
Permanently banned.
#1805652 - 07/05/09 09:00 PM
[Re: prodigalson]
It would be a good idea if the tensioner sprung down instead of up is what I'm saying
Permanently banned.
#1805910 - 07/06/09 09:30 AM
[Re: prodigalson]
Loc: Houston, TX
Thats some great info w/ illustration dRock. Now all we need is the correct length and were in buisness.
SOLD!!!!
3 registered (Bangster, DES, 1 invisible),
63
257
