#1804362 - 07/03/09 07:09 PM PI Motor teardown pics
TaxiDriver Offline
Loc: Seattle
Started disassembly of the $75 PI motor-2003- that I bought from a Hippie
Guides looked pretty good
a little rust in the bores
it had signs of milky oil but I could not determine where from
the head gaskets and oil filter adapter gaskets looked ok
Maybe it was from a bad oil cooler
The heads look good and cams turned easily. I'll know more when I tear into the bottom end. It got too hot today to finish. I might just use the topend on a non pi motor. This will be going into my white 96 P71
94 P71 & 96 P71
#1804386 - 07/03/09 07:41 PM Re: PI Motor teardown pics [Re: TaxiDriver]
prodigalson Offline
Loc: Cleveland, OH USA
I didn't know it got hot in Seattle. 65 too much for ya? had to take your turtleneck off? lol
Seriously nice buy though, I wish I knew some hippies.
Edited by prodigalson (07/03/09 07:42 PM)
Permanently banned.
#1804394 - 07/03/09 07:53 PM Re: PI Motor teardown pics [Re: prodigalson]
98P73_IRAQ Offline
congrats,
great deal,the motoe looks like having 10000 miles only
#1804452 - 07/03/09 09:46 PM Re: PI Motor teardown pics [Re: 98P73_IRAQ]
TaxiDriver Offline
Loc: Seattle
Here are some bonus pics, no extra charge
I want to get my 96 P71 back on the road. It has a rod knocking. I bought this '03 motor because I thought the 03+ has better connecting rods.
94 P71 & 96 P71
#1804506 - 07/03/09 10:58 PM Re: PI Motor teardown pics [Re: TaxiDriver]
IZ1111 Offline
Loc: Houston, TX
Scrap the block and use the heads for a compression bumb. Or give them to me! I want some PI. Unbelievable purchace.
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1804574 - 07/04/09 12:02 AM Re: PI Motor teardown pics [Re: TaxiDriver]
Raybo Offline
Loc: Clearwater, Florida
Holy sh*t that block is clean!!!!! You F'ed that guy in the A!!!
Sig removed. Read the rules.
#1804611 - 07/04/09 12:48 AM Re: PI Motor teardown pics [Re: Raybo]
CVcamel Offline
Loc: midwest
Very nice, thanks for the pics.
06 CVPI...stock
#1804668 - 07/04/09 04:12 AM Re: PI Motor teardown pics [Re: prodigalson]
TechnoWeenie Offline
Loc: The perimeter
It doesnt.... \:D
82 degrees with 0 humidity and they cry murder...
It's heaven compared to the 100+ degrees and 80% humidity I used to experience..
#1804739 - 07/04/09 09:33 AM Re: PI Motor teardown pics [Re: TechnoWeenie]
I assume that the engine was proven not able to turn over as you had mentioned on the previous thread.
2004 Crown Vic LX SOLD!!
#1804791 - 07/04/09 11:52 AM Re: PI Motor teardown pics [Re: Chevyguy]
TaxiDriver Offline
Loc: Seattle
The previous owner said that it would turn over a little and then lock up. It did it to me once but I was able to rock it with a tire bar on the crank and it freed up. It must have been the surface rust in the bores. Maybe I will hone and ring it. Now I will start to teardown the 95 NPI that I originaly bought for the swap for $200 to determine which bottom end is better. I am leaning towards the NPI shortblock with the PI topend and using the best chains and guides. The PI guides looked good. I am getting more comfortable working on these motors. I was a bit reluctant to work on computerized fuel injected modern engines with wires and hoses everywhere with metric bolts. I have always been a brand X mechanic but I must say working on these is pretty straight forward. I really like the bolts they use. You just crack them and spin them out by hand. Most 30+ year old stuff I have worked on has stiff bolts that you have to fight. Who knows I might be ready to tackle the J-Mod soon. And where are all you heat lovers that want to help me wrench on the motor in this unbelieveably hot scorching 85 degrees blazing hot afternoon sun?? Thats a joke son. Can't you see there is no shop. This is redneck auto repair style.
94 P71 & 96 P71
#1804824 - 07/04/09 12:58 PM Re: PI Motor teardown pics [Re: TaxiDriver]
98P73_IRAQ Offline
i have 1000 bucks but it will cost me 10000 to ship this to iraq....dam
#1804864 - 07/04/09 02:54 PM Re: PI Motor teardown pics [Re: 98P73_IRAQ]
interceptor1985 Offline
Loc: OREGON
Daaaaamn Perhaps if I found deals like that in Seattle I'd drive there more often;) How about a set of E7 heads from a mustang or some other HO 5.0...How about a 5.4 short block for my 99???...lol Thats a great deal you got:) nice pics.
#1804908 - 07/04/09 04:50 PM Re: PI Motor teardown pics [Re: interceptor1985]
vicfan_00 Offline
Loc: Quad Cities,IL
I'd throw the entire new one in the 96. just throw in some new bearings in the bottom end, get the crank checked out and your good to go.
http://www.supermotors.net/17311
2000 CVPI 118K miles (6/2013). Steeda UDs,EMP Water Pump,Ported Plenum,FRPP 70MM TB,PI Intake,
PI cams,180 stat,NGK TR6IX Iridiums,3500 stall converter from Darrin,Dual Trans Coolers,
J-Mod,MMX Driveshaft,3.55 with T-lok,Full Magnaflow Exhaust,Marauder Cluster,
Console with floor shift. 14.9 with no tune.SOLD 11/14
Living vicariously through brothers 93 and 03
Currently in the garage- 2011 edge, 62 t-bird.
#1804968 - 07/04/09 08:30 PM Re: PI Motor teardown pics [Re: vicfan_00]
TaxiDriver Offline
Loc: Seattle
Got the PI shortblock oiled up and turning freely
Car waiting for its new motor . I drove it about 10 miles today with the bad motor but it sure was knocking and misfiring.
This is the 95 NPI engine, not nearly as clean
Old style crappy intake-I have two of these extra if somebody needs
Redneck motor shop
I wanted to get the tranny off but I stripped a bolt so I gave for today. I don't yet know which bottom end to use. I'll keep ya post when I strip the two lower ends. Just gotta get the car going cause I don't like driving the tow truck everywhere.
I find good deals all the time. Let me know what you need.
94 P71 & 96 P71
#1805098 - 07/05/09 01:09 AM Re: PI Motor teardown pics [Re: TaxiDriver]
capt512 Offline
Loc: KC, MO
$75!! I woulda bought that for the newer style intake alone!!
2001 CVPI - Ex-Kansas Turnpike Authority (Sold)
2000 CVPI - Ex-Kansas Turnpike Authority
2003 Marauder (300A)
2006 CVPI - Ex-NJ Airport Police 55k Miles
#1805433 - 07/05/09 03:33 PM Re: PI Motor teardown pics [Re: capt512]
vicfan_00 Offline
Loc: Quad Cities,IL
I dont blame you on the truck, we have a 76 300 with duallys and I hate driving that thing.
#1805565 - 07/05/09 07:12 PM Re: PI Motor teardown pics [Re: capt512]
RWDForever Offline
Loc: Mercedes Stadium
Is that an old underwear covering up the license plate ?
1995 GM/LS -- 364K miles, engine rebuilt in my garage at 310K miles, 3rd plastic intake, 4th steering box, 2nd front suspension rebuild. MODS:1998 transmission, 1996 PCM, 1996 engine/trans wiring harness spliced in. A/C compressor cutoff dash switch, leather seats recovered with NOS cloth, dash switch for heater core shutoff valve. HPP springs installed front, police springs installed rear. 1997 steering box upgrade. My clearcoat is peeling off.
1992 Taurus LX -- 108k miles, added transmission cooler. Rear heavy duty springs.
#1805566 - 07/05/09 07:17 PM Re: PI Motor teardown pics [Re: RWDForever]
Loc: OREGON
wtf????? where?
#1805656 - 07/05/09 09:13 PM Re: PI Motor teardown pics [Re: interceptor1985]
TaxiDriver Offline
Loc: Seattle
Update: I tore down the 95 NPI motor today. Everything looked good. I could still see all of the cross hatch hone marks. However it was not nearly as clean as the PI motor. I have decided to do the NPI shortblock with the PI heads, cams and intake. Although I am not sure what is involved in swapping the heater water tube that runs through the valley. I will save the PI shortblock for another project. The car has 3.27 gears so it should be fairly powerful, I hope. I will post a new threads when I begin the build up. Looks like there is alot of clean up work to be done first. As far as the rag covering the license plate, no thats not my old underwear but if you really need some, I think Sears is having a sale.
94 P71 & 96 P71
#1805850 - 07/06/09 07:03 AM Re: PI Motor teardown pics [Re: TaxiDriver]
mustang_zulu Offline
I am not
Loc: Garland, TX
these guys sure unlocked some sick HP from a junkyard 4.6L. might be some good reading for you. of course the intake system they use is CRAP!!!! look what made the best power for them with the less amount of $$$ the route ur going is in the right direction for sure!!!
http://www.hotrod.com/techarticles/engine/hrdp_0804_ford_4_6_engine/index.html
5 registered (55sunliner, professorP7B, Preston03LSE, GRMN_CV, 1 invisible), 90 Guests and 276 Spiders online.
bluejay_32 308
a_d_a_m 240
Rainbowpizza 186
DudeAbides 146
JeffBoudah 110
Moby_Vic 106
Old_Guy_Stu 89
Bangster 68
BigNSlow 56
2004_p71 56
