Page 2 of 2 < 1 2
#1805433 - 07/05/09 03:33 PM Re: PI Motor teardown pics [Re: capt512]
vicfan_00 Offline
Loc: Quad Cities,IL
I dont blame you on the truck, we have a 76 300 with duallys and I hate driving that thing.
http://www.supermotors.net/17311
2000 CVPI 118K miles (6/2013). Steeda UDs,EMP Water Pump,Ported Plenum,FRPP 70MM TB,PI Intake,
PI cams,180 stat,NGK TR6IX Iridiums,3500 stall converter from Darrin,Dual Trans Coolers,
J-Mod,MMX Driveshaft,3.55 with T-lok,Full Magnaflow Exhaust,Marauder Cluster,
Console with floor shift. 14.9 with no tune.SOLD 11/14
Living vicariously through brothers 93 and 03
Currently in the garage- 2011 edge, 62 t-bird.
#1805565 - 07/05/09 07:12 PM Re: PI Motor teardown pics [Re: capt512]
RWDForever Offline
Loc: Mercedes Stadium
Is that an old underwear covering up the license plate ?
1995 GM/LS -- 364K miles, engine rebuilt in my garage at 310K miles, 3rd plastic intake, 4th steering box, 2nd front suspension rebuild. MODS:1998 transmission, 1996 PCM, 1996 engine/trans wiring harness spliced in. A/C compressor cutoff dash switch, leather seats recovered with NOS cloth, dash switch for heater core shutoff valve. HPP springs installed front, police springs installed rear. 1997 steering box upgrade. My clearcoat is peeling off.
1992 Taurus LX -- 108k miles, added transmission cooler. Rear heavy duty springs.
#1805566 - 07/05/09 07:17 PM Re: PI Motor teardown pics [Re: RWDForever]
interceptor1985 Offline
Loc: OREGON
wtf????? where?
#1805656 - 07/05/09 09:13 PM Re: PI Motor teardown pics [Re: interceptor1985]
TaxiDriver Offline
Loc: Seattle
Update: I tore down the 95 NPI motor today. Everything looked good. I could still see all of the cross hatch hone marks. However it was not nearly as clean as the PI motor. I have decided to do the NPI shortblock with the PI heads, cams and intake. Although I am not sure what is involved in swapping the heater water tube that runs through the valley. I will save the PI shortblock for another project. The car has 3.27 gears so it should be fairly powerful, I hope. I will post a new threads when I begin the build up. Looks like there is alot of clean up work to be done first. As far as the rag covering the license plate, no thats not my old underwear but if you really need some, I think Sears is having a sale.
94 P71 & 96 P71
#1805850 - 07/06/09 07:03 AM Re: PI Motor teardown pics [Re: TaxiDriver]
mustang_zulu Offline
I am not
Loc: Garland, TX
these guys sure unlocked some sick HP from a junkyard 4.6L. might be some good reading for you. of course the intake system they use is CRAP!!!! look what made the best power for them with the less amount of $$$ the route ur going is in the right direction for sure!!!
http://www.hotrod.com/techarticles/engine/hrdp_0804_ford_4_6_engine/index.html
Page 2 of 2 < 1 2
1 registered (DES), 61 Guests and 258 Spiders online.
CrystalPistol 365
bluejay_32 309
a_d_a_m 224
Rainbowpizza 185
DudeAbides 153
JeffBoudah 120
Moby_Vic 106
Old_Guy_Stu 78
Bangster 61
BigNSlow 60
