#1804034 - 07/03/09 09:57 AM ENGINE BELT THAT BYPASSES A/C
Interceptor99 Offline
Loc: USA GA MD
Does anyone know what the dimensions are of an engine belt that bypasses the A/C on a 99 CVPI?
1999 Crown Vic Police Interceptor
#1804150 - 07/03/09 01:14 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: BigNSlow]
IZ1111 Offline
Loc: Houston, TX
If you did manage to get the right size belt. How would you Install it and put tension on it?
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1804189 - 07/03/09 02:28 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: IZ1111]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Uh... The tensioner.
The Jmod video is done! LINK!
#1804376 - 07/03/09 07:32 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: Rizzo]
prodigalson Offline
Loc: Cleveland, OH USA
Removing the compressor can be a bit of work and the bypass just becomes another idler. Pretty pointless to have 3 idlers in-line with a tensioner when you can just look for a grooved tensioner pulley and delete the rest. It's much less work IMHO.
Belt lengths are measured in 1/8ths of an inch if that helps too.
Permanently banned.
#1804384 - 07/03/09 07:40 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: Rizzo]
Nomad8326 Offline
Loc: Ohio
LMAO. Unless you want to try deleting that as well. Which should be interesting to watch to say the least.
I would defintely try napa the local privately owned shop has been very good to me.
#1804496 - 07/03/09 10:45 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: Rizzo]
IZ1111 Offline
Loc: Houston, TX
If you bypass the AC pulley completely (which is what the original poster wants to do), then the belt will go straight from the crsnk to alt pulley. How is tension placed when the belt is routed this way? Or is there another way to route the belt so it has tension and doesn't go around the AC pulley?
SOLD!!!!
#1804598 - 07/04/09 12:36 AM Re: ENGINE BELT THAT BYPASSES A/C [Re: IZ1111]
prodigalson Offline
Whoa totally disregard what I said earlier I was looking at a Mustang diagram. I have no idea how you would reroute around the A/C on these cars.
Permanently banned.
#1804833 - 07/04/09 01:37 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: prodigalson]
TheShadow Offline
Loc: SoCal High Desert
A 3" grooved pulley on the tensioner should be enough, dependent on why you're doing the bypass. It should work temporarily, if, for instance your compressor seized and you need to accumulate money to replace it. As a permanent fix, don't expect miracles.
A link to the first place I found on Search:
http://www.vortechsuperchargers.com/product.php?p=63
Routing would be the same, except when the belt comes around the crankshaft, put it on the outside of the new tensioner pulley, then to the alternator. The original idler pulley won't be doing much. Make sure you allow for tension on the belt when measuring!!!
EDIT:
Here's a Gates P/N:
GATES Part # 38008 {Thermoplastic V-Ribbed 6 Grooved (70mm x 17mm x 25mm)} Grooved Pulley
Available at Kragen, at least, and probably NAPA, etc.
Edited by TheShadow (07/04/09 01:51 PM)
Edit Reason: Add info
#1805452 - 07/05/09 03:54 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: TheShadow]
Here is a routing we used for another member's 93-99:
It 'worked'
The tensioner's effective range will be almost nothing, so the belt will have to be sized just right.
I like that, or at least it sounds like it should work well (crank->tensioner (outside)->idler (UNDER)->alt)
#1805650 - 07/05/09 08:55 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: dRock96Marquis]
prodigalson Offline
I'm not sure shadows idea would work because of the motion of the tensioner arm. You would almost have to remove the idler and even then I don't think you could get the tensioner to ride properly it would be so close to bottoming out to function properly.
Permanently banned.
#1805652 - 07/05/09 09:00 PM Re: ENGINE BELT THAT BYPASSES A/C [Re: prodigalson]
prodigalson Offline
It would be a good idea if the tensioner sprung down instead of up is what I'm saying
Permanently banned.
#1805910 - 07/06/09 09:30 AM Re: ENGINE BELT THAT BYPASSES A/C [Re: prodigalson]
IZ1111 Offline
Loc: Houston, TX
Thats some great info w/ illustration dRock. Now all we need is the correct length and were in buisness.
SOLD!!!!
4 registered (Davidzq, 02_LSE, Bangster, bluejay_32), 84 Guests and 284 Spiders online.
bluejay_32 302
a_d_a_m 240
Rainbowpizza 186
DudeAbides 146
JeffBoudah 110
Moby_Vic 105
Old_Guy_Stu 89
Bangster 68
2004_p71 56
BigNSlow 56
