#1809356 - 07/09/09 11:05 PM limiter speed
dmitriy Offline
Loc: kherson,ukraine
how to remove the speed limiter?
fcv 1992
#1809358 - 07/09/09 11:05 PM Re: limiter speed [Re: dmitriy]
BigJon Offline
you will need a tune
-Current:
2001 Crown Victoria P74
-Gone, but not forgotten:
1988 Mercury Grand Marquis
1994 Ford Crown Victoria
2000 Ford Crown Victoria HPP
2004 Mercury Grand Marquis
#1809379 - 07/09/09 11:24 PM Re: limiter speed [Re: dmitriy]
larryo340 Offline
Loc: Long Island
'92 shouldn't have a limiter. At least the '92 MGM that I had didn't have one. I think the first year for the limiters is when OBD II started in '95.
MOD List for MGM
...Marquis sold frown
#1809404 - 07/09/09 11:57 PM Re: limiter speed [Re: BigNSlow]
daverbmxer Offline
Loc: ND
Any idea on what they will do then? Just curious, I'm happy at 75 though. =)
2000 Mercury Grand Marquis
#1809452 - 07/10/09 01:01 AM Re: limiter speed [Re: daverbmxer]
eugene13087 Offline
When you hit the limiter, it kicks the throttle out from under you. In other words, it would be just like removing your foot from the pedal. I have a '94; at 107, you hit the governor. The car drops to about 103 before you are able to stop slowing down. I got her to 109 once. I was going 100, and floored it. The engine roared and she started accelerating. At 107, it kicked out the throttle, but the drive train still had enough inertia to get her to 109 before she slowed down.
For the record, I did this on the I-5 in the Central Valley of CA. There were no cars close, nor people or buildings. There were cops ahead, I was sure, but luckily a silver Benz convertible had blown by at 120+ with no signs of slowing down. I passed him about 15 minutes later, pulled over on the sign of the road, a Crown Vic behind him.
#1809476 - 07/10/09 01:38 AM Re: limiter speed [Re: eugene13087]
daverbmxer Offline
Loc: ND
Is a speed limiter not the same as a governor? Kind of curious what these cars would hit non governed.
#1809513 - 07/10/09 04:25 AM Re: limiter speed [Re: daverbmxer]
mustang_zulu Offline
I am not
Loc: Garland, TX
you can change th PCM??? P71 PCM's in cars that had 3.27 RAR should have a 135 limiter, P71's that have a 3.55 RAR shouldhave a 120 limiter....
#1809522 - 07/10/09 05:54 AM Re: limiter speed [Re: mustang_zulu]
dmitriy Offline
not so simple
I have on my cv - civilian-1 is
box aod, as far as I know it is not reset.
I thought that there are simple solutions in America.
in ukraine are not found
#1809573 - 07/10/09 08:28 AM Re: limiter speed [Re: dmitriy]
stalag Offline
Loc: Columbus, OH
Dmitriy,
The vehicles as produced by Ford for the general public have a speed limiter (usually) because the aerodynamics of the car cause it to lift off the ground north of 120 MPH. This makes the vehicle unstable above those speeds because of lack of tire contact. You can remove the governors in the vehicles in older vehicles or if the vehicles are computer controlled the limiter is in the computer of the vehicle. A computer designed limiter requires tuning software to remove. There are no other options here.
Stalag
#1809766 - 07/10/09 02:38 PM Re: limiter speed [Re: stalag]
dmitriy Offline
Now everything is clear
thank you very much
but now the question-and who knows how to programirovat ecu
#1809767 - 07/10/09 02:40 PM Re: limiter speed [Re: dmitriy]
dmitriy Offline
and can substitute for p71 ecu from 1992?
#1809804 - 07/10/09 04:04 PM Re: limiter speed [Re: dmitriy]
IZ1111 Offline
Loc: Houston, TX
So removing the governer removes the limiter? Is this right?
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1809822 - 07/10/09 04:31 PM Re: limiter speed [Re: IZ1111]
stalag Offline
Loc: Columbus, OH
a governor is a mechanical speed limiter. Not used on ODB II vehicles.
#1809841 - 07/10/09 04:59 PM Re: limiter speed [Re: dmitriy]
You have an AOD 92 so you need an early AOD PCM from a Police model. Perhaps one of the boys here can locate you one, I can check in my junkyard travels.
By the way the 92 Police models have the P-72 VIN code as they are fleet models with the Police Package. Starting in 93 the seperate P-71 VIN coded model was introduced.
2004 Crown Vic LX SOLD!!
#1810056 - 07/10/09 11:07 PM Re: limiter speed [Re: Chevyguy]
dmitriy Offline
all right
I have a police pacet-2 exhaust and 4 disc brakes
but is restrictive. 2facp72wxnx176717
The idea of the p71 ecu with knew a long time, but we are in Ukraine and this machine is a rare
You can order spare parts. but they offer 3 options, s afraid of mistakes with the choice of
Edited by dmitriy (07/10/09 11:15 PM)
