Page 1 of 4 1 2 3 4 >
#1824705 - 07/28/09 12:36 PM Headlight Alignment
Snik Offline
Loc: Minneapolis, MN
Sorry if this has been posted in the past... I searched and could not find it.
How do I adjust the left headlight beam only down? I'll use my garage door to see the beams. Thanks
2003 Ford Crown Victoria
#1824712 - 07/28/09 12:43 PM Re: Headlight Alignment [Re: Snik]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Well there are only two adjusting screws.
One is for in and out and the other is for up and down .
Add year and model to your sig. It will save you having to answer that in the future.
The Jmod video is done! LINK!
#1824719 - 07/28/09 12:46 PM Re: Headlight Alignment [Re: Rizzo]
Snik Offline
Ooops sorry
2003 Crown Vic
#1824970 - 07/28/09 06:25 PM Re: Headlight Alignment [Re: Snik]
jaybird Offline
Loc: San Jose Ca.
u will need the adjustment tool, I bought mine @ carquest
Iforget what its called now?
2000 CV LX HPP Loaded 3.55 RAR SOLD @ 191k MILES / Modified K&N CAI FIPK w/ Lower Inlet / Magnaflow 12255 Mufflers / KYB Gas A Just Shocks / Rear Coil Spring Conversion / 18" Mustang Fanblades! 1.5" Hubcentric Spacers / Michelin Pilot HXMX M4 235/50/18 Tires / Hawk HPS Brake Pads F&R / SilverStar Light Bulbs
#1827081 - 07/31/09 12:00 PM Re: Headlight Alignment [Re: jaybird]
Bigrick31 Offline
Loc: Nor*Cal
1. Headlights have two spring-loaded adjusting screws, one on the top controlling up and down movement and one on the side controlling left and right movement. on 92 and later models the adjusters are reached from the rear of the headlight assembly and are turned using a small wrench or pliers.
2. There are several methods of adjusting the headlights. The simplest method requires a blank wall 25 feet in front of the vehicle and a level floor.
3. Position masking tape vertically on the wall in reference to the vehicle center line and the center lines of both headlights.
4. Position a horizontal tape line in reference to the center line of all the headlights.
5. adjustment should be made with the vehicle sitting level, the gas tank half full and no unusually heavy load in the vehicle.
6. Starting with the low beam adjustment, position the high intensity zone so it is two inches below the horizontal line and two inches to the side of the headlight vertical line away from oncoming traffic. Adjustment is made by turning the top adjustment screw clockwise to raise the beam and counterclockwise to lower the beam. The adjusting screw on the side should be used in the same manner to move the beam left or right.
7. With the high beams on, the high intensity zone should be vertically centered with the exact center just below the horizontal line. It may not be possible to position the headlight aim exactly for both high and low beams. If a compromise must be made, keep in mind that the low beams are the most used and have the greatest effect on safety.
Edited by Bigrick31 (07/31/09 12:07 PM)
2000 CVPI
Build Log
#1827186 - 07/31/09 02:42 PM Re: Headlight Alignment [Re: Bigrick31]
GaryinVT Offline
Loc:
I use a tiny 4mm box wrench that I got in a Craftsman Mini-Wrench Pack. Using pliers would suck, and tear up the hex head.
#2195821 - 12/08/10 12:47 PM Re: Headlight Alignment [Re: GaryinVT]
Ponyguy Offline
Loc: Oswego, IL
PLEASE don't even give anyone that idea! Using pliers on a hex head is cruel and unusual punishment... \:\(
Sig removed. Read the rules.
My transportation sources:
#2195864 - 12/08/10 02:15 PM Re: Headlight Alignment [Re: Ponyguy]
coldfusion11 Offline
n00b pwn
Loc: Rochester Hills, MI
x78437234782334 on that. Only should be used when ABSOLUTE necessary. Which is usually when someone else had used pliers and rounded off the nut.
2002 CV P73
#2196166 - 12/09/10 01:39 AM Re: Headlight Alignment [Re: coldfusion11]
ClassBuddy Offline
Loc: US
My 09 mgm has had headlight problems from day one. Ford can't get them align right, so they say that is the way they are suppose to be. I wrote Ford, & they said they would look into it. I guess they are still looking into it.
The problem is that they lo beams are great, but the hi beams are useless. All they seam to do is shine up into the sky & make the road look foggy. You can actually see farther down the road with the lo beams. But Ford doesn't seem to care, as so far they have done nothing to fix it.
2009 Grand Marquis
#2196201 - 12/09/10 05:18 AM Re: Headlight Alignment [Re: ClassBuddy]
Summerwind Offline
Loc: Iowa, Linn CO
Class, sorry to hear that.. \:\( My '08 GMQ has some of the best headlights on a car that I have had..low beams go out well, the first time I hit the high beams, I thought I'd lit up a set of arc lamps!!! They go FAR down the road..I was amazed especially for "standard" headlights. I also never get anyone flashing me on low beams, so they must have been adjusted right from the factory. I hope you get yours fixed!!
"Moya" '08 Merc GMQ Dual exhaust/H-Pipe, Flowmaster Delta 40's, 80mm MAF, '07 Interceptor airbox, '07 Interceptor Zip tube, 89 octane tune from BOC, Alpine 500 watt amp, 12" subwoofer 55k mi
And since the mods cant decide on "what" pics are "legal" there aint one
#2648503 - 01/02/13 01:45 AM Re: Headlight Alignment [Re: ClassBuddy]
roadblockp71 Offline
Loc: Washington, USA
I brought my '02 CVI to Ford just the other day and asked them to adjust my right headlight as it shown down since installed. They managed to raise it a tiny fraction. Today I finally got it to where I wanted it. Ford wasn't that helpful. The tech didn't even put the plastic cover over the radiator in right and closed the hood on it.
*Note: Ground Search and Rescue Equipment Installed*
#2648792 - 01/02/13 07:04 PM Re: Headlight Alignment [Re: roadblockp71]
brownie Offline
Loc: Texas
Sounds like DIY.
Edited by brownie (01/02/13 07:06 PM)
Edit Reason: Change line position
#2649112 - 01/03/13 12:31 PM Re: Headlight Alignment [Re: Snik]
00MGMLS Offline
#2649878 - 01/04/13 10:03 PM Re: Headlight Alignment [Re: 00MGMLS]
PHoganDive Offline
Loc: Mass, USA
Originally Posted By: 00MGMLS
I have that tool...One thing to be careful of with that tool is not to unscrew the adjuster so far you can't get the tool off the end of the stud. The tool is a ratchet, and only goes one way (you flip it over to adjust the other direction). The adjusting stud can get unscrewed close enough to the body panel behind the headlight that you can't get the tool off, without removing the headlight clip, to remove the headlight for extra clearance.
I had this happen on the side of the road at night (when else would you adjust them?), and ended up having to drive home with the tool still attached to the stud, as I couldn't see well enough to undo the headlight clip on the side of the road.
#2933530 - 11/25/15 02:07 PM Re: Headlight Alignment [Re: Snik]
Consalam_NJ Offline
Loc: New Jersey
Update: to adjust the headlight beam up, you turn the top adjustment screw COUNTER-clockwise, not clock-wise. So:
UP = Counter-Clockwise
DOWN = Clock-Wise
Just take your time and it's really very simple to do the adjustment.
2007 CVPI
106K Miles
PA Trooper Car - Retired
Just Getting Started...
18" Fan Blades with 255/45's all around
Rockville 2Din with 12"Sub
Explorer Center Console
Bi-Xenon HID's and LED's Everywhere Else
Bumper Tuck
K&N Filter
Future Mods:
Thrush Welded Mufflers with 3" Stainless Polished Tips
Upgraded Lighting Harness
Tint
Badgeless Grill
RIP "Eddie" - 2006 CVPI - May 2017
108k Miles
Former PA Cruiser
Interior/Exterior LED lighting
Rear Bumper Tuck
K&N Filter
Headlight Wiring Harness Mod with 35W HID's
Ford CD Radio Upgrade with Aux Connection / Hands Free
Rampage Center Console
3 registered (Tenevic_P71, Old_Guy_Stu, 1 invisible), 86 Guests and 283 Spiders online.
bluejay_32 159
CrystalPistol 97
Old_Guy_Stu 87
a_d_a_m 79
TheCableGuy 54
Moby_Vic 52
DudeAbides 51
Bangster 49
Ponyguy 46
RF_Overlord 42
