#1846361 - 08/26/09 05:56 PM Putting a fuel cell in the trunk?
Bigrick31 Offline
Loc: Nor*Cal
With the addition of my cars new rear end its come to my attention that I can no longer drop my gas tank without first taking out the IRS. For this reason i would like to remove my stock gas tank and add a fuel cell in my trunk. I dont know that much about how the fuel system works in a car but I keep hearing that I need to use my stock sending unit however in order to do that it needs to be mounted in the same position it is now which is sideways. I would like to have a fuel cell with the sending unit sitting on top. I know people who build fuel cells so i can get one that fits nicely into my trunk but I would like to know if i want my sending unit mounted on top of the fuel cell what will I need to do? Im guessing buy an aftermarket sending unit and probably change out a bunch of other stuff in the car as well if someone could explain the process to me and recommend some quality parts id really appreciate it.
2000 CVPI
Build Log
#1846982 - 08/27/09 11:18 AM Re: Putting a fuel cell in the trunk? [Re: Bigrick31]
Bigrick31 Offline
Loc: Nor*Cal
Anyone?
2000 CVPI
Build Log
#1847214 - 08/27/09 04:45 PM Re: Putting a fuel cell in the trunk? [Re: Bigrick31]
RocketCouch Offline
User
Loc: So Cal
I use an aftermarket Jaz tank in the RocketCouch with a fuel sending unit built into it. I made a mount on to keep the tank level so it always has a constant supply of fuel going to the sump.
Here's some pics of mine:
Making the stock sending unit work with an aftermarket or custom cell will need modification. I don't even think that anyone that has done a fuel cell would even bother with the stock sending unit.
I know your buddy can make a tank but if you need any fuel system parts please let me know \:\)
#1847563 - 08/28/09 01:18 AM Re: Putting a fuel cell in the trunk? [Re: RocketCouch]
CVPI_GT Offline
How low is too low?
Loc: Richmond Va
Chris i didn't know you were running nitrous. And i think a fuel cell would be cool.
Phillip, December 2012 POTM Winner http://tinyurl.com/px2ufby
1992 Ford Crown Victoria S,
Suspension Mods https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2603760#Post2603760
Wheels & Tires https://www.crownvic.net/ubbthreads/ubbth...mp;#Post2606379
#1847580 - 08/28/09 02:30 AM Re: Putting a fuel cell in the trunk? [Re: CVPI_GT]
Bigrick31 Offline
Loc: Nor*Cal
So what do i take the sending unit out of? A f150? or do i buy an aftermarket one that will work with my fuel gauge?
2000 CVPI
Build Log
#1848066 - 08/28/09 08:12 PM Re: Putting a fuel cell in the trunk? [Re: Bigrick31]
1997GrandMarquis Offline
Loc: New Baltimore, MI
I personally dont think you would need to use the sending unit thats in a ford really. Its just that you'd have to pick a aftermarket sending unit that will work with the ford style.
an example. I had a G body cutlass and had a fuel cell in it..Gm usses sending units that read 0 ohms - 90 ohms. 0 ohms = empty and 90 = full.
I"m not sure what ford units read at but thats all you'd need to make sure of.
Justin
New Baltimore, MI
1997 Grand Marquis - 4.6L, 124,000 miles, 3.27 gears, Very clean, DDM HID's (4500K), 20% Tint all the way around, Air Lift 1000 Kit, More to come...
#1848188 - 08/28/09 10:32 PM Re: Putting a fuel cell in the trunk? [Re: 1997GrandMarquis]
IZ1111 Offline
Loc: Houston, TX
Fuel cell in the trunk is sounding better by the minute.
1992 Crown Victoria LX 150K AOD 3.08gears
-A/C delete (w/ condenser & accumulator), -CVPI Aluminum Driveshaft, -Cold Air Intake, -Electric Fan, -'96+ Intake System, -180� Thermostat, -NGK Iridium Spark Plugs, -FlowMaster 40 muffler, -UnderDrive Pulleys (excluding WP pulley), -Battery in Trunk
SOLD!!!!
#1848648 - 08/29/09 01:36 PM Re: Putting a fuel cell in the trunk? [Re: IZ1111]
Bigrick31 Offline
Loc: Nor*Cal
Anyone know what the ohm specs are for a for sending unit? Also the fuel pump in my car is in the fuel tank when adding a fuel cell im guessing i need an after market fuel pump that mounts outside of the tank?
2000 CVPI
Build Log
#1849930 - 08/31/09 04:09 PM Re: Putting a fuel cell in the trunk? [Re: Bigrick31]
JohnnyB Offline
Loc: San Diego-ish
15ohms = empty
160ohms = full
resistance in the wiring from the fuel sender to the gauge should be < 5ohms
'99 CVPI T-56 swap adtr ported plenum, Marauder airbox/MAF, steeda underdrives, boc tune, PI intake, Metco control arms + watts, bilstein shocks, ens bushings, addco swaybars, cut front springs & saggy rears, Explorer console, marauder corners, and then some more stuff. Next up: pi cam swap
#1849987 - 08/31/09 05:52 PM Re: Putting a fuel cell in the trunk? [Re: JohnnyB]
Bigrick31 Offline
Loc: Nor*Cal
Thanks for that!
2000 CVPI
Build Log
#1851192 - 09/02/09 01:35 AM Re: Putting a fuel cell in the trunk? [Re: Bigrick31]
indianerMoustach Offline
Loc: indiana
run your fuel pump outside the car if you can or you will smell fuel in the car all the time. my corolla was like that until i moved the pump. i was afraid to smoke in it
2001 Police Interceptor Ex SouthHoHand Emergency Unit
#1859624 - 09/13/09 06:20 PM Re: Putting a fuel cell in the trunk? [Re: indianerMoustach]
tackleberry Offline
Loc: Las Vegas
what is this fuel cell thing?
