#1913018 - 11/17/09 11:48 AM 85 MPH to 140 MPH conversion
Freakmaster Offline
Loc: NOVA, VA
Hello all!
I have a 1992 ford crownvictoria LX with about 90,000 miles on it and recently my odometer and trip meter stopped working. My speedo still works so i know it is the little gears behind the cluster....
my question is sinc i have to pull it out and buying a new cluster is almost the same as the gears, what would I have to change/replace/convert to make the new p71 140 MPH speedo read correctly... I know this can be done because I have seen it, Im just not sure what has to be adjusted to give me the right reading... if anyone can tell me what I need to do to make a higher rated MPH cluster work in my dash i would greatly appreciate it... Thanks in advance!
-Chris
Edited by wontstopthefunk (11/17/09 12:27 PM)
2005 Crown Victoria PI 100K miles, Jmod
2004 Crown Victoria LX 76k miles, Blue metallic exterior, Digital dash, Sunroof, Black Leather, JMOD, BBK 75mm TB, Professional Products "Typhoon" Plenum, 80mm MAF, CVPI zip tube, JLT air filter, BOC 93 tune, 55w 6000K Projection HID's, Alpine headunit with Bluetooth
GONE - 1993 Crown Vic LX
GONE - 1992 Crown Vic LX PI, 35% Tint, 55W 6500K HID Xenon headlight conversion, Custom cold air intake with down tube and shield (oil vent delete), transmission cooler, transmission kit, dual flowmasters complete with new high flow cats, H-pipe and tail pipes, 4 channel amp, L7 Kicker Solobaric Subwoofers, window guards, iridium plugs, 9 MM spark plug wire set, 200 Amp alternator, custom burned chip, Remote start, Alarm,Keyless, w/ Motion Sensors, Remote Window Modules
#1913484 - 11/17/09 09:27 PM Re: 85 MPH to 140 MPH conversion [Re: Freakmaster]
Nothing will have to be adjusted as the speedo heads all use the same pulse per mile input - it will read accurately. However, to avoid modification you must use one from a 1992-1994 model (analog only)
Also, keep in mind the shift pattern label on the speedometer face is unique for those with the AOD transmission (early '92), however this means nothing (your transmission will shift exactly the same before and the gear positions will be unchanged)
2 registered (RF_Overlord, Rainyp71), 112 Guests and 17 Spiders online.
