#1906141 - 11/09/09 09:30 PM
NPI vs PI heads...
Loc: 48021
Ok so I read things about PI heads and NPI heads...whats the difference and wouldnt a police interceptor have PI heads.If not then whats the difference. How much power would we be talking if adding PI heads.
1999 Crown Vic Police Interceptor 90k miles
Interior Mods..Lighted window switchs on driver and passenger doors. Fixed headlight switch lights
Exterior...Clear corners/new headlight assy's
Future..Aftermarket C/D player..dual flowmasters..honeycomb grill,chrome tips,bumper tuck,chin spoiler,paint job
#1906188 - 11/09/09 10:28 PM
Re: NPI vs PI heads...
[Re: 1999PI]
less is more�
Loc: Moses Lake, Wa
PI does not mean Police interceptor. It means Performance Improved. NPI means Non-Performance Improved. Mustangs got the PI heads, cams and intake in 1999. Panthers did not receive them until 2001. Putting them on a stock NPI engine will raise the compression ratio and require Premium gasoline. A cheaper solution that many have done is install the PI cams and intake on their stock engine. That is actually most of the HP improvement.
-Colton  2004 Ford Crown Vic LX, 89k "Tank" (Totaled 12/06/15 22:30 PST) 2002 Ford Crown Vic PI, 201k "Highwayman" (Ex-Kootenai County, ID Unit #42) - Down for bad engine 2003 Ford Crown Vic PI, 98k "Name TBD"
#1906357 - 11/10/09 01:28 AM
[Re: Colt45]
Loc: 48021
PI does not mean Police interceptor. It means Performance Improved. NPI means Non-Performance Improved. Mustangs got the PI heads, cams and intake in 1999. Panthers did not receive them until 2001. Putting them on a stock NPI engine will raise the compression ratio and require Premium gasoline. A cheaper solution that many have done is install the PI cams and intake on their stock engine. That is actually most of the HP improvement. I know the PI doesnt mean police interceptor...so would i have to do anything else other then add the cams and intake?
#1906359 - 11/10/09 01:29 AM
[Re: 1999PI]
less is more�
Loc: Moses Lake, Wa
Not really. A tune would optimize performance, though.
#1907334 - 11/11/09 02:04 AM
[Re: 1999PI]
I am not
Loc: Garland, TX
I know the PI doesnt mean police interceptor...so would i have to do anything else other then add the cams and intake? depends... what year, make and model do you have?? i'm almost certin 96+ ur ok. 96-98 mustang guys do this mod daily. i did the pi intake and cams. it was well worth it. i found used stuff, and total parts cost was under $200. i had to buy a bunch of tools to make it all happen (needed them anyway kind of thing).
#1914179 - 11/18/09 06:03 PM
[Re: mustang_zulu]
so basically PI cams and PI intake manifold= PI engine? then whats the point of it having a higher compression? exactly how much power difference is there with the cams and intake vs the complete pi engine? does the PI ECU add anything or would a tuner be sufficient?
2000 baby blue Mercury GS (M74) 249k miles.
#1914200 - 11/18/09 06:35 PM
[Re: Merque]
Coolest guy on CVN
Loc: In the beams!
What makes a PI engine a PI engine is The PI Intake, Cams, and heads. Also, they have dished piston heads. The NPI engine doesn't have dished pistons.
Therefore, if you put the PI heads on the NPI motor,(non dished piston heads) it bumps the compression by making the combustion chamber smaller. Higher compression = higher cylinder pressure, and that in turns makes more power. One would have to put a higher octane fuel in though. At least 91, but some say 93. A tune wouldn't be required, but it would be suggested.
An NPI engine with PI cams, intake, and heads would out perform a stock PI engine. It would do that because the previously meantioned higher compression. But putting any sort of forced induction on the NPI motor with all the PI stuff would be out of the question. The Rods would tunnel their way out of the block, or you'd start blowing head gaskets.... or both, at the same time. Double FAIL!!!
1999 P71, Chevy 6.0, billet 85mm turbo, 4L80e, 3.73s, E85, etc. [email protected]2006 P71, bone stock sans JMOD 2000 P71, Black and white 2002 LX sport
#1914354 - 11/18/09 09:29 PM
[Re: Over2tonsofFun]
less is more�
Loc: Moses Lake, Wa
Yes, thats doable, just be aware the stock pistons and rods are not designed for that service.
#1914560 - 11/19/09 12:25 AM
Coolest guy on CVN
Loc: In the beams!
So would adding forced induction on a NPI with the PI cams and Intake be good?
Tim You can do that, but putting stock parts on a car is only gonna get you so far. If you bit and piece and engine together without a plan, you probably won't get as far as you would if you knew exactly what you wanted from the start. You get what you paid for. Aftermarket, when done right is way more worth it than making a frankenstine motor from stock parts with a blower on it.
#1914668 - 11/19/09 05:14 AM
[Re: Street_Shark]
Loc: paterson,nj
to get a forged rotating assembly for the mod motor is about $1800-2300.
1986 Crown Victoria LTD - R.I.P. 10/06/2010 1998 Grand Marquis GS Palm Beach - Cop Chip 2000 Grand Marquis LS - pretty much stock 2000 Chevy Malibu LS - P.O.S. Civic Burner
