#1932290 - 12/11/09 05:31 PM reclining
LTDteether Offline
My power seat just stopped moving in the "de-recline" direction. I have the wiring diagram and I hope to look at it this weekend. I just want comments on the problem from anyone that had problems with power seats in the past. What was the failure cause, switch, wiring, connectors, or motor. Anything I forgot? I hope I just need to clean the switch or something like that.
This is a problem. I tapped the recline a couple of times while testing it and leaned it back just a little. I really prefer to drive more, er, erect.
'99 GM GS HPP.
#1932300 - 12/11/09 05:37 PM Re: reclining [Re: LTDteether]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
If you don't hear the motor which I assume works both ways then I would look at the switch.
Got a 12v test light to see if current it getting to the motor ?
The Jmod video is done! LINK!
#1932355 - 12/11/09 07:00 PM Re: reclining [Re: Rizzo]
LTDteether Offline
I've never invested the big bucks in a real test light :-) I usually cobble together stupid gator clips and a bulb I have lying around. I do have a good collection of multimeters, go figure.
It goes back , but not up so I am thinking the switch, but it could be wires or connectors.
'99 GM GS HPP.
#1932656 - 12/12/09 11:11 AM Re: reclining [Re: LTDteether]
Gangstas_Inc Offline
CvN's Resident OG
Loc: the Jungles of Peru, or Tampa....
Clean the connector 1st and see what happens. Let us know
2007 p71
A wise man once said "sticking feathers up your butt does not make you a chicken"
#1934117 - 12/14/09 03:35 PM Re: reclining [Re: Gangstas_Inc]
If it is working in the recline up position or you are at the stop and can hear the motor 'thud', I'm sure the problem is the switch itself (as the voltage is simply reversed to reverse the movement, so the motor and wiring are fine)
You can apply 12v across the recline motor wiring at the inline switch connector behind door panel to test motor operation or just to get the seat back to a normal position for now.
Pinouts on my webpage in the seat swap FAQ
2 registered (Traffic22, Dmblanch), 64 Guests and 315 Spiders online.
bluejay_32 159
Old_Guy_Stu 88
CrystalPistol 80
a_d_a_m 77
TheCableGuy 57
DudeAbides 53
Ponyguy 49
Moby_Vic 47
Bangster 46
RF_Overlord 46
