Page 2 of 4 < 1 2 3 4 >
#2014240 - 03/30/10 08:57 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Section8]
BlaineB Offline
Yes I understand. Although it is pretty close anyway, and the cup technically reduces the inner diameter a bit....although just slightly, it still does.
Funny thing, the older Cherokee's used to have an extension in the air box to reach behind the headlight just as the Panther's do. However in the later models this extension was eliminated and a block off plate was added over the hole behind the headlight. Literally, a plastic piece screwed to the header panel blocking this cold air flow was added from the factory. Easily removed, however.....still, what is the idea behind that?!?!
Edited by BlaineB (03/30/10 08:58 PM)
#2014319 - 03/30/10 10:38 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: BlaineB]
Quickvic30 Offline
Just watchin
Loc: Minneapolis, MN
A little thing called budget cuts \:D
#2014333 - 03/30/10 10:55 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Quickvic30]
BlaineB Offline
I wouldn't think a budget cut would involve the addition of a worthless piece of black plastic covering up a nice hole which let that nice colder air in. But who knows, maybe they found some scrap plastic somewhere.
#2014347 - 03/30/10 11:20 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: BlaineB]
99_03PantherS Offline
Loc: NW side Chicago
maybe water was being sucked in. who knows
Jason G.
'06 Towncar Designer
'81 Mark VI 2 door
'88 Towncar Cartier
'16 F-450 V10 DRW
#2014369 - 03/31/10 12:21 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: 99_03PantherS]
b1kfd Offline
Loc: Mississippi
Maybe the plate made it quieter, to help pass noise emmission tests. Just a guess.
2001 p71 former Jefferson County, Mo Sherriff Deputy's car, 2005 Ford Freestyle (wife's car) 1992 pos Nissan pickup, 1989 Kawasaki ZX10 Ninja.
#2014380 - 03/31/10 12:29 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: b1kfd]
Quickvic30 Offline
Just watchin
Maybe someone should E-mail chrysler and ask \:D
#2014402 - 03/31/10 12:56 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Quickvic30]
Section8 Offline
Awesome hijack!
Maybe you can pursue the issue further on http://www.idontgiveacrap.com
2003 Ford Crown Victoria P71- 61k miles, Ex US Marshalls car, SAP but changed to black grille and small caps. 235/60-16 tires, "Big Gulp" free intake mod, 2004 zip tube with stock MAF and stock tune, special cop headlights that go into steath mode at random. Best run 15.73 @ 88.25
#2014434 - 03/31/10 01:42 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Section8]
BlaineB Offline
There is no issue, I was just comparing the two.
#2015070 - 03/31/10 10:08 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: BlaineB]
BlaineB Offline
delete
Edited by BlaineB (04/01/10 02:43 AM)
#2016170 - 04/02/10 10:05 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: BlaineB]
Texas_Charlie Offline
Loc: Corpus Christi, TX
how do you get the snorkel out?
#2016249 - 04/02/10 12:36 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Texas_Charlie]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
Pull.
Hard.
It's just pressed in.
The Jmod video is done! LINK!
#2016654 - 04/03/10 12:06 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: Rizzo]
will_reed90 Offline
Loc: michigan
i did this today because i had nothing better to do. i dont know if it was wishfull thinking but it felt like it worked. a large drink cup from a fast food joint works well
2000 CVPI no mufflers, everything else is factory.
oh yeah i forgot about the bottle.
190HP N/A - 238HP "50 SHOT" - 264HP "100 SHOT"
15.95 N/A in the heat
nitrous times soon... hopefully
its yours for the right price.
#2016689 - 04/03/10 02:08 AM Re: Big Gulp (of air) Free intake snorkel Mod [Re: will_reed90]
jefo Offline
Loc: c
I did a similar mod to my airbox. instead of using a cup, i used a 3" abs rubber pipe coupler with a hose clamp. I had to cut it a bit to fit perfectly, but it looks clean, and makes a positive seal with the fender. \:\) btw, it clamps onto the outside of the hole of which the snorkel was removed.
#2016986 - 04/03/10 05:30 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: jefo]
BlaineB Offline
That sounds like it would be the best option as the tube would not make the inner diameter of the intake hole any smaller than it already is. Can you grab some pictures to show what kind of coupling you actually used?
#2017038 - 04/03/10 07:32 PM Re: Big Gulp (of air) Free intake snorkel Mod [Re: BlaineB]
Section8 Offline
How many fractions of a millimeter thick is a free cup? maybe 1/2mm or 1/3mm?
As long as this hole is bigger than your throttle body or MAF I don't think you need to worry about that 1/3 of a mm difference.
The problem with the home depot mod where you cut off the snorkel and attach a pipe, is the remaining piece has a smaller hole than any other point in the intake system.
2 registered (Jabes, stalag), 63 Guests and 87 Spiders online.
Moby_Vic 76
JeffBoudah 74
Old_Guy_Stu 69
Armada Master 54
DudeAbides 51
a_d_a_m 49
Dmblanch 46
Ponyguy 43
SocalSam 38
