Page 2 of 2 < 1 2
#194011 - 07/15/03 01:51 PM Re: Interesting HO conversion tech info
Petely Offline
Loc: Chicago, IL
Why are the injectors leaking after shutdown.? Are they sticking open. If the o-rings are bad then it would spray which is a bad thing but it would occur after startup. Hehe, I had that happen during a test drive. When inserting the injectors I musta shaved one of the o-rings and man, gas was everywhere. 88GrandMarq, what brand injectors did you get, from where, and what was the cost. I just replaced mine with some cheapy GP Sorensons that weren't that cheap. $40 * 8 = lotta cost. I like the rails that General Motors uses in their buicks. Little more heavy duty. Not just a tube with little openings.
Peter
1987 Mercury Grand Marquis
*sold to some guy on cvn for $1
New Long List of Rules Compliant Sig
#194012 - 07/15/03 03:47 PM Re: Interesting HO conversion tech info
AOD Offline
i have SVT87's old 14# injectors in my car. i did the swap as a test to rule out my injectors as the cause of the 'random engine miss'. i dont remember having the problem with leakdown until after i swapped his in. my guess is one of them is staying open, and letting fuel leak into the cylinder. i dont know why this would cause the engine to crank for 5 seconds extra...but when the engine is hot and sat for 20 minutes to 5 hours it will require 5 seconds extra cranking and reak of gas after it turns over.
~AOD
#194013 - 07/15/03 04:51 PM Re: Interesting HO conversion tech info
shaman Offline
Some cruise info
If you swapped in a Mustang EEC brain, it'd be simpler to swap in the stand alone cruise control from a stang as well. All you need is the amplifier, the servo, and the VSS signal.
http://www.dalidesign.com/hbook/ccmain.html
Carson
87 Crown Vic owner, 98 altima driver
#194014 - 07/15/03 05:27 PM Re: Interesting HO conversion tech info
Petely Offline
Loc: Chicago, IL
That is a good link man. Thanks for posting it.
Peter
#194015 - 07/15/03 05:49 PM Re: Interesting HO conversion tech info
Cool.
Cruise control on our cars is controlled either by a stand-alone electronic box, or it is integrated into the ECU. I think 88/89/90 was the switchover year(s) from one system to the other.
Alex.
#194016 - 08/01/03 07:15 PM Re: Interesting HO conversion tech info
Petely Offline
Loc: Chicago, IL
Updates please. How did that HO cam work with the stock ecu? Me == curious!
Peter
#194017 - 08/02/03 12:26 AM Re: Interesting HO conversion tech info
88grandmarq Offline
4R70W rebuilder
Page 2 of 2 < 1 2
