#1963977 - 01/24/10 07:35 PM
Re: motor oil
[Re: thegreat22]
Loc: Columbus, OH
10W-30 is probably okay for where you are located. If you drive north however I would go with a thinner oil if you do so during the winter.
By the way the lower viscosity oils will create less drag in the engine making for more power.
stalag
Edited by stalag (01/24/10 07:36 PM)
#1964223 - 01/25/10 01:31 AM
Re: motor oil
[Re: stalag]
Loc: Herrin,Illinois,Williamson Cou...
Either 5w20 or 5w30 should be ok. 20w40 is a no go.
1998 Mercury Grand Marquis LS stock.
#1964477 - 01/25/10 12:09 PM
Re: motor oil
[Re: ford05]
Loc: Columbus, OH
By the way the lower viscosity oils will create less drag in the engine making for more power. It is a fluid dynamics thing.
stalag
Edited by stalag (01/25/10 12:10 PM)
#1964623 - 01/25/10 03:55 PM
Re: motor oil
[Re: stalag]
Loc: Rain City
stalag at the same time if they viscosity is very low for an extended period of time its a bad thing for example : 5w20 + 90 degree heeat + 5 hour drive might not be a good thing for obvious reasons
#1964833 - 01/25/10 08:32 PM
Re: motor oil
[Re: Street_Shark]
Loc: Columbus, OH
20W oil can be worked in an engine up to 120F ambient. Unless you are doing extended long distance driving like a truck your assumption is not true with most conditions encountered in the US. The sole exception may be Death Valley in the dead of summer which would require 5w-30.
Stalag
#1965022 - 01/26/10 12:47 AM
Re: motor oil
[Re: stalag]
Ok I keep 5w30 in my 98 marquis year around now. I used to put 10w30 in it year around, then I found out 5w30 is good in between all purpose oil for this kind of car.Heavy oils are for older cars and vehicles under lots of workload stress. So suit yourself.
#1965031 - 01/26/10 01:07 AM
Re: motor oil
[Re: stalag]
Loc: SoCal
The sole exception may be Death Valley in the dead of summer which would require 5w-30. Part of Ford's 5W-20 testing involved running Expeditions and Navigators, loaded to maximum capacity, for 250,000 miles with 15,000 mile OCIs. If it can pass something as tough as that, and has Ford's backing, then I'm sure Death Valley wouldn't be an exception. Even at this end, where temperatures get up to 60 C, I have yet to hear of an oil related failure with 5W-20 in Fords.
Lucifer: '01 Grand Marquis GS ConvenienceTuned By Marty @ Mo's Speed Shop In Memory of Ned Nuss, Rick Richardson and Matt (2vmodular)
#1965174 - 01/26/10 10:43 AM
Re: motor oil
[Re: Street_Shark]
Loc: California
IDK, I'm using 5W-20 in my 04 Grand Marquis. I regularly drive from So. California to Arizona. It's about 6 or 7 hour drive (depending on traffic) and last summer it was 110F. and above for most of the trip. (I saw as high as 115) That was half a dozen trips ago.
Edited by super88 (01/26/10 10:44 AM)
2004 MGM LS
#1965176 - 01/26/10 10:45 AM
Re: motor oil
[Re: White Falcon LS]
Loc: California
The sole exception may be Death Valley in the dead of summer which would require 5w-30. Part of Ford's 5W-20 testing involved running Expeditions and Navigators, loaded to maximum capacity, for 250,000 miles with 15,000 mile OCIs. If it can pass something as tough as that, and has Ford's backing, then I'm sure Death Valley wouldn't be an exception. Even at this end, where temperatures get up to 60 C, I have yet to hear of an oil related failure with 5W-20 in Fords. +1
2004 MGM LS
#1965398 - 01/26/10 05:03 PM
Re: motor oil
[Re: Street_Shark]
Loc: Columbus, OH
Landyacht,
Actually there is no downside. The tolerances are so much tighter in a 4.6L modular engine (5.4L as well) as opposed to older designs that the thinner oils are more than up to the task of protecting the engine. The tighter tolerances means that the oil films need to be correspondingly thinner as well. The film surface is what allows shear to occur between two moving parts. That shear occurs easier in a lighter weight oil reducing internal friction of the fluid and as a result gives just as good lubrication when the tolerances are tighter. The thicker oils are used where shock protection from parts that are moving to keep them from scuffing/banging together when you have loose tolerances. Also, a high quality synthetic will beat out a conventional oil any day of the week because the designed properties of a mixture of known chemicals verses a weighted fraction from oil distillation allow for better shear and surface protection. Lighter oils are also less prone to production of sludge (because of the better flow properties of the lighter oils leading to less contact time with hot surfaces) and as a result are also better for the longevity of a vehicle.
To make the arguements you are attempting you need an understanding of fluid dynamics and film surfaces to be right on this point. I did, when I was in high school 20 years ago, play with different oils in a 1.6L Subaru Brat. At that time the vehicle called for a 10W-40 weight oil. I found the following points.
1. Heavier oils like 20W-50 did work but bogged the engine. 2. 10W-30 worked reasonably well and was better than 10W-40 as far as performance. 3. Mobil 1 5W-20 found all the leaks in the engine but also cleaned the crankcase and the engine ran much cooler. After a couple of oil changes at 3000K intervals the oil came out much cleaner. I also had a cousin who helped me do the valve lash adjustment on the car comment on how clean the valve assembly was in comparison to other engines he had worked on. Also, I saw the best performance with that oil in my crankcase when I drove the vehicle.
Today being a scientist (PhD) crosstrained as an engineer I now understand why this all works. I would suggest courses in fluid dynamics and study of surface structures before making a vague statement like
" I just think there must be a downside. "
Stalag
Edited by stalag (01/26/10 05:06 PM)
#1965467 - 01/26/10 06:22 PM
Re: motor oil
[Re: Street_Shark]
Loc: Columbus, OH
There are entire textbooks at the college level dedicated to fluid dynamics. Much of the math if you are in high school is even well above your teacher and your teacher may have some trouble comprehending. PM me if you want to chat a bit about this topic.
Stalag
#1965481 - 01/26/10 06:41 PM
Re: motor oil
[Re: stalag]
Loc: KY,OH,MICH
3 registered (DES, Fopeano, Jettman),
63
288
