Page 1 of 9 1 2 3 4 5 6 7 8 9 >
#1977495 - 02/11/10 05:40 PM Replacing/changing color of LEDs on defrost switch
I am working on doing all my window switches and had an extra defrost button sitting around so figured I'd do that one too.
1 - pop out the switch cover
original green illumination LED
Original 'defrost on' amber LED
2 - remove plastic cover(I guess you could just removed this and leave the switch cover in place but this is how I did it)
3 - remove old LEDs(I used solder wick to remove the old solder from the LED so then it could just be pulled off the board)
4 - install new SMD LED's(I used blue 1206)
5 - Test
Illumination
'Defrost on'
Both on
6 - Replace cover, first pic taken with both lights on and using a flash
(no flash)
Just the illumination light on
When I get the switch put back in tomorrow morning, I'll take pics of it in place.
#1977509 - 02/11/10 05:54 PM Re: Replacing/changing color of LEDs on defrost switch [Re: BlackVic_P71]
SgtTaz Offline
Loc: Chicago, IL
Nice! Man I'm going to be very busy this spring with all the new projects and my addition of the 05 ;\)
#1977596 - 02/11/10 08:00 PM Re: Replacing/changing color of LEDs on defrost switch [Re: SgtTaz]
PB92 Offline
Loc: Communist CT
Groooooovy daddio!!!! I like it............
99 P71 Ex-Greenwich CT Det. car. New Ford crate engine. Deep Wedgewood Blue. Big 4 upgrade, 370amp alt w/overdrive pulley. ARA3 PCM. High power CB'er for 35 years. GMRS Operator Midland MXT400
#1977624 - 02/11/10 08:40 PM Re: Replacing/changing color of LEDs on defrost switch [Re: PB92]
nicklee94 Offline
Loc: Dallas
That [censored] tight YO...lol
Where you get the L.E.Ds
Sig removed. Read the rules.
#1977753 - 02/11/10 10:35 PM Re: Replacing/changing color of LEDs on defrost switch [Re: nicklee94]
StealthMode Offline
Loc: Minnesota, USA
I'd like to be able to do that. Blue would go good in mine. If only I could figure out why mine isn't turning on:(
~SOLD~ frown 2004 CVPI 132xxx, Superchips Performance Tune, 3:55 Gears, 1-2 Gear Lower Actuator Spring Removed, Steeda Underdrive Pulleys, K&N Filter, "Customized" Cold Air Induction, Rear Cat Delete, 22in Glass Packs, Exhaust Dumped at Rear Axle w/Turn downs.
#1977879 - 02/12/10 01:14 AM Re: Replacing/changing color of LEDs on defrost switch [Re: StealthMode]
C_A_F_B_Duval Offline
I've got all of mine switched to blue. Took me about a week workin a couple hours a night. Now I have the floor boards lit up with blue leds. The stock interior lights are switched to blue led's. Now im workin on the trunk and engine lights, puttin the blue LED's in there too. I've also got to do the strobe kits and find a way to change the color of the interior panels. Not sure how,thought about maybe that spray paint made for plastic and a sealant.
1999 CV. Work in progress.
A Crown Vic with a lift kit,4wd conversion, and super swamper's, has it ever been done before?? if not I want to be the person with the first Cop Car Mud Machine.
#1979143 - 02/13/10 05:21 PM Re: Replacing/changing color of LEDs on defrost switch [Re: C_A_F_B_Duval]
StealthMode Offline
Loc: Minnesota, USA
Actually using spray paint works pretty good. I painted some of my trim black to match the outside of the car.
#1979226 - 02/13/10 07:58 PM Re: Replacing/changing color of LEDs on defrost switch [Re: StealthMode]
Mr1999p71 Offline
Loc: Breckenridge county,Kentucky
THAT IS SHARP!!! do you think it would look good in white to match a white exterior?
1999 p71, 100k miles
Full blue cloth interior
16" steelies,CB radio
Mods to come: Tint windows, install push bumper.
#1980158 - 02/14/10 08:41 PM Re: Replacing/changing color of LEDs on defrost switch [Re: StealthMode]
I finished the switches today with the lock/unlock and master window switches.
Stock green lighting
All soldered in
All lit blue
Checked the lights half-way through and got this, no clue where the one red came from since they were all in one blister pack
A diagram in case anyone else wants to do this
Edited by BlackVic_P71 (02/14/10 08:45 PM)
#2079376 - 06/25/10 10:43 PM Re: Replacing/changing color of LEDs on defrost switch [Re: BlackVic_P71]
Sgt_Dobish Offline
Loc: NJ
where did you purchase these leds from? im interested in doing this mod since my pioneer is blue and white
#2079593 - 06/26/10 05:31 AM Re: Replacing/changing color of LEDs on defrost switch [Re: Sgt_Dobish]
yayo_ote Offline
Loc: houston,tx
im loving this good job
1998 Crown Victoria Police Interceptor 120K Miles, Black Leather Seats and Carpet, Kenwood CD Mp3 Deck, Door Kenwood 6-1/2" 2-way coaxial speakers, Rear Pioneer 6"x9"
#2129357 - 08/31/10 12:26 PM Re: Replacing/changing color of LEDs on defrost switch [Re: Sgt_Dobish]
Super_Buffalo Offline
Loc: Southbridge, MA
x2. As soon as I figure this one out I'm going to order them up. What about your Temp controls? How did you do those?
2004 CVPI, Dark Blue Pearl, Tucked rear fascia, Osram Sylvania Silverstar 9007's, Rizzo's blinker mod, Gatorback belt, 180 degree thermostat, and more to come...
#2129573 - 08/31/10 06:10 PM Re: Replacing/changing color of LEDs on defrost switch [Re: Super_Buffalo]
I got either 50 or 100 1206 SMD LED's from China on ebay for around $20, I think. I did the temp controls but that didn't require and SMD's, just put in 194 LED's.
I also took out the little plastic piece on the knob and painted it with translucent blue paint.
#2129591 - 08/31/10 06:42 PM Re: Replacing/changing color of LEDs on defrost switch [Re: BlackVic_P71]
JohnnyV Offline
Loc: The Jersey Shore
Did you get the clear LEDS? The color looks a little spotty. Frosted LEDS would be a good choice to disperse light a little more evenly. Looks good though!
2000 P71:4500kHIDs/StainlessWorksCatback/Twin12"Subs/RemoteStart/SteeliesWithSpacers/5%RearTint
1984 Porsche 928S
#2129625 - 08/31/10 07:50 PM Re: Replacing/changing color of LEDs on defrost switch [Re: JohnnyV]
They are real cheap blue LEDs in the HVAC control, I may put a strip of blue SMD in there at some point to even the color out.
2 registered (RipWixomAssembly, Swirlsound), 104 Guests and 12 Spiders online.
Traffic22 15
