i have a 98 cv police. 175000 mi. i was degreasing the engine in prep for a tc cover job. after i rinsed of the eingine and cranked it up i noticed a misfire. so i got my scanner out and i pulled code p1401. the dpfe giving high voltage reading. would just raplacing this sensor fix the issue, or is their someting that is causing the high voltage reading. i just did a tune up so i know its not the plugs. i checked my injectors with an indicator light, all are pusling, but the strangest thing happens when i disconnect an injector. on cylinders 1 and 7 when i pull the injector plug the idle smoothes out compared to when they are all plugged up. also when i was checking the codes the engine overheated spraying coolent everywhere. i had just replaced the fan. please help
