#2014469 - 03/31/10 02:42 AM How often should my cooling fan run?
illgame Offline
Loc: michigan
Just wondering if this is a Crown vic thing...my fan kicks on after barley driving anywhere regardless of car temp....my car runs and drives great but was wondering how often should it be running under normal 50-70 degree heat and driving conditions....seems like mine runs far more than any car ive drivin in the past...
98 vic
#2014474 - 03/31/10 03:06 AM Re: How often should my cooling fan run? [Re: illgame]
CrownV351 Offline
Loc: MN
What year Vic? 95-97 it runs when the A/C or defrost is on. 98-02 it cycles when a certain temp is reached (210 I think) runs constant with A/C or defrost on. 03-up is controlled by the PCM according to engine speed, coolant temp and if A/C or defrost is on (variable speed fan).
If yours comes on just after start up and the HVAC controls in the off position, you may need a new coolant temp sender unit for the fan. Check the connections at the fan too, as sometimes they get loose, or burned up (depending on year)
"What were dealin' here.....is a total lack of respect for the law!!" -Sheriff Buford t. Justice
2009 CVPI ex MN State Patrol squad. 77k.
1995 Chevrolet Caprice 9C-1 5.7 LT-1 Ex-Minnesota State Patrol #45110 with many many mods.
1952 Pontiac Chieftain 4-door undergoing frame off restoration...endless..
#2014579 - 03/31/10 09:59 AM Re: How often should my cooling fan run? [Re: illgame]
gDMJoe Offline
Loc: Timbuk3, MI
And the year, make, and model of your vehicle is ?
HINT/TIP - Put your vehicle information in your sig'. -OR- provide it within each post.
-click the Vic-
#2014649 - 03/31/10 11:23 AM Re: How often should my cooling fan run? [Re: gDMJoe]
Tracy Offline
Loc: West Bend, WI, USA
Check your coolant and make sure it isn't low or empty.
I found that when my coolant tank was close to empty (just a little in the bottom)that my fan ran more than when the coolant tank was filled to spec.
Plus depending on the position of the A/C switch will turn the fan on. MAX A/C, MORM A/C, MIX, and DEFROST will turn it on in a 98+ Vic. Any questions consult your Owner's Manual.
1 registered (FR3AK), 43 Guests and 234 Spiders online.
CrystalPistol 362
bluejay_32 324
a_d_a_m 231
Rainbowpizza 167
DudeAbides 149
JeffBoudah 124
Old_Guy_Stu 77
BigNSlow 69
Bangster 62
