#2019800 - 04/07/10 05:41 PM got a 97 crown vic p71 and i think i got a problem
97_p71_racecar Offline
Loc: brewer me
I have a 97 Crown Vic p71 that im building into a stock car and I ran into a few problems first problem i drained the anti freeze out and was going to add water so i started filling it with water and nothing not bubbling like it was not getting to the radiator and so im thinking water pump. second problem i was cutting the exhaust off and i was not thinking and i cut two o2 sensors off do i need the 2 o2 sensors so could i get some help please
#2019840 - 04/07/10 06:49 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: 97_p71_racecar]
SCHALLZ Offline
Loc: La Crosse WI, USA
you will want to keep the o2's or you will show running lean unless you get a programmer to shut them off
#2019848 - 04/07/10 07:07 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: SCHALLZ]
Loc: brewer me
ok. ill some how reinstall them
any one have a idea why i can not put fluid in the car
#2019857 - 04/07/10 07:24 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: 97_p71_racecar]
gord_bolton Offline
Loc: Saskatoon, Saskatchewan
You need to fill though the thermostat housing or heater hose.
#2019877 - 04/07/10 08:08 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: gord_bolton]
Loc: brewer me
are you joking?
#2019894 - 04/07/10 08:36 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: 97_p71_racecar]
Loc: brewer me
if thats the way it is done ill do it
#2020324 - 04/08/10 11:38 AM Re: got a 97 crown vic p71 and i think i got a problem [Re: 97_p71_racecar]
99_03PantherS Offline
Loc: NW side Chicago
You need to fill it from the thermostat housing.
USE DISTILLED WATER!!
Jason G.
'06 Towncar Designer
'81 Mark VI 2 door
'88 Towncar Cartier
'16 F-450 V10 DRW
#2020391 - 04/08/10 01:21 PM Re: got a 97 crown vic p71 and i think i got a problem [Re: 99_03PantherS]
Loc: brewer me
ok ill try that
11 registered (bobb, bluejay_32, ds13254, Davidzq, cghorr01, Bezaleel, 2 invisible), 93 Guests and 314 Spiders online.
CrystalPistol 255
bluejay_32 168
Old_Guy_Stu 105
JeffBoudah 77
a_d_a_m 72
Moby_Vic 62
Ponyguy 62
Dmblanch 58
DudeAbides 42
Bangster 38
