#2050863 - 05/20/10 09:55 AM OD off light flashing- transmission
rick1970 Offline
Loc: FL, USA
the od off light is flashing on and off...the car is hunting for gears...any idea what to check??..thank you.....
2001 crown victoria P71
#2050874 - 05/20/10 10:06 AM Re: OD off light flashing- transmission [Re: rick1970]
Colt45 Offline
less is more�
Loc: Moses Lake, Wa
Youll need to pull the codes from the computer. Flashing OD light indicates a transmission fault.
-Colton
2003 Ford Crown Vic PI, 98k "Name TBD"
#2050888 - 05/20/10 10:23 AM Re: OD off light flashing- transmission [Re: Colt45]
rick1970 Offline
Loc: FL, USA
ok..thank you....so how many things could it be??!! something easy and cheap i hope.....
#2050890 - 05/20/10 10:28 AM Re: OD off light flashing- transmission [Re: rick1970]
Colt45 Offline
less is more�
Loc: Moses Lake, Wa
Dozens. The codes will be more specific and it could be anything from loose or corroded wiring to a transmission rebuild. Try to avoid driving the car until this is repaired.
Edited by Colt45 (05/20/10 10:28 AM)
-Colton
#2050895 - 05/20/10 10:34 AM Re: OD off light flashing- transmission [Re: Colt45]
rick1970 Offline
Loc: FL, USA
well..i have to drive it to the shop..thats it..i have a bike..so hope no rain...!
#2050929 - 05/20/10 11:17 AM Re: OD off light flashing- transmission [Re: rick1970]
gDMJoe Offline
Loc: Timbuk3, MI
Eenie meenie chilli beanie, the spirits are about to speak! ...
And the year, make, and model of your vehicle is ?
HINT/TIP: Put your vehicle information in your sig' -OR- provide it your posting(s).
-click the Vic-
#2050943 - 05/20/10 11:41 AM Re: OD off light flashing- transmission [Re: gDMJoe]
rick1970 Offline
Loc: FL, USA
2001 ford crown victoria p71 97K miles
#2050980 - 05/20/10 12:22 PM Re: OD off light flashing- transmission [Re: rick1970]
99_03PantherS Offline
Loc: NW side Chicago
Dont drive it anymore.
If the OD light is flashing, it can be a sensor of some kind. Need to have the code checked.
Jason G.
'06 Towncar Designer
'81 Mark VI 2 door
'88 Towncar Cartier
'16 F-450 V10 DRW
#2051135 - 05/20/10 04:00 PM Re: OD off light flashing- transmission [Re: 99_03PantherS]
rick1970 Offline
Loc: FL, USA
i concur about not driving it..but have to get it to the shop..pushing it sucks...towing well...sucks...driving it three miles is that bad??...thanks guys...
#2054183 - 05/25/10 12:17 AM Re: OD off light flashing- transmission [Re: rick1970]
spenck07 Offline
Loc: Edon, Ohio
I just started getting that same thing bought the car two weeks ago, and now over 50 or 60 it does it, no shift problems or overdrive issues just blinking light.
#2374017 - 09/19/11 12:45 AM Re: OD off light flashing- transmission [Re: rick1970]
SteamRoller Offline
Loc: San Fernando Valley, Californi...
So how do I pull the transmission codes? I have an OBDII scanner but I don't think it will help with the codes.
SteamRoller
2001 Grand Marquis LS
COMPLETED MODS:
Borla Stainless cat back dual exhaust system
Gutted Air Box (TurboVic's way).
Airlift 100 coil inserts.
Alpine CDA 9813 MP3 - Got ripped OFF !!!
replaced with a lower model Alpine
Audiobahn AS57PQ plates all around
Audiobahn A4601T 4channel X 75w @ 4 ohm RMS
Infinity BassLink
#2374165 - 09/19/11 11:43 AM Re: OD off light flashing- transmission [Re: rick1970]
MyP71Vic Offline
Loc: Brookfield, WI
Mine does this also I got some codes from it about a month ago then everything cleeared up and worked great now it is back. The codes I got were P1783 trans temp, P1705 tran rng out of test rng, P1502 vss inter apcm functioning, P1501 vss out of self test rn, and P0500 veh spd vss er. These seem kind of random or are they related through one sensor? It is totally fine when driving very easy. Fluid is like new still cause it keeps leaking a little so I just keep adding it as it goes to keep it fresh!
#2374461 - 09/19/11 09:58 PM Re: OD off light flashing- transmission [Re: rick1970]
JSanders Offline
Loc: California
High temp is one cause for a flashing light. If you can measure the temp with a touchless temp probe while it is flashing, you might see if the temp is too high, if the sensor is bad or not. You can shoot the bottom of the tranny pan and get a pretty accurate trans fluid temp that way.
Could be that your trans cooler is plugged up, or the thermostat on the trans cooler is frozen shut. Normal is around 180 degrees, mine takes a good 10 miles to get up that high unless it's super hot out.
#2374475 - 09/19/11 10:17 PM Re: OD off light flashing- transmission [Re: JSanders]
SLOBRA Offline
Loc: Minnesnowta
That seems pretty high man unless you have a stall converter maybe. I had a scanguage on mine last year with the 3800 stall and 4.10 gears and never saw more than 165. I basically borrowed the device and beat the crap out of it for 15 minutes.
9psi, E85, stock bottom end
[email protected]
#2374528 - 09/20/11 12:14 AM Re: OD off light flashing- transmission [Re: MyP71Vic]
olopezm Offline
Loc: Irapuato, Mexico
You can give it a try, some transmission codes can be read with a cheap scanner, if nothing comes up then you'll need to have it diagnosed with the proper scanner. I've seen that kind of behavior on transmissions when the Transmission Range Sensor aka Neutral Safety Switch or Manual Lever Position Sensor goes bad; a bad VSS can cause that too.
It looks like your fluid leak has caused intermittent contact with the sensors. I would inspect the connectors and sensors and give them a good clean with electric contact cleaner.
Oscar.
1997 Pontiac Grand Prix GT
2000 Ford Windstar SE
JSanders Offline
Loc: California
MyP71Vic Offline
Loc: Brookfield, WI
olopezm Offline
Oscar.
SLOBRA Offline
Loc: Minnesnowta
[email protected]
Bangster Offline
FLP71 Offline
Loc: Florida
gcassidy Offline
Loc: Silver Spring, MD
Greg
'01 CVPI
'98 SVT Mustang Cobra
2002 SVT Focus
stalag Offline
Loc: Columbus, OH
gcassidy Offline
Greg
'01 CVPI
2002 SVT Focus
maroonlagoon Offline
Loc: allover
Hey Gang,
Thanks
2 registered (magic, bluejay_32), 46 Guests and 137 Spiders online.
bluejay_32 204
a_d_a_m 126
Old_Guy_Stu 123
DudeAbides 95
Ponyguy 69
Davidzq 47
CrystalPistol 46
Moby_Vic 43
ClayBelt 37
Bangster 35
