#2050863 - 05/20/10 09:55 AM
OD off light flashing- transmission
Loc: FL, USA
the od off light is flashing on and off...the car is hunting for gears...any idea what to check??..thank you.....
2001 crown victoria P71
#2050874 - 05/20/10 10:06 AM
Re: OD off light flashing- transmission
[Re: rick1970]
less is more�
Loc: Moses Lake, Wa
Youll need to pull the codes from the computer. Flashing OD light indicates a transmission fault.
-Colton  2004 Ford Crown Vic LX, 89k "Tank" (Totaled 12/06/15 22:30 PST) 2002 Ford Crown Vic PI, 201k "Highwayman" (Ex-Kootenai County, ID Unit #42) - Down for bad engine 2003 Ford Crown Vic PI, 98k "Name TBD"
#2050888 - 05/20/10 10:23 AM
[Re: Colt45]
Loc: FL, USA
ok..thank you....so how many things could it be??!! something easy and cheap i hope.....
#2050890 - 05/20/10 10:28 AM
[Re: rick1970]
less is more�
Loc: Moses Lake, Wa
Dozens. The codes will be more specific and it could be anything from loose or corroded wiring to a transmission rebuild. Try to avoid driving the car until this is repaired.
Edited by Colt45 (05/20/10 10:28 AM)
#2050895 - 05/20/10 10:34 AM
[Re: Colt45]
Loc: FL, USA
well..i have to drive it to the shop..thats it..i have a bike..so hope no rain...!
#2050943 - 05/20/10 11:41 AM
[Re: gDMJoe]
Loc: FL, USA
2001 ford crown victoria p71 97K miles
#2050980 - 05/20/10 12:22 PM
[Re: rick1970]
Loc: NW side Chicago
Dont drive it anymore. If the OD light is flashing, it can be a sensor of some kind. Need to have the code checked.
Jason G. '06 Towncar Designer '81 Mark VI 2 door '88 Towncar Cartier '07 P71 SAP- steedas, jmod, 410s, Mo's tune, numerous interior exterior mods. '16 F-450 V10 DRW '08 F-450 Powerstroke DRW: DPF,EGR delete, AFE intake Spartan powered. RIP 94 P71, 97 P71, 99 M74, 03 M74
#2051135 - 05/20/10 04:00 PM
[Re: 99_03PantherS]
Loc: FL, USA
i concur about not driving it..but have to get it to the shop..pushing it sucks...towing well...sucks...driving it three miles is that bad??...thanks guys...
#2054183 - 05/25/10 12:17 AM
[Re: rick1970]
Loc: Edon, Ohio
I just started getting that same thing bought the car two weeks ago, and now over 50 or 60 it does it, no shift problems or overdrive issues just blinking light.
#2374017 - 09/19/11 12:45 AM
[Re: rick1970]
Loc: San Fernando Valley, Californi...
So how do I pull the transmission codes? I have an OBDII scanner but I don't think it will help with the codes.
SteamRoller 2001 Grand Marquis LS
COMPLETED MODS: Borla Stainless cat back dual exhaust system Gutted Air Box (TurboVic's way). Airlift 100 coil inserts.
Alpine CDA 9813 MP3 - Got ripped OFF !!! replaced with a lower model Alpine
Audiobahn AS57PQ plates all around Audiobahn A4601T 4channel X 75w @ 4 ohm RMS Infinity BassLink
#2374165 - 09/19/11 11:43 AM
[Re: rick1970]
Loc: Brookfield, WI
Mine does this also I got some codes from it about a month ago then everything cleeared up and worked great now it is back. The codes I got were P1783 trans temp, P1705 tran rng out of test rng, P1502 vss inter apcm functioning, P1501 vss out of self test rn, and P0500 veh spd vss er. These seem kind of random or are they related through one sensor? It is totally fine when driving very easy. Fluid is like new still cause it keeps leaking a little so I just keep adding it as it goes to keep it fresh!
2004 P71 Dodge County Sherrif 158K 3.27 Trac-Lock, BBK 78mm TB/Plenum, 1/2 inch spacer, SCT XCAL 2 Tuner with BOC Tune, OBX LT Headers Kit, ACCEL Super Coils, Light back tinted Headlights and Clear Side markers, 8K 55W HID, Heinous Control Arms from ADTR, 17 inch 06 GT Premium Rims Up next either cams, stall, or gears.
#2374461 - 09/19/11 09:58 PM
[Re: rick1970]
Loc: California
High temp is one cause for a flashing light. If you can measure the temp with a touchless temp probe while it is flashing, you might see if the temp is too high, if the sensor is bad or not. You can shoot the bottom of the tranny pan and get a pretty accurate trans fluid temp that way. Could be that your trans cooler is plugged up, or the thermostat on the trans cooler is frozen shut. Normal is around 180 degrees, mine takes a good 10 miles to get up that high unless it's super hot out.
 2001 P73 JMOD Trim rings and tall caps. BH1976 Headlight mod, Philips XTreme9007. Rear 17mm Swaybar. Do you want a JMOD decal sticker? 2for$6, see my profile for link. Need LCM relay? (EQ1-11111S) LCM relay link here:
#2374475 - 09/19/11 10:17 PM
[Re: JSanders]
Loc: Minnesnowta
Normal is around 180 degrees That seems pretty high man unless you have a stall converter maybe. I had a scanguage on mine last year with the 3800 stall and 4.10 gears and never saw more than 165. I basically borrowed the device and beat the crap out of it for 15 minutes.
1997 Lincoln Mark VIII LSC Supercharged 9psi, E85, stock bottom end [email protected]
#2374528 - 09/20/11 12:14 AM
[Re: MyP71Vic]
Loc: Irapuato, Mexico
You can give it a try, some transmission codes can be read with a cheap scanner, if nothing comes up then you'll need to have it diagnosed with the proper scanner. I've seen that kind of behavior on transmissions when the Transmission Range Sensor aka Neutral Safety Switch or Manual Lever Position Sensor goes bad; a bad VSS can cause that too. Mine does this also I got some codes from it about a month ago then everything cleeared up and worked great now it is back. The codes I got were P1783 trans temp, P1705 tran rng out of test rng, P1502 vss inter apcm functioning, P1501 vss out of self test rn, and P0500 veh spd vss er. These seem kind of random or are they related through one sensor? It is totally fine when driving very easy. Fluid is like new still cause it keeps leaking a little so I just keep adding it as it goes to keep it fresh! It looks like your fluid leak has caused intermittent contact with the sensors. I would inspect the connectors and sensors and give them a good clean with electric contact cleaner. Oscar.
1995 Lincoln Town Car Signature 1997 Pontiac Grand Prix GT 2000 Ford Windstar SE
3 registered (av8or1, RF_Overlord, 1 invisible),
56
296
