Page 30 of 77 < 1 2 28 29 30 31 32 76 77 >
#2076506 - 06/22/10 06:13 PM Re: New big ford owner in UK - project resto/lowrider [Re: andyfanshawe]
And whats the chance of getting hold of another sensor like that?
I believe it is zero. There was a member here a few years ago looking for one. He may have found one on ebay, but for some reason I think the "fix" was pulling the airbag light and disabling the system.
Alex.
#2076523 - 06/22/10 06:22 PM Re: New big ford owner in UK - project resto/lowrider [Re: GM_Guy]
Any chance you can scan the air bag diagram? I can't find squat on the box air bag system.
If you are working off the full wiring diagram, pay special attention to tiny little references to connections to other wiring. Your power may be tied into something else as secondary power.
If you remove the airbag control module, does that phantom power go away? (air bag module holds a charge for while to power the system).
Alex.
#2076659 - 06/22/10 10:08 PM Re: New big ford owner in UK - project resto/lowrider [Re: GM_Guy]
PseudoBoat Offline
Loc: Toronto
I grabbed a bunch at a wreckers until I found a good one. I may have some still ( I know I have some sensors, just maybe not the middle one ). I intend to go to the wreckers later this summer, so there is a good chance I could ship one to you.
I'm actually going to be in London in early July...
1991 Grand Marquis - restoration project
IAS Performer Shocks
Electric Fan From Windstar
3G Alt Upgrade
Shorty Headers
#2076665 - 06/22/10 10:28 PM Re: New big ford owner in UK - project resto/lowrider [Re: PseudoBoat]
pantera77 Offline
Loc: Buffalo, NY
Pulling the air bag light = the worst noise ever.
You could throw a resister in there, or be lazy like me and put a piece of electrical tape over it.
Or fix it the right way.
2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
2005 Grand Marquis GS - Marauder swaybars, exhaust, wheels - Daily Driver/Winter Beater
2003 Marauder - Trilogy # 8, JLT, kooks, 2.5" exhaust, 4.10's/31 spline, widened rear's, metco's, addco's, ridetech's 415hp/381tq
2004 Marauder DTR - 46k 100% Bone Stock
1987 Colony Park - Money Pit
#2076918 - 06/23/10 07:57 AM Re: New big ford owner in UK - project resto/lowrider [Re: pantera77]
Jeff2 Offline
Loc: Cincinnati, Ohio
Surely one of us in the US can find a decent one in a boneyard. My airbag light isn't on, so presumably all the sensors are still good. I figure if mine are still good, here in the rust belt, other cars ought to have good sensors too.
Unfortunately, I've got no time right now to head to the boneyard (even though I could use a few parts). My son is gearing up to work on his Eagle Scout Project and that is sucking up the majority of my free time. Hopefully later this summer I'll have more free time.
1991 Crown Victoria LX (sold) - Had something like 160k miles on the original 302W and AOD trans. The odometer gears broke at a bit over 100k miles, so miles were calculated by gallons of gas times prior average MPG.
#2077160 - 06/23/10 04:37 PM Re: New big ford owner in UK - project resto/lowrider [Re: Jeff2]
andyfanshawe Offline
Loc: UK
Wow, it would be seriously nice to have someone find me a good used centre sensor, but I wonder how hard it will be to repair. I'll find out.
But now, the wiring fault..........................
Well, finally solved it! What a stupid thing it was.
Almost embarassing, but not.
The fault was assuming. I know, I know, you should never assume.
When the factory wiring was checked out, it was fine. When the new wires were soldered in, it wasn't fine. So it makes sense that I had done something wrong. But I double and triple checked the wiring colour to colour and it was okay.
Have a look at this photo, especially the black tape just above my finger
Now I ASSUMED that the tape was just holding the wires together. After all, what stupid idiot would join a permanently hot wire to an accy feed wire?
Heres a photo of it with the tape removed
That is a professional crimped join/splice. And that is where the power was being transferred to the yellow/black wire. But why would it be there? Remember this is a new stereo with no hacked wiring.
A few mins later and the crimp was off, the wires heat shrink insulated and we are back firing on all cylinders! So to speak.
Just 1 crimp was causing the electric windows to operate without the key, the LCD clock to stay illuminated and the stereo to stay powered up with the key out without manually switching it off. Still can't believe it.
We live and learn!
Andy.
www.lowcamaro.com
#2077172 - 06/23/10 04:49 PM Re: New big ford owner in UK - project resto/lowrider [Re: andyfanshawe]
interceptor1985 Offline
Loc: OREGON
About that electrical box, if you can manage to find a way inside of it you can check for blown capacitors by looking for bulged rounded off tops, they should be flat on top. that's a normal common problem for circuit boards that have had some sort of short. And the reason its wrapped in steel is to avoid radio interference I think.
By the way, great eye on that wire, it would have slipped right past me!
#2080430 - 06/27/10 11:56 AM Re: New big ford owner in UK - project resto/lowrider [Re: interceptor1985]
Justin McCarter Offline
Loc: Fredericksburg VA
I believe all my sensors are intact, never did find out why my light was on but ditched the bulb and module years ago. so if you wanted mine then i guess i could test and send it over the lake or we could make it much easier by me and you finish every thing on your car except your air bag light. send the car over i could install the sensor and make shure the fix is good over a two year quality check and test and i'll be shure to get your car back to you when the check is over.
But seriously send me a pm with what you used for circuit testing and i'll let you know. More or less just reimbursement for shipping.
Justin.
daily driver FORD F350 king ranch, 8' bed 6.4l diesel, spartan 310 tune, egr delete, 5" exhaust...
!!deceased!!! 1990 Crown vic GT A9L MAF computer conversion 347 stroker, F303 cam, T5 5speed trans. big brakes , disk rear._- Stock heads and intake 212hp@ 4k 311Lb@ 2-3.4k !!!deceased!!!
http://www.cardomain.com/id/mccarterjg
#2080648 - 06/27/10 04:18 PM Re: New big ford owner in UK - project resto/lowrider [Re: Justin McCarter]
Loc: UK
Wow! Thanks Justin.
Let me get you a test diagram drawn out. Then all you need is a digital multimeter.
I'll arrange for the car to come over to you, or just the shipping for the sensor! Whichever is easiest :-)
Thanks again.
Andy.
www.lowcamaro.com
#2081507 - 06/28/10 03:07 PM Re: New big ford owner in UK - project resto/lowrider [Re: andyfanshawe]
Loc: UK
Tonight, I intended to start the process of removing the inner rear wheel arches and reduce the outer wheel arch lip in width and start reconstructing it all-including reprofiling the rear lower quarter panels.
BUT, got involved in servicing my dads car Enjoyed it too much though. Took me away from the jobs in hand!
Tell you what though. Went out in it yesterday to the local country park with my youngest son (7) and my good lady Wife. I drove, my Wife sat on the passenger front and my little lad sat inbetween us on the bench seat! Was fantastic. All 3 on one seat, and still plenty of room.
Now what car can you do that in these days? Eh? Those days are gone! But not for us :yay:
Andy.
www.lowcamaro.com
#2081525 - 06/28/10 03:29 PM Re: New big ford owner in UK - project resto/lowrider [Re: andyfanshawe]
Loc: UK
Hi again Justin.
Here is a connector view of the centre front airbag sensor.
Sorry its slightly blurred!
Anyway, put a digital multimeter set on ohms, between connector 620 and a good shiney bit of the metal case. If it reads less than 1 ohm, chuck it in a box and tell me what I owe you for shipping!
Thanks.
Andy.
www.lowcamaro.com
#2081811 - 06/28/10 09:04 PM Re: New big ford owner in UK - project resto/lowrider [Re: andyfanshawe]
I'll check tomorrow, and i'm going to need a real address a bit more specific than UK. I have a shipping est that could be from 80$-170$.
One random address gave me a 4day shipping of 71$ and a 2day shipping of 49$, that would be for around Blackfriars st. Carlisle.
Justin.
Edited by Justin McCarter (06/28/10 09:11 PM)
#2082639 - 06/29/10 06:52 PM Re: New big ford owner in UK - project resto/lowrider [Re: Justin McCarter]
Ship it as a international surface parcel with Canada Post (6"x5"x4" 1kg is $15). Shipping with things like fedex will hit Andy with extra charges from the shipper.
If not a lot is going over on the mail run, it'll get to andy within 2 weeks since they fill the space with the lower dollar options. It potentially can get to Andy as fast as express post.
Alex.
#2083110 - 06/30/10 12:31 PM Re: New big ford owner in UK - project resto/lowrider [Re: GM_Guy]
enslow Offline
Loc: Vancouver
Justin is in the US, so he has two options. Drive to Canada to ship it Canada Post, or ship it US Postal Service. But you're right, UPS, Fedex, etc have inflated shipping costs, especially for international orders.
Testing the MAF
Digital Cluster Repair
Stalag's Coolant Write-up
#2083439 - 06/30/10 05:09 PM Re: New big ford owner in UK - project resto/lowrider [Re: enslow]
Oops. I was thinking of the Toronto fella who said he had some modules. The US has priority mail international (small packets upto 4 pounds for $13.45. (flat rate box 8-5/8" x 5-3/8" x 1-5/8")
[ http://www.usps.com/prices/priority-mail-international-prices.htm ]
Alex.
0 registered (), 67 Guests and 18 Spiders online.
