#2174822 - 11/03/10 09:49 PM headlight switch backwards compatible?
Drac Offline
Cpt. Smug
Loc: Cali
i have a 2004 CVPI headlight switch laying around. i like it more than the 2000 switch i currently have. i know since the dimmer is different, it may net be a direct swap. but is it possible to wire the 2004 assembly it in to my 2000?
#2174974 - 11/04/10 01:40 AM Re: headlight switch backwards compatible? [Re: Drac]
optik Offline
never say never
Loc: Minneapolis, MN
I was actually considering doing the same thing in reverse during the course of my auto-lamp upgrade. The newer version switch I bought on fleabay, the knob is kinda grayish, certainly a lighter more faded black than the switch body, which annoys me more than is reasonable.
Originally Posted By Ezbok58a
Chicago, come for the food. Stay because you were murdered.
2014 Ford Fusion Titanium AWD
2008 Ford Expedition SSV
Mirror of p71interceptor.com: http://www.idmsvcs.com/2vmod/
Mirror of moldyrabbit.com/liquid/: http://www.idmsvcs.com/liquid/
#2175014 - 11/04/10 05:37 AM Re: headlight switch backwards compatible? [Re: optik]
P_Weston Offline
Cynical Bastard
Loc: Reno, Nevada
Is it just me or did I miss the part where you can push the knob in for cabin lights? I have two 2003+ switches and they both don't press in. My roommates 04 GMQ's doesn't press in either?
2000 Mercury Grand Marquis GS "Dewgong"
#2175030 - 11/04/10 08:12 AM Re: headlight switch backwards compatible? [Re: P_Weston]
larryo340 Offline
Loc: Long Island
...and the autolamps delayed off time not an easy turn of the knob. I know the '06 is owner programable, it's not hard but is a PITA to do.
MOD List for MGM
...Marquis sold frown
#2175623 - 11/04/10 11:46 PM Re: headlight switch backwards compatible? [Re: larryo340]
Drac Offline
Cpt. Smug
Loc: Cali
anyone have a solid answer to my original question? lol
#2175637 - 11/05/10 12:13 AM Re: headlight switch backwards compatible? [Re: Drac]
ALPHA Offline
Loc: butte, ca
i dont think so dude, i was just looking at my switches and the signal from the digital to anilog would be different, unless the wires are the same, but it makes me wonder if the lcm is different
USGI Mil-Spec Disposable Tactical Retention Straps AKA ZIP TIES
FULL P71 Site Download
someone buy me stap stickers, i love those things
alpha@crownvic.net
#2176456 - 11/06/10 01:54 PM Re: headlight switch backwards compatible? [Re: ALPHA]
No, you can't use an '03- switch in a '95-'02
While the actual headlamp switch could be wired in without much difficulty, the dimmer is not at all compatible.
2003+ use a rheostat for the panel dimming. Not in the traditional manner (controlling output voltage), rather, resistance to ground to the LCM. The LCM uses this resistance to ground input to determine the panel dimming.
The '95-'02 system, however, simply uses independent panel dim UP and panel dim DOWN inputs to the LCM from the momentary dimming rocker switch
#2176459 - 11/06/10 01:56 PM Re: headlight switch backwards compatible? [Re: P_Weston]
The dome lamp function of 03+ switches was made part of dimmer switch, much like older cars (turn all the way, past the stop, to turn on the interior lamps)
#2177106 - 11/07/10 05:37 PM Re: headlight switch backwards compatible? [Re: dRock96Marquis]
Drac Offline
Cpt. Smug
Loc: Cali
thanks drock!
0 registered (), 59 Guests and 12 Spiders online.
