#2225989 - 01/26/11 07:51 PM oil all under my hood...anyone else have this?
tackleberry Offline
Loc: Las Vegas
so i saw a tiny drop under my car, i popped the hood and saw a mess of fluid sprayed all over the motor and hood.
looks like the fan sprayed oil all over the place? im almost certain that its oil as its brown in color.
i have no had any oil leaks on the ground tho....i cant see any leaks anywhere. could the oil cooler itself just be shot and leaking somewhere that i cant see it?
any help would be great, please look at photos.
#2225996 - 01/26/11 07:57 PM Re: oil all under my hood...anyone else have this? [Re: tackleberry]
Dogslayer Offline
Loc: Montgomery county,Ohio
I dont know but it looks bad
#2226009 - 01/26/11 08:11 PM Re: oil all under my hood...anyone else have this? [Re: Dogslayer]
blazer Offline
Loc: New Jersey
Check your tranny lines. I had something similar like that happen to me. Had a hole in the line and it was spraying up.Start the car, open the hood and look around. Be careful. Hope it's minor... As for the previous persons input...Worthless!!
2001 CVPI
#2226011 - 01/26/11 08:14 PM Re: oil all under my hood...anyone else have this? [Re: blazer]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
The fan is clean from the motor forward, The oil is from the FEAD area and looks like the fan did blow it all over.
I like that ^^ guys idea, Check the oil to make sure your up to the line then start the car and look.
how does it look under the crank and balancer ?
The Jmod video is done! LINK!
#2226022 - 01/26/11 08:24 PM Re: oil all under my hood...anyone else have this? [Re: Rizzo]
SPM Offline
Loc: Minnesota
You've got leakage that is finding its way onto one or more pulleys, where it's getting sprayed around like a runny nose. First thing I'd be doing is verifying that it really is oil and not something else, like trans fluid from the cooler lines or the power steering pump.
It's hard to tell by those pics exactly where it's coming from, but there's only so many places for a leak to start at depending on what's leaking...
2008 Grand Marquis LS, 138K miles
2014 Chrysler 300C, 97K miles (sold)
2005 Grand Marquis LS, 145K miles (sold)
2000 CVPI, 229K miles (sold)
#2226030 - 01/26/11 08:32 PM Re: oil all under my hood...anyone else have this? [Re: SPM]
P70_Owner Offline
Loc: NY
What color is your coolent? It could be a pinhole leak in the coolent line that's doing it.
'07 P70 with 280K. Runs like a champ. laugh
Came with the "Taxi Chip"! grin
Want to throw throw money down the drain and make your car look like crap? Try painting your car yourself!
#2226037 - 01/26/11 08:38 PM Re: oil all under my hood...anyone else have this? [Re: P70_Owner]
tackleberry Offline
Loc: Las Vegas
coolant is green.
i have been smelling coolant for a while, but never a leak and only smelled it when the fan turned on. meaning, if i ran the air cond all the time to have the fan running, i never smelled coolant because the temp of the car was always at 190-193 insted of 198-200 before the fan kicked in, and the drop on the ground looked greenish brown. only one drop never seen it before.
its really weird. i dont see any leaks along the FEAD line which is making me think its not coming from the motor. i did replace my oil cooler lines about 2 weeks ago. those are not leaking from anything i can see.
#2226054 - 01/26/11 09:07 PM Re: oil all under my hood...anyone else have this? [Re: tackleberry]
P70_Owner Offline
Loc: NY
Just a shot in the dark, but I think you may have a pinhole leak in your radiator. I think the dirt from the fan and hood is turning it brown, but that's just a guess by the way the fan looks. Not too many things are directly in front of the fan, and seeing how the radiator is right there, that's what I'm betting on.
#2226058 - 01/26/11 09:11 PM Re: oil all under my hood...anyone else have this? [Re: P70_Owner]
tackleberry Offline
Loc: Las Vegas
thats what i was thinking first it was coolant, but the color threw me off. my oil is also about 500 miles past due and last i saw it was very dark. this stuff is kinda lighter brown.
#2226090 - 01/26/11 09:46 PM Re: oil all under my hood...anyone else have this? [Re: tackleberry]
nba1341 Offline
Loc: Upland, California
^^^ lighter brown as in slightly rusty/dirty coolant..?
2010 Grand Marquis LS 75k
1965 Mustang Fastback
#2226106 - 01/26/11 10:01 PM Re: oil all under my hood...anyone else have this? [Re: nba1341]
What about the Water pump? when My Malibu's Water pump went, It di almost exactly that, the FEAD belt caused it to spray nasty orange Dex-Cool everywhere! I have no Idea where exactly it was leaking, but I could clearly see coolant coming off of the pulley. Your Engine bay looks like its covered in green, but that could just be the photos.
EDIT: Just looked at the photos again, there is definitely alot of green around the water pump pulley. I'd almost put money on it. As for why it looks brown on the hood, Its probably picking up grease from elsewhere under the hood.
Edited by BigMerc96 (01/26/11 10:06 PM)
#2226131 - 01/26/11 10:36 PM Re: oil all under my hood...anyone else have this? [Re: BigMerc96]
tackleberry Offline
Loc: Las Vegas
sounds like a pressure test is in order? anyone have a link with pics how to do it or is it as simple as putting the tester on where the rad cap goes and pump the tool til you see a leak at a specified pound level?
#2226135 - 01/26/11 10:40 PM Re: oil all under my hood...anyone else have this? [Re: BigMerc96]
tackleberry Offline
Loc: Las Vegas
here is a larger pic of the water pump
#2226173 - 01/26/11 11:21 PM Re: oil all under my hood...anyone else have this? [Re: tackleberry]
Bangster Offline
man up and taste it \:\)
#2226197 - 01/26/11 11:50 PM Re: oil all under my hood...anyone else have this? [Re: Bangster]
tackleberry Offline
Loc: Las Vegas
hahaha!! wont be the first time lol
4 registered (HDmech, Oldgeizer, a_d_a_m, 1 invisible), 66 Guests and 272 Spiders online.
bluejay_32 202
a_d_a_m 130
DudeAbides 124
CrystalPistol 104
Old_Guy_Stu 98
Moby_Vic 73
Ponyguy 57
ford05 55
f00barbob 50
Warped9 45
