Page 2 of 3 < 1 2 3 >
#2266072 - 03/25/11 08:34 PM Re: Cranks strong but won't start [Re: OPS03]
TheShadow Offline
Loc: SoCal High Desert
That clanking might just be your exhaust hangers, about $5 each (6 of them) 2 on the muffler and 1 on the tailpipe, each side.
#2266079 - 03/25/11 08:48 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
K, I'll check thanks for the suggestion.
#2270192 - 04/01/11 01:46 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
The starting problem returned with a vengeance...I'm wondering whether it might be electrical. In any case, I ordered and new pump and pillow filter.
#2270934 - 04/02/11 06:16 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
When I get the pump my plan is to siphon as much gas as possible into my Expedition, then run the Panther dry in the garage (door open...hehe) then I will take photos and videos as much as possible to document removal of the old pump and install of the new. I'll replace the hangers as well since I'll need to remove them to move the pipes anyway. If anyone here in SoCal wants to help...
#2271359 - 04/03/11 12:56 PM Re: Cranks strong but won't start [Re: OPS03]
Harrisons004 Offline
Loc: South OC, California
Where in socal are we talking? Im having kind of similar problems and after trying to fix other things, I am suspecting it is the fuel pump.
Black '98 CVPI work in progress. honeycomb grill and a few other little things to start.
Coming soon; Go Rhino! push bumper, New paint, Jmod hopefully, and Headlight Relay upgrade kit.
#2271692 - 04/03/11 10:44 PM Re: Cranks strong but won't start [Re: OPS03]
Skoles Offline
Loc: Mass
In the body of knowledge section about the fuel pump there's a piece mentioned one of the wires chaffing and grounding out at the pump being an issue. Did you check that?
2001 CVPI
#2271943 - 04/04/11 11:04 AM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
Thanks for the suggestion it could very well be a wire that is the type of behavior it has - works great most of the time good pressure, but intermittently doesn't even prime. I have not checked it, but I will.
I had an Ebay code and so I got the Airtex E2471-type pump with filter shipped for $15. Yes, $15. I am going to take the hangers off and then I will be able to move the pipes just enough to get the whole unit out as per the very helpful Youtube video. I'll check all wires and connections, replace at least the pillow filter (worth the $15 right there) and I'll likely replace the pump as well at that point UNLESS I definitely find a bad connection or chaffed wire or something along those lines. Then I'll replace the hangers and then....hopefully move onto the next problem.
#2272857 - 04/05/11 08:19 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
I check the wires everywhere I could think of -- on the outside of the unit on the tank, in the trunk (found 2 hollow-points), under the seat, behind the seat (nothing there really), changed the Cam pos sensor for the hell of it ($15) checked all fuses. Wow, there is no life coming from that pump. I had my son turn the key as I touched the relay in that box on the drivers side in the engine compartment. I could feel the relay 'kick', I checked all the fuses and swapped some relays in the other box near the battery. Hey - there's a smaller, rectangular box near the box but closer to the firewall with 2 relays in it. What's that all about? Police stuff?
Anyway, I guess I'll roll it down the driveway, push it around to the right direction, and then use my Expedition to push it up the driveway into the garage for the _real_ fun. Pics to follow.
#2275715 - 04/10/11 01:05 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
wow, these cars run a lot better when they are actaully getting fuel to the engine. I installed the fuel pump, cost $15, I spent more on tools and such. Afterwards I ran for a while then checked everything then went to fill up with gas and put 17.8 gallons in.
Edited by OPS03 (04/10/11 05:40 PM)
#2277665 - 04/12/11 11:18 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
The fuel pump replacement is complete.
One of the articles in the 'Body of Knowledge': "1992+ Panther fuel pump replacement - by JayP71" was very helpful. Thanks JayP71...
Thanks also to Galaxieman - very good hints there.
My P71 goes vroom vroom again. Nice.
#2278028 - 04/13/11 02:50 PM Re: Cranks strong but won't start [Re: OPS03]
NSCVPI Offline
Loc: Nova Scotia
I had the same problem with my 2005 CVPI a year ago or so and I replaced the fuel pump to fix the problem also. The best price I could find at the time was $400 for a fuel pump and sending unit though.. I guess I got ripped off?
#2278228 - 04/13/11 08:35 PM Re: Cranks strong but won't start [Re: OPS03]
OPS03 Offline
Loc: California
No, it sounds like you bought the whole unit, which includes the float and everything, right? Local Ford dealer quoted me about the same they sell just the whole unit not just the pump. I just purchased a pump, came with the filter and a pigtail (which I didn't use). This is it here:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360350557218&viewitem=&sspagename=STRK%3AMEWNX%3AIT#ht_2303wt_935
I had a coupon for $10 off. So now my fuel pump problem is solved, BUT the 'mechanic' said my tranny needs major work. I'm not sure I believe him though, I'm getting lurching at about 45mph with low pedal pressure he says the OD gear may be going or something internal is f'd up. I'm hoping it's just a switch or sensor on the outside.
#2609617 - 10/11/12 06:34 AM Re: Cranks strong but won't start [Re: BigMerc96]
Jay28660 Offline
Loc: Garden City, MI
Originally Posted By: BigMerc96
Check all the fuses and swap the fuel pump relay w/ another one. there are a few things in these cars you could "borrow" a relay from, I think the a/c uses the same type of relay, can't remember. When you turn the key to run, You should hear the fuel pump whine for a few seconds then stop. also, when you turn the key to "run" the check engine light should come on. If the check engine light won't come on, then the ECU isn't getting power. If you can't hear the fuel pump, then its not getting power or has failed. If the ECU isn't on, obviously it won't be able to prime the fuel pump.
How can you test if the ECU isnt getting power? I am having a starting issue and I dont have any dash lights coming on but the car will crank. Headlights and taillights work but no start. How can you diagnose an ECU? where is it?
#2609687 - 10/11/12 11:00 AM Re: Cranks strong but won't start [Re: OPS03]
No CEL while ign on/cranking generally equals loss of power to the PCM...
Now with P/S & PDB
#2609769 - 10/11/12 01:32 PM Re: Cranks strong but won't start [Re: OPS03]
jdebert Offline
Loc: Monterey CA
That link,
is delisted. No can see.
0 registered (), 20 Guests and 122 Spiders online.
bluejay_32 204
a_d_a_m 126
Old_Guy_Stu 124
DudeAbides 95
Ponyguy 68
Davidzq 47
CrystalPistol 46
Moby_Vic 43
ClayBelt 38
LTC_Dave 35
