#1623001 - 11/25/08 07:08 PM Motor Oil Capacity
cfrank Offline
Loc: North Florida
Being these P71's have oil coolers does that increase the oil capacity or is it still the normal 5 quarts with filter?
2000 Ford Crown Victoria P71 - Ex jacksonville,Fl PD unit# 160
Check out my ebay items!
#1623010 - 11/25/08 07:14 PM Re: Motor Oil Capacity [Re: cfrank]
Rizzo Offline
J-MOD Master
Loc: Romulus,MI
I always buy 6 and have one to top off and then save that for the next lawn mower oil change
The Jmod video is done! LINK!
#1623054 - 11/25/08 07:48 PM Re: Motor Oil Capacity [Re: Rizzo]
Panther71 Offline
Ford says 5 quarts with filter..........
2000 P71 Former Ridgecrest,CA PD Captains Unit -- 125K -- P71 Pic in link below...
http://4.bp.blogspot.com/_M4HMCCz1jm8/SUVu1QY70iI/AAAAAAAAAAU/iMXwNDv8eGk/s1600-h/DSC_0028.JPG
#1623080 - 11/25/08 08:05 PM Re: Motor Oil Capacity [Re: Panther71]
mustang_zulu Offline
I am not
Loc: Garland, TX
x2, and with them selling oil in those 5 quart jugs makes it easy for us \:\)
#1623087 - 11/25/08 08:10 PM Re: Motor Oil Capacity [Re: mustang_zulu]
cfrank Offline
Loc: North Florida
Well, it makes sense. But it is still kind of hard to believe that the same car without oil cooler would still hold the same amount so how big is the oil cooler/how much does it hold?
#1623116 - 11/25/08 08:32 PM Re: Motor Oil Capacity [Re: cfrank]
99vicnerd Offline
Loc: NA
actually, i looked up how much they hold before i did my first oil change in my 99 p71. Some site said they held 7 quarts, but I am thinking when you drain the pan out, you aren't draining the cooler, so its prolly still holding a good quart in itself.
#1623132 - 11/25/08 08:39 PM Re: Motor Oil Capacity [Re: 99vicnerd]
A lot of the oil in the cooler lines and cooler will remain. Even if you did drain them out you wouldn't get as much as you'd expect.
Definitely don't dump in 7 quarts!
If you have an oil cooler (p71, Tow) expect to use ~5.25 for -'02 and ~6.25 for '03+
Non oil cooler cars - 5 quarts -02, 6 quarts 03+
#1623166 - 11/25/08 09:05 PM Re: Motor Oil Capacity [Re: dRock96Marquis]
99vicnerd Offline
Loc: NA
I didn't use 7, i used 5. There was just some site that said 6-7 or something.
#1623295 - 11/25/08 10:31 PM Re: Motor Oil Capacity [Re: 99vicnerd]
Fordiesel69 Offline
Loc: Erie, PA
I always let my oil stop dripping which usually take 30 minutes unless it is a hot summer day. EVERY P71 I owned took 5.5 to reach the full mark. On the 04 I had, it took 6.5 to hit the full mark. If you just drain and fill quickly and don;t wait for it to stop dripping, then maybe 5 would be fine.
-'14 Fusion S - 160K
#1626156 - 11/29/08 01:07 PM Re: Motor Oil Capacity [Re: dRock96Marquis]
R03 Offline
Loc: Land of the Free.
Hold on, can you please clarify this for me.
I might be reading this wrong.
6.25 quarts for 03+ non oil cooler equipped.
5 quarts for 02- oil cooler equipped.
6 quarts for 03+ oil cooler equipped.
Claudine.
2006 / P71 / 150,000km
#1626160 - 11/29/08 01:15 PM Re: Motor Oil Capacity [Re: R03]
flyboy Offline
Ret US Army Medic
Loc: Chillicothe, Mo
My 04 Sport & the 04 LTC both use only 6 qts. Never had experience with oil cooler.
#1626396 - 11/29/08 07:46 PM Re: Motor Oil Capacity [Re: flyboy]
ford05 Offline
Loc: New Jersey
I USE 6 QTS
#1626504 - 11/29/08 11:34 PM Re: Motor Oil Capacity [Re: ford05]
Fordiesel69 Offline
Loc: Erie, PA
Keep it simple.
Police cars:
98-02 takes 5.5
03-08 takes 6.5
And if I am off by 0.25, no problem. The oil pan has a shield welded into it to prevent the crank from splashing the oil.
This is what it takes to get mine exactly on the full mark. I have owned enough to know it is not a miscalibrated dipstick. However I do let mine drain a long to get as much old out as possible.
#1626514 - 11/30/08 12:06 AM Re: Motor Oil Capacity [Re: Fordiesel69]
KSPEED Offline
Loc: Kansas
Oops. I put in 6 last time! Dipstick looked okay...
2001 P71 SAP -- More Stuff Click!
#2262817 - 03/20/11 09:31 PM Re: Motor Oil Capacity [Re: cfrank]
Steveo989 Offline
Loc: Minnesota
I think the best course of action is to buy (2) five-quart jugs of your choice oil. Dump 5 quarts in, start it up, check for leaks, drop the car, and then top off to desired amount. It's always going to be a slightly different amount.
The important part is making sure you get enough oil in the crankcase so it won't run dry then you can always top it off to spec.
I always like filling it up as high on the hashes as it goes. I think the extra capacity helps to absorb heat due to the increased oil volume, I am pretty sure it makes a difference.
2005 Ford Crown Victoria 130,000 Engine:G-Oil 5w-30 w/ Purolator Pureone, Rear Diff. Valvoline Synpower 75w-140, Transmission Valvoline Mercon V.
1999 Ford Crown Vic 125,000 Engine: Mobil 1 5w-30 w/ Wix, Rear Diff Royal Purple 80w-90, Transmission OEM Motorcraft Mercon V.
2001 Dodge Intrepid 134,000 Engine Valvoline Nextgen 10w-30 w/ Purolator Pureone.
5 registered (bluejay_32, Rainbowpizza, Davidzq, ismann, 1 invisible), 71 Guests and 289 Spiders online.
bluejay_32 161
a_d_a_m 106
Rainbowpizza 36
