#2241556 - 02/18/11 02:25 PM
Re: Cranks strong but won't start
[Re: OPS03]
Check all the fuses and swap the fuel pump relay w/ another one. there are a few things in these cars you could "borrow" a relay from, I think the a/c uses the same type of relay, can't remember. When you turn the key to run, You should hear the fuel pump whine for a few seconds then stop. also, when you turn the key to "run" the check engine light should come on. If the check engine light won't come on, then the ECU isn't getting power. If you can't hear the fuel pump, then its not getting power or has failed. If the ECU isn't on, obviously it won't be able to prime the fuel pump.
#2241858 - 02/18/11 09:12 PM
[Re: OPS03]
Glad it was something simple, its always a good thing.
#2242511 - 02/19/11 10:37 PM
[Re: OPS03]
Loc: Clearwater, Florida
Sorry dude but mine was the same way and it ended up as the fuel pump. Its very very common on these cars. So common the dealer may be out of stock for the pump and you'll have to go autozone.
I suggest you rent for free a fuel pressure gauge from Autozone and hook it to the shrader valve on the intake and check the fuel pressure. It will tell you its not happy. You have to force the pump on using the dongle on the drivers side wheel well.
The pisser is it may not even be the pump itself but the pump filter sock gets so nasty & clogged after a few years it starves the pump. Sock is unavailable. You'll see what I mean when you pull it.
Sig removed. Read the rules.
#2242711 - 02/20/11 11:51 AM
[Re: OPS03]
Let not get ahead of ourselves here, Change the fuel filter if it hasn't been done recently. The service interval on these filters is only 15,000 mi, and driving w/ it clogged for an extended period of time will kill the pump. If the car seems fine after that, I wouldn't think too much into it. If the car still acts funny, then I would get a pressure tester and look farther into it. Relays do go bad, and its a simple fix, thats why it was in my first line of suggestions.
#2257342 - 03/12/11 01:28 PM
[Re: OPS03]
Next time it does this, Triple prime the fuel system before trying to crank it over. This is accomplished by turning the key to run for 5-10sec then turning it off, wait 30sec then turn it to run again. After the third time you turn it to run, try and start it. If it fires right up, then there is fuel pressure issues, either a clogged filter or a dying pump.
#2257347 - 03/12/11 01:58 PM
[Re: OPS03]
Loc: Ma.
now it might be a good time to check the fuel pressure
